[PATCH] Beaglebone: fix missing clobber in inline assembly.
Marcos Díaz marcos.diaz at tallertechnologies.com
Thu Sep 10 18:08:20 UTC 2015
Ticket #2416
https://devel.rtems.org/ticket/2416
Please let me know if this is ok and if I need to submit something else.
Greetings
On Thu, Sep 10, 2015 at 12:48 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> Marco,
> This looks fine and I will apply it but I want to put it on 4.11
> and master. Can you file a quick ticket on it?
> Thanks.
> --joel
> On 9/10/2015 10:20 AM, Marcos Diaz wrote:
>> flush_data_cache uses R0 directly but doesn't list it as a clobbered
>> register.
>> Compiling with -O3 made this code break, since the function that calls
>> flush_data_cache
>> already uses r0.
>>   c/src/lib/libbsp/arm/beagle/include/bsp.h | 8 +++++++-
>>   1 file changed, 7 insertions(+), 1 deletion(-)
>> diff --git a/c/src/lib/libbsp/arm/beagle/include/bsp.h
>> b/c/src/lib/libbsp/arm/beagle/include/bsp.h
>> index 0250749..d9fd2ae 100644
>> --- a/c/src/lib/libbsp/arm/beagle/include/bsp.h
>> +++ b/c/src/lib/libbsp/arm/beagle/include/bsp.h
>> @@ -112,7 +112,13 @@ static inline void isb(void)
>>   /* flush data cache */
>>   static inline void flush_data_cache(void)
>> -    asm volatile("mov r0, #0; mcr p15, #0, r0, c7, c10, #4" : : :
>> "memory");
>> +    asm volatile(
>> +        "mov r0, #0\n"
>> +        "mcr p15, #0, r0, c7, c10, #4\n"
>> +        : /* No outputs */
>> +        : /* No inputs */
>> +        : "r0","memory"
>>   #define __arch_getb(a)      (*(volatile unsigned char *)(a))
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
______________________________
<http://www.tallertechnologies.com>
Marcos Díaz
Software Engineer
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
Skype: markdiaz22
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150910/f5cf3c53/attachment-0002.html>
