Patch for nested mutex project solving priority inversion problem for uniprocessor.
Saurabh Gadia gadia at usc.edu
Fri Sep 11 00:14:20 UTC 2015
Hi Sebastian,
Sorry for late reply. I was out of town and could not reply. I am bit
confused with above description which I need to get clarified:
1. replaced LIFO with sorted list:  I don't change the mutex order to make
the list sorted. Instead I promote the priorities so that we don't need to
change position of mutex in the chain and the list without any swapping of
mutex in chain becomes sorted and valid.
2. I was confused with spsem03 test cases. So I created spsem04 test case
which demonstrates that our implementation supports horizontal
implementation. It has the same scenario of test case 3 but now we can say
that horizontal nesting works correctly. you can find all description about
this test cases on link below.
https://docs.google.com/document/d/1RM427RKSoyrZrchEcDIx4etmtWqrFArzRRLWqcU8RK0/edit?usp=sharing
3. Your mentioned example is definitely supported by the our implementation.
I also need clarification on ticket 2412:
1. Is there something wrong with problem description?
    it says - "The allocator mutex is already owned, so the priority of the
low priority thread is raised to the priority of the high priority thread.
The memory allocation completes and the allocator mutex is released, since
the low priority thread still owns the file system instance mutex it
continues to execute with the high priority (the high priority thread is
not scheduled)"
Instead --> after releasing lock over allocator the low priority threads
priority will no longer be high as there is restoration of priority of on
mutex release. This is the behavior with our implementation. So low
priority thread will again be restored at its original priority after
releasing allocator lock.
*I am not able to get what do we have to do in this ticket like what is the
problem we are trying to solve(objective, current behavior)*
2. Our implementation is only for strict order mutex behavior and will not
work for unordered mutex operations. We will need complete different
implementation for unordered mutex operation.
3. Our SMP implementation has recursive mutex acquisition behavior for
supporting horizontal nesting? Will it be fine with RTEMS?
note: *Cyrille* please mention any other doubts if I have missed any.
Thanks,
Saurabh Gadia
On Sun, Sep 6, 2015 at 11:04 PM, Sebastian Huber <
> Hello Saurabh,
> On 05/09/15 01:52, Saurabh Gadia wrote:
>> This is the patch for solving priority inversion problem for uniprocessor
>> architecture. It works correctly for all test cases on master. For 4.11 the
>> patch get applied cleanly but the branch does not compile because of some
>> rbtree error(unrelated to project). Github link:
>> https://github.com/saurabhgadia4/rtems/tree/nested-mutex
> I reviewed your patch. Basically you replaced the LIFO list of priorities
> with a sorted list? Does it work with timeouts and external priority
> changes (e.g. task A blocks on a mutex owned by O, another task B raises
> the priority of A, will this raise the priority of O?)
> Since all tests pass, test sptests/spsem03 passes, which shows that your
> implementation doesn't support horizontal nesting.
> There is no deadlock detection.
> Please have a look at:
> https://devel.rtems.org/ticket/2412
> I think the suggested implementation would even work on SMP systems quite
> well.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150910/11b18cc8/attachment-0002.html>
