[PATCH] [RTEMS] Update RTEMS thread model
Aurelio Remonda aurelio.remonda at tallertechnologies.com
Tue Sep 22 14:01:49 UTC 2015
Thank you Sebastian! We were able to reproduce the tests.
The test we were interested in was 25_algorithms/random_shuffle/moveable,
this one fails, as we saw in your results (and ours as well). We debugged
it and find out that all three VERIFY pass (cout of the same line gave us
1, is an equal) but we didn't get the exit code 0 at the end of the
simulation. Apparently, this is making DejaGNU think something's wrong.
We find out that if we reduce the size of A (the array that contains the
values being shuffled) the test runs correctly.
On Fri, Sep 18, 2015 at 5:24 AM, Sebastian Huber <
> On 17/09/15 16:36, Aurelio Remonda wrote:
>> It is printing the "real time" but the time is set to a date early
>>> >in the RTEMS development history. Look at the year. That's about the
>>> >time the test was initially written.
>>> >It is likely running faster than "real time" because it is a simulator.
>>> >The numbers not ending in "5" is a bit unusual. The test consists of
>>> >four tasks:
>>> >+ one runs every 5 seconds
>>> >+ one every 10
>>> >+ one every 15
>>> >+ IDLE
>>> >It exits when one notices it has gone over 30 seconds.
>> Thank you Joel! I have another question if you don't mind: where i can
>> find the realview_pbx_a9_qemu.exp file?
>> I can't find it in dejagnu/boards.
> Sorry, I check this file in.
Aurelio Remonda
Software Engineer
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
*Phone:* +54-351-4217888 / 4218211
<http://www.tallertechnologies.com> <http://www.tallertechnologies.com>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150922/0e52bc53/attachment-0002.html>
