Rtems-test cortex-m3
Sebastian Huber
Fri Apr 1 04:57:21 UTC 2016
On 28/03/16 21:01, Aurelio Remonda wrote:
> Hello, we were trying to get Sebastian's patches to work on the latest
> qemu. It seems the board is running ok on qemu 2.5.50 without the
> patches except for:
> -Memory hack: The memory on this board is still fixed to default
> value. I already submit a patch that allows you to change the memory
> size we are waiting for revision.
Nice.
> -Disable-priority_mask: this patch does not apply directly and rtems
> is running without it.
I am not sure which side-effects has this.
> So I run the rtems-test script:
> ./rtems-test --log=lm3s6965_qemu --timeout=60
> --rtems-bsp=lm3s6965_qemu
> --rtems-tools=/home/aurelio-remonda/rtems/install
> /home/aurelio-remonda/rtems/build/arm-rtems4.11/c/lm3s6965/testsuites/
> Passed: 342
> Failed: 0
> Timeouts: 175
> Invalid: 0
> Total: 517
> Average test time: 0:00:15.392969
> Testing time : 2:12:38.165222
> And then again with default time out:
> ./rtems-test --log=lm3s6965_qemu --rtems-bsp=lm3s6965_qemu
> Passed: 345
> Failed: 0
> Timeouts: 172
> Invalid: 0
> Total: 517
> Average test time: 0:00:46.056823
> Testing time : 6:36:51.377917
> So the test resulting in timeouts are known cases? Any of these test
> will pass if I set a larger timeout value?
> Do you think we can change the qemu version for this board?
This timeout count is too high. Only the spintrcritical* tests may
timeout out. All other timeouts should be looked at individually.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
