[PATCH] pc386: Add virtio network driver
Jinhyun jinhyun at konkuk.ac.kr
Fri Apr 1 08:41:20 UTC 2016
Thanks for your comments and interest in our patch.
Our implementation is based on FreeBSD version release 10.0.0. As you have suggested,
we will add ifdefs to distinguish the RTEMS specific codes and resubmit the
patch.
In addition, we will add instructions on how to use it in
virtio/README.txt. Let us know if this is OK.
Thanks,
Jin-Hyun
Sent: Tuesday, March 29, 2016 11:41 PM
To: Jinhyun <jinhyun at konkuk.ac.kr>
Cc: rtems-devel at rtems.org <devel at rtems.org>; jinh at konkuk.ac.kr
Subject: Re: [PATCH] pc386: Add virtio network driver
Hi
Thanks for the submission. My comments are going to be very general.
+ Can you document which version of the FreeBSD source files this is based
up? Perhaps an svn revision/branch and a list of the exact files in their source
tree? This has been a historical problem when trying to track future changes.
+ What were the nature of the rtems specific changes? Are they cleanly
ifdef'ed so a diff against the original FreeBSD source shows ifdef additions
and blocks of RTEMS specific code added?
+ I didn't see any instructions on how to use this. What type of setup is
needed?
I am pretty sure I actually reviewed a conference paper on this work and
am excited to see it submitted. Let's just make it top notch on usability
and maintainability.
--joel
On Tue, Mar 29, 2016 at 8:47 AM, Jinhyun <mailto:jinhyun at konkuk.ac.kr> wrote:
diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am
b/c/src/lib/libbsp/i386/pc386/Makefile.am
index d9af7dd..da50c67 100644
--- a/c/src/lib/libbsp/i386/pc386/Makefile.am
+++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
@@ -232,6 +232,19 @@ noinst_PROGRAMS += 3c509.rel
 3c509_rel_LDFLAGS += -Wl,--undefined=ep_board
 endif
+if HAS_NETWORKING
+vtnet_CPPFLAGS = -D__INSIDE_RTEMS_BSD_TCPIP_STACK__
+noinst_PROGRAMS += vtnet.rel
+vtnet_rel_SOURCES = virtio/if_vtnet.c
+vtnet_rel_SOURCES += virtio/if_vtnet.h
+vtnet_rel_SOURCES += virtio/virtio_pci.c
+vtnet_rel_SOURCES += virtio/virtio_pci.h
+vtnet_rel_SOURCES += virtio/virtio.c
+vtnet_rel_SOURCES += virtio/virtio.h
+vtnet_rel_CPPFLAGS = $(AM_CPPFLAGS) $(vtnet_CPPFLAGS)
+vtnet_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
+endif
 libbsp_a_LIBADD = mailto:../../../libcpu/@RTEMS_CPU@/cache.rel
 libbsp_a_LIBADD += mailto:../../../libcpu/@RTEMS_CPU@/page.rel
 libbsp_a_LIBADD += mailto:../../../libcpu/@RTEMS_CPU@/score.rel
@@ -246,6 +259,7 @@ if HAS_NETWORKING
 libbsp_a_LIBADD += ne2000.rel
 libbsp_a_LIBADD += wd8003.rel
 libbsp_a_LIBADD += 3c509.rel
+libbsp_a_LIBADD += vtnet.rel
 endif
 EXTRA_DIST += HOWTO
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/if_vtnet.c
b/c/src/lib/libbsp/i386/pc386/virtio/if_vtnet.c
new file mode 100644
index 0000000..4fcd92c
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/if_vtnet.c
@@ -0,0 +1,1032 @@
+ * @file if_vtnet.c
+ * @brief Driver for virtio network devices
+ * Copyright (c) 2016 Jin-Hyun Kim <mailto:jinhyun at konkuk.ac.kr>
+ *   and Hyun-Wook Jin <mailto:jinh at konkuk.ac.kr>
+ * Ported from FreeBSD to RTEMS March 16, http://sslab.konkuk.ac.kr
+ * Copyright (c) 2011, Bryan Venteicher <mailto:bryanv at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ *    notice unmodified, this list of conditions, and the following
+ *    disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <rtems.h>
+#include <rtems/rtems_bsdnet.h>
+#include <bsp.h>
+#include <bsp/irq.h>
+#include <sys/mbuf.h>
+#include <sys/param.h>
+#include <sys/socket.h>
+#include <sys/sockio.h>
+#include <sys/systm.h>
+#include <net/if.h>
+#include <netinet/in.h>
+#include <netinet/if_ether.h>
+#include <pcibios.h>
+#include "virtio.h"
+#include "virtio_pci.h"
+#include "if_vtnet.h"
+static struct vtnet_softc vtnet_softc;
+static rtems_interval     vtnet_ticksPerSecond;
+int rtems_vtnet_driver_attach(
+  struct rtems_bsdnet_ifconfig *config,
+  int                           attaching
+  struct vtnet_softc *sc;
+  int                 ret;
+  printk( "rtems_vtnet_driver_attach start\n" );
+  sc = &vtnet_softc;
+  memset( sc, 0, sizeof( struct vtnet_softc ) );
+  /* Set up timing values */
+  vtnet_ticksPerSecond = rtems_clock_get_ticks_per_second();
+  printk( "\tAttaching virtio pci...\n" );
+  ret = vtpci_attach( config, &sc->vtpci_softc );
+  if ( ret ) {
+    printk( "vtpci_attach fail...\n" );
+  /* Alloc virtqueues */
+  printk( "\tAllocating virtqueues...\n" );
+  ret = vtnet_alloc_virtqueues( sc );
+  if ( ret ) {
+    printk( "vtnet_alloc_virtqueues fail...\n" );
+  /* Setup interrupt */
+  printk( "\tSetup interrupt...\n" );
+  ret = vtnet_setup_intr( &sc->vtpci_softc );
+  if ( ret ) {
+    printk( "vtpci_setup_intr fail...\n" );
+  /* Setup interface */
+  printk( "\tSetup interface...\n" );
+  ret = vtnet_setup_interface( sc, config );
+  if ( ret ) {
+    printk( "vtnet_setup_interface fail...\n" );
+  printk( "rtems_vtnet_driver_attach end\n" );
+  return 0;
+static int vtnet_alloc_virtqueues( struct vtnet_softc *sc )
+  uint16_t val16;
+  int      size, error;
+  /* Init virtio_net_hdr */
+  memset( &sc->vtnet_net_hdr, 0, sizeof( struct virtio_net_hdr ) );
+  /* Select virtqueue 0 */
+  vtpci_io_write_2( &sc->vtpci_softc,
+    VIRTIO_PCI_QUEUE_SEL,
+    VIRTIO_PCI_QUEUE_SEL_RX );
+  val16 = vtpci_io_read_2( &sc->vtpci_softc, VIRTIO_PCI_QUEUE_NUM );
+  /* Alloc memory & continuous memory for vring */
+  sc->vtnet_rxvq_size = val16;
+  size = sizeof( struct virtqueue ) + val16 * sizeof( struct vq_desc_extra
+  sc->vtnet_rxvq = malloc( size, M_DEVBUF, M_NOWAIT );
+  memset( sc->vtnet_rxvq, 0, size );
+  error =
+    vtnet_alloc_virtqueue( sc->vtnet_rxvq, VIRTIO_PCI_QUEUE_SEL_RX, val16
+  if ( error ) {
+    return error;
+  /* Select virtqueue 1 */
+    VIRTIO_PCI_QUEUE_SEL_TX );
+  sc->vtnet_txvq_size = val16;
+  sc->vtnet_txvq = malloc( size, M_DEVBUF, M_NOWAIT );
+  memset( sc->vtnet_txvq, 0, size );
+  error =
+    vtnet_alloc_virtqueue( sc->vtnet_txvq, VIRTIO_PCI_QUEUE_SEL_TX, val16
+  if ( error ) {
+    return error;
+  return 0;
+static int vtnet_alloc_virtqueue(
+  struct virtqueue *vq,
+  uint16_t          queue_num,
+  uint16_t          queue_size
+  unsigned long align;
+  void         *mem;
+  int           size;
+  vq->vq_queue_index = queue_num;
+  vq->vq_alignment = VIRTIO_PCI_VRING_ALIGN;
+  vq->vq_nentries = queue_size;
+  vq->vq_free_cnt = queue_size;
+  vq->vq_max_indirect_size = VTNET_RX_MIN_SEGS;
+  align = vq->vq_alignment;
+  size = queue_size * sizeof( struct vring_desc );
+  size += sizeof( struct vring_avail ) + ( queue_size * sizeof( uint16_t )
+          sizeof( uint16_t );
+  size = ( size + align - 1 ) & ~( vq->vq_alignment - 1 );
+  size += sizeof( struct vring_used ) +
+          ( queue_size * sizeof( struct vring_used_elem ) ) +
+  mem = (void *) malloc( size + align, M_DEVBUF, M_NOWAIT );
+  if ( ( (unsigned long) mem % align ) > 0 ) {
+    mem =
+      (void *) ( (unsigned long) mem +
+                 ( align - ( (unsigned long) mem % align ) ) );
+  vq->vq_ring_size = size;
+  vq->vq_ring_mem = mem;
+  memset( vq->vq_ring_mem, 0, size );
+  virtqueue_disable_intr( vq );
+  return 0;
+int vtnet_setup_intr( struct vtpci_softc *sc )
+  uint8_t val8;
+  int     ret;
+  /* Get intrrupt level */
+  pcib_conf_read8( sc->pci_signature, PCI_INTERRUPT_LINE, &val8 );
+  ret = rtems_interrupt_handler_install(
+    val8,
+    NULL,
+    RTEMS_INTERRUPT_SHARED,
+    (rtems_interrupt_handler) vtnet_intr,
+    NULL );
+  return ret;
+static int vtnet_setup_interface(
+  struct vtnet_softc           *sc,
+  struct ifnet *ifp;
+  int           mtu;
+  ifp = &sc->arpcom.ac_if;
+  ifp->if_softc = (void *) &vtnet_softc;
+  if ( config->mtu ) {
+    mtu = config->mtu;
+  } else {
+    mtu = ETHERMTU;
+  sc->arpcom.ac_enaddr[ 0 ] = 0x08;
+  sc->arpcom.ac_enaddr[ 1 ] = 0x00;
+  sc->arpcom.ac_enaddr[ 2 ] = 0x27;
+  sc->arpcom.ac_enaddr[ 3 ] = 0x98;
+  sc->arpcom.ac_enaddr[ 4 ] = 0xe7;
+  sc->arpcom.ac_enaddr[ 5 ] = 0x0f;
+  ifp->if_softc = sc;
+  ifp->if_unit = sc->vtpci_softc.unit_number;
+  ifp->if_name = sc->vtpci_softc.unit_name;
+  ifp->if_mtu = mtu;
+  ifp->if_init = vtnet_init;
+  ifp->if_ioctl = vtnet_ioctl;
+  ifp->if_start = vtnet_start;
+  ifp->if_output = ether_output;
+  ifp->if_flags = IFF_BROADCAST | IFF_SIMPLEX;
+  ifp->if_snd.ifq_maxlen = IFQ_MAXLEN;
+  if_attach( ifp );
+  ether_ifattach( ifp );
+  return 0;
+static void vtnet_init( void *xsc )
+  rtems_interrupt_level level;
+  struct mbuf          *m;
+  uint32_t              val32;
+  uint16_t              val16;
+  uint8_t               val8;
+  int                   last;
+  sc = xsc;
+  rtems_interrupt_disable( level );
+  if ( ifp->if_flags & IFF_RUNNING ) {
+    return;
+  printk( "vtnet_init start\n" );
+  /* vtnet_stop */
+  ifp->if_flags &= ~IFF_RUNNING;
+  sc->vtnet_link_active = 0;
+  vtnet_callout_stop( sc );
+  /* vtnet_disable_interrupts */
+  virtqueue_disable_intr( sc->vtnet_rxvq );
+  virtqueue_disable_intr( sc->vtnet_txvq );
+  /* vtpci_stop */
+  vtpci_io_write_1( &sc->vtpci_softc,
+    VIRTIO_PCI_STATUS,
+    VIRTIO_CONFIG_STATUS_RESET );
+  /* vtnet_drain_rxtx_queues */
+  last = 0;
+  while ( ( m = virtqueue_drain( sc->vtnet_rxvq, &last ) ) != NULL ) {
+    m_freem( m );
+  last = 0;
+  while ( ( m = virtqueue_drain( sc->vtnet_txvq, &last ) ) != NULL ) {
+    m_freem( m );
+  /* vtpci_reinit */
+  val8 = vtpci_io_read_1( &sc->vtpci_softc, VIRTIO_PCI_STATUS );
+  if ( val8 != VIRTIO_CONFIG_STATUS_RESET ) {
+    /* vtpci_stop */
+  /* Set status bit as acknowlege & driver */
+  val8 |= VIRTIO_CONFIG_STATUS_ACK;
+  vtpci_io_write_1( &sc->vtpci_softc, VIRTIO_PCI_STATUS, val8 );
+  val8 |= VIRTIO_CONFIG_STATUS_DRIVER;
+  vtnet_negotiate_features( sc );
+  /* vtpci_init_virtqueue */
+  vtnet_init_virtqueue( sc, sc->vtnet_rxvq );
+  vtnet_init_virtqueue( sc, sc->vtnet_txvq );
+  if ( !val16 || vtpci_io_read_4( &sc->vtpci_softc, VIRTIO_PCI_QUEUE_PFN )
+    printk( "\tRXQ already exists!\n" );
+  vtpci_io_write_4( &sc->vtpci_softc, VIRTIO_PCI_QUEUE_PFN,
+    ( (uint32_t) sc->vtnet_rxvq->vq_ring_mem >>
+      VIRTIO_PCI_QUEUE_ADDR_SHIFT ) );
+    printk( "\tTXQ already exists!\n" );
+    ( (uint32_t) sc->vtnet_txvq->vq_ring_mem >>
+  /* vtnet_init_rx_queues */
+  sc->vtnet_rx_clsize = MCLBYTES;
+  vtnet_rxq_populate( sc );
+  /* vtnet_init_tx_queues */
+  sc->vtnet_tx_watchdog = 0;
+  vq_ring_enable_interrupt( sc->vtnet_rxvq, 0 );
+  vq_ring_enable_interrupt( sc->vtnet_txvq, 0 );
+  ifp->if_flags |= IFF_RUNNING;
+  /* virtio_reinit_complete */
+  val8 |= VIRTIO_CONFIG_STATUS_DRIVER_OK;
+  /* vtnet_update_link_status; */
+  sc->vtnet_link_active = 1;
+  /* start vtnet_daemon */
+  if ( sc->daemonTid == 0 ) {
+    sc->daemonTid = rtems_bsdnet_newproc( "VTNd",
+      VTNET_DAEMON_STKSIZE,
+      vtnet_daemon,
+      sc );
+  /* start vtnet_tick */
+  sc->stat_ch = vtnet_timeout_running;
+  /* TODO: timeout routine is not working */
+  /* timeout(vtnet_tick, sc, hz); */
+  printk( "vtnet_init end\n" );
+  rtems_interrupt_enable( level );
+static int vtnet_rxq_eof( struct vtnet_softc *sc )
+  struct virtqueue    *vq;
+  struct mbuf         *m;
+  struct ether_header *eh;
+  uint32_t             len;
+  int                  deq, count;
+  vq = sc->vtnet_rxvq;
+  len = 0;
+  deq = 0;
+  count = VTNET_RX_PROCESS_LIMIT;
+  while ( count-- > 0 ) {
+    m = virtqueue_dequeue( vq, &len );
+    if ( m == NULL ) {
+      break;
+    deq++;
+    if ( len < sc->vtnet_hdr_size ) {
+      vtnet_rxq_enqueue( sc, m );
+      continue;
+    if ( vtnet_rxq_replace( sc, m, len ) != 0 ) {
+      continue;
+    m->m_pkthdr.len = len;
+    m->m_pkthdr.rcvif = ifp;
+    m_adj( m, sizeof( struct virtio_net_hdr ) );
+    /* vtnet_rxq_input */
+    eh = mtod( m, struct ether_header * );
+    m_adj( m, sizeof( struct ether_header ) );
+    m->m_pkthdr.len = m->m_len;
+    ether_input( ifp, eh, m );
+    if ( ( ifp->if_flags & IFF_RUNNING ) == 0 ) {
+      break;
+  if ( deq > 0 ) {
+    vtpci_notify( &sc->vtpci_softc, vq );
+  return ( count > 0 ? 0 : EAGAIN );
+static int vtnet_rxq_enqueue(
+  struct mbuf        *m_head
+  struct vring_desc    *desc, *dp;
+  struct vq_desc_extra *dxp;
+  struct mbuf          *m;
+  uint16_t              head_idx, idx;
+  uint8_t               segs;
+  desc = vq->vq_ring.desc;
+  if ( vq->vq_free_cnt == 0 ) {
+    return ENOSPC;
+  segs = 0;
+  for ( m = m_head; m != NULL; m = m->m_next ) {
+    segs++;
+  if ( segs == 0 ) {
+    return EINVAL;
+  if ( vq->vq_free_cnt < segs ) {
+    return EMSGSIZE;
+  head_idx = vq->vq_desc_head_idx;
+  dxp = &vq->vq_descx[ head_idx ];
+  dxp->cookie = m_head;
+  dxp->ndescs = segs;
+  for ( m = m_head, idx = head_idx; m != NULL;
+        m = m->m_next, idx = dp->next ) {
+    dp = &desc[ idx ];
+    dp->addr = (uint32_t) m->m_data;
+    dp->len = m->m_len;
+    dp->flags = VRING_DESC_F_NEXT | VRING_DESC_F_WRITE;
+  dp->flags &= ~( VRING_DESC_F_NEXT );
+  vq->vq_desc_head_idx = idx;
+  vq->vq_free_cnt -= segs;
+  vq_ring_update_avail( vq, head_idx );
+  return 0;
+static int vtnet_rxq_replace(
+  struct mbuf        *m,
+  int                 len
+  struct mbuf *m_new;
+  int          error;
+  if ( m->m_next == NULL ) {
+    if ( m->m_len < len ) {
+      return EINVAL;
+    m_new = vtnet_rxq_alloc_mbuf( sc, 1, NULL );
+    if ( m_new == NULL ) {
+      return ENOBUFS;
+    error = vtnet_rxq_enqueue( sc, m_new );
+    if ( error ) {
+      m_freem( m_new );
+    } else {
+      m->m_len = len;
+  } else {
+    error = vtnet_rxq_replace_nomgr( sc, m, len );
+  return error;
+static struct mbuf *vtnet_rxq_alloc_mbuf(
+  int                 nbufs,
+  struct mbuf       **m_tailp
+  struct mbuf *m_head, *m_tail, *m;
+  int          i;
+  MGETHDR( m_head, M_DONTWAIT, MT_DATA );
+  if ( m_head == NULL ) {
+    m_freem( m_head );
+    return NULL;
+  MCLGET( m_head, M_DONTWAIT );
+  if ( ( m_head->m_flags & M_EXT ) == 0 ) {
+    return NULL;
+  m_head->m_len = sc->vtnet_rx_clsize;
+  m_tail = m_head;
+  for ( i = 1; i < nbufs; i++ ) {
+    MGETHDR( m, M_DONTWAIT, MT_DATA );
+      return NULL;
+    MCLGET( m, M_DONTWAIT );
+    if ( ( m->m_flags & M_EXT ) == 0 ) {
+      m_freem( m );
+      return NULL;
+    m->m_len = sc->vtnet_rx_clsize;
+    m_tail->m_next = m;
+    m_tail = m;
+  if ( m_tailp != NULL ) {
+    *m_tailp = m_tail;
+  return m_head;
+static int vtnet_rxq_replace_nomgr(
+  struct mbuf        *m0,
+  int                 len0
+  struct mbuf *m, *m_prev, *m_new, *m_tail;
+  int          len, clsize, nreplace, error;
+  clsize = sc->vtnet_rx_clsize;
+  m_prev = NULL;
+  m_tail = NULL;
+  nreplace = 0;
+  m = m0;
+  len = len0;
+  while ( len > 0 ) {
+      return EMSGSIZE;
+    m->m_len = ( m->m_len > len ) ? len : m->m_len;
+    len -= m->m_len;
+    m_prev = m;
+    m = m->m_next;
+    nreplace++;
+  m_new = vtnet_rxq_alloc_mbuf( sc, nreplace, &m_tail );
+    m_prev->m_len = clsize;
+    return ENOBUFS;
+  if ( m_prev->m_next != NULL ) {
+    m_tail->m_next = m_prev->m_next;
+    m_prev->m_next = NULL;
+  if ( error ) {
+    if ( m_tail->m_next != NULL ) {
+      m_prev->m_next = m_tail->m_next;
+      m_tail->m_next = NULL;
+    m_freem( m_new );
+  return error;
+static void vtnet_start( struct ifnet *ifp )
+  struct mbuf          *m;
+  int                   enq, error;
+  vq = sc->vtnet_txvq;
+  enq = 0;
+  if ( ( ifp->if_flags & IFF_RUNNING ) == 0 || sc->vtnet_link_active == 0 )
+    return;
+  vtnet_txq_eof( sc );
+  while ( ifp->if_snd.ifq_head != NULL ) {
+    IF_DEQUEUE( &ifp->if_snd, m );
+      break;
+    if ( ( error = vtnet_txq_enqueue( sc, m ) ) != 0 ) {
+      if ( m != NULL ) {
+        IF_PREPEND( &ifp->if_snd, m );
+      break;
+    enq++;
+  if ( enq > 0 ) {
+    sc->vtnet_tx_watchdog = VTNET_TX_TIMEOUT;
+static void vtnet_txq_eof( struct vtnet_softc *sc )
+  struct mbuf      *m;
+  while ( ( m = virtqueue_dequeue( vq, NULL ) ) != NULL ) {
+    m_freem( m );
+  if ( vq->vq_nentries == vq->vq_free_cnt ) {
+static int vtnet_txq_enqueue(
+  struct mbuf          *m;
+  uint16_t              head_idx;
+  uint8_t               segs;
+    return ENOSPC;
+  segs = 1;
+    segs++;
+  if ( segs == 1 ) {
+    return EINVAL;
+    return EMSGSIZE;
+  /* First desc of chain must be vtnet tx hdr */
+  dp = &desc[ head_idx ];
+  dp->addr = (uint32_t) &sc->vtnet_net_hdr;
+  dp->len = sizeof( struct virtio_net_hdr );
+  dp->flags |= VRING_DESC_F_NEXT;
+  /* Link rest mbuf to chain */
+    dp = &desc[ dp->next ];
+    dp->addr = mtod( m, uint32_t );
+  vq->vq_desc_head_idx = dp->next;
+  return 0;
+static void vtnet_negotiate_features( struct vtnet_softc *sc )
+  uint32_t host_features;
+  uint32_t guest_features;
+  host_features =
+    vtpci_io_read_4( &sc->vtpci_softc, VIRTIO_PCI_HOST_FEATURES );
+  guest_features = host_features & 0xfffff;
+  guest_features &= VTNET_FEATURES;
+  vtpci_io_write_4( &sc->vtpci_softc, VIRTIO_PCI_GUEST_FEATURES,
+    guest_features );
+  guest_features =
+    vtpci_io_read_4( &sc->vtpci_softc, VIRTIO_PCI_GUEST_FEATURES );
+  printk( "\tHost_features:\t0x%08x\n", host_features );
+  printk( "\tGuest_features:\t0x%08x\n", guest_features );
+  sc->vtnet_hdr_size = sizeof( struct virtio_net_hdr ) + ETHER_HDR_LEN;
+static void vtnet_callout_stop( struct vtnet_softc *sc )
+  if ( sc->stat_ch == vtnet_timeout_running ) {
+    sc->stat_ch = vtnet_timeout_stop_rq;
+    while ( sc->stat_ch != vtnet_timeout_stopped ) {
+      rtems_bsdnet_semaphore_release();
+      rtems_task_wake_after( vtnet_ticksPerSecond );
+      rtems_bsdnet_semaphore_obtain();
+static void vtnet_callout_reset( struct vtnet_softc *sc )
+    timeout( vtnet_tick, sc, hz );
+  } else if ( sc->stat_ch == vtnet_timeout_stop_rq ) {
+    sc->stat_ch = vtnet_timeout_stopped;
+static int vtnet_init_virtqueue(
+  int                   i;
+  vq->vq_desc_head_idx = 0;
+  vq->vq_used_cons_idx = 0;
+  vq->vq_queued_cnt = 0;
+  vq->vq_free_cnt = vq->vq_nentries;
+  memset( vq->vq_ring_mem, 0, vq->vq_ring_size );
+  for ( i = 0; i < vq->vq_nentries; i++ ) {
+    dxp = &vq->vq_descx[ i ];
+    dxp->cookie = NULL;
+    dxp->ndescs = 0;
+    dxp->indirect = NULL;
+  vq_ring_init( vq );
+  return 0;
+static int vtnet_rxq_populate( struct vtnet_softc *sc )
+  struct virtqueue *rxvq;
+  struct mbuf      *m;
+  int               nbufs, error;
+  rxvq = sc->vtnet_rxvq;
+  for ( nbufs = 0; rxvq->vq_free_cnt; nbufs++ ) {
+    m = vtnet_rxq_alloc_mbuf( sc, 1, NULL );
+      return ENOBUFS;
+    error = vtnet_rxq_enqueue( sc, m );
+    if ( error ) {
+      m_freem( m );
+  if ( nbufs > 0 ) {
+    vtpci_notify( &sc->vtpci_softc, rxvq );
+    if ( error == EMSGSIZE ) {
+      error = 0;
+  return error;
+static int vtnet_ioctl(
+  struct ifnet   *ifp,
+  ioctl_command_t cmd,
+  caddr_t         data
+  int error;
+  error = 0;
+  switch ( cmd ) {
+    case SIOCSIFMTU:
+      /* TODO: vtnet_change_mtu */
+      break;
+    case SIOCSIFFLAGS:
+      vtnet_init( ifp->if_softc );
+      break;
+    case SIOCADDMULTI:
+    case SIOCDELMULTI:
+      /* TODO: vtnet_rx_filter_mac */
+      break;
+    default:
+      error = ether_ioctl( ifp, cmd, data );
+      break;
+  return error;
+static void vtnet_tick( void *xsc )
+  int                 timedout;
+  timedout = vtnet_watchdog( sc );
+  if ( timedout != 0 ) {
+    vtnet_init( sc );
+  } else {
+    vtnet_callout_reset( sc );
+static int vtnet_watchdog( struct vtnet_softc *sc )
+  if ( sc->vtnet_tx_watchdog == 0 || --sc->vtnet_tx_watchdog ) {
+    return 0;
+  return 1;
+static rtems_isr vtnet_intr( rtems_vector_number v )
+  uint8_t             isr;
+  isr = vtpci_io_read_1( &sc->vtpci_softc, VIRTIO_PCI_ISR );
+  if ( isr & VIRTIO_PCI_ISR_INTR ) {
+      return;
+    rtems_bsdnet_event_send( sc->daemonTid, RTEMS_EVENT_1 );
+  } else if ( isr & VIRTIO_PCI_ISR_CONFIG ) {
+     * TODO: Handling of config interrupt
+static void vtnet_daemon( void *xsc )
+  struct virtqueue   *txvq;
+  int                 more, tries;
+  rtems_event_set     events;
+  txvq = sc->vtnet_txvq;
+  while ( 1 ) {
+    rtems_bsdnet_event_receive( RTEMS_EVENT_1,
+      RTEMS_WAIT | RTEMS_EVENT_ANY,
+      RTEMS_NO_TIMEOUT,
+      &events );
+    /* tx intr */
+    tries = 0;
+againtx:
+    if ( ifp->if_snd.ifq_head != NULL ) {
+      vtnet_start( ifp );
+    if ( virtqueue_postpone_intr( txvq, VQ_POSTPONE_LONG ) != 0 ) {
+      virtqueue_disable_intr( txvq );
+      if ( tries++ < VTNET_INTR_DISABLE_RETRIES ) {
+        goto againtx;
+    /* rx intr */
+    tries = 0;
+againrx:
+    more = vtnet_rxq_eof( sc );
+    if ( more || vq_ring_enable_interrupt( rxvq, 0 ) != 0 ) {
+      if ( !more ) {
+        virtqueue_disable_intr( rxvq );
+        goto againrx;
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/if_vtnet.h
b/c/src/lib/libbsp/i386/pc386/virtio/if_vtnet.h
index 0000000..7f81bad
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/if_vtnet.h
@@ -0,0 +1,181 @@
+ * @file if_vtnet.h
+ * @brief Header for if_vtnet.c
+ * This header is BSD licensed so anyone can use the definitions to
implement
+ * compatible drivers/servers.
+ * are met:
+ * 3. Neither the name of IBM nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED
+ * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
PARTICULAR
+ * PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL IBM OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/network/virtio_net.h 255111
2013-09-01 04:23:54Z bryanv $
+#ifndef _IF_VTNET_H_
+#define _IF_VTNET_H_
+/* The feature bitmap for virtio net */
+#define VIRTIO_NET_F_CSUM 0x00001       /* Host handles pkts w/ partial
csum */
+#define VIRTIO_NET_F_GUEST_CSUM 0x00002 /* Guest handles pkts w/ partial
csum*/
+#define VIRTIO_NET_F_MAC 0x00020        /* Host has given MAC address. */
+#define VIRTIO_NET_F_GSO 0x00040        /* Host handles pkts w/ any GSO
type */
+#define VIRTIO_NET_F_GUEST_TSO4 0x00080 /* Guest can handle TSOv4 in. */
+#define VIRTIO_NET_F_GUEST_TSO6 0x00100 /* Guest can handle TSOv6 in. */
+#define VIRTIO_NET_F_GUEST_ECN 0x00200  /* Guest can handle TSO[6] w/ ECN
in.*/
+#define VIRTIO_NET_F_GUEST_UFO 0x00400  /* Guest can handle UFO in. */
+#define VIRTIO_NET_F_HOST_TSO4 0x00800  /* Host can handle TSOv4 in. */
+#define VIRTIO_NET_F_HOST_TSO6 0x01000  /* Host can handle TSOv6 in. */
+#define VIRTIO_NET_F_HOST_ECN 0x02000   /* Host can handle TSO[6] w/ ECN
in. */
+#define VIRTIO_NET_F_HOST_UFO 0x04000   /* Host can handle UFO in. */
+#define VIRTIO_NET_F_MRG_RXBUF 0x08000  /* Host can merge receive buffers.
+#define VIRTIO_NET_F_STATUS 0x10000     /* virtio_net_config.status
available*/
+#define VIRTIO_NET_F_CTRL_VQ 0x20000    /* Control channel available */
+#define VIRTIO_NET_F_CTRL_RX 0x40000    /* Control channel RX mode support
+#define VIRTIO_NET_F_CTRL_VLAN 0x80000  /* Control channel VLAN filtering
+#define VTNET_FEATURES \
+  ( VIRTIO_NET_F_CSUM | \
+    VIRTIO_NET_F_MAC | \
+    VIRTIO_NET_F_GSO | \
+    VIRTIO_NET_F_HOST_TSO4 | \
+    VIRTIO_NET_F_HOST_TSO6 | \
+    VIRTIO_NET_F_HOST_ECN | \
+    VIRTIO_NET_F_HOST_UFO )
+#define VTNET_RX_MIN_SEGS 2
+#define VTNET_RX_PROCESS_LIMIT 512
+#define VTNET_TX_TIMEOUT 5
+#define VTNET_INTR_DISABLE_RETRIES 4
+#define VTNET_DAEMON_STKSIZE 4096
+struct virtio_net_hdr {
+  uint8_t flags;
+  uint8_t gso_type;
+  uint16_t hdr_len;
+  uint16_t gso_size;
+  uint16_t csum_start;
+  uint16_t csum_offset;
+struct vtnet_tx_header {
+  struct virtio_net_hdr hdr;
+  struct mbuf *vth_mbuf;
+struct vtnet_softc {
+  struct arpcom arpcom;
+  struct vtpci_softc vtpci_softc;
+  struct virtqueue *vtnet_rxvq;
+  struct virtqueue *vtnet_txvq;
+  rtems_id daemonTid;
+  struct virtio_net_hdr vtnet_net_hdr;
+  int vtnet_rxvq_size;
+  int vtnet_txvq_size;
+  int vtnet_link_active;
+  int vtnet_hdr_size;
+  int vtnet_rx_clsize;
+  int vtnet_tx_watchdog;
+  enum { vtnet_timeout_stopped, vtnet_timeout_running,
vtnet_timeout_stop_rq }
+  stat_ch;
+static int vtnet_alloc_virtqueues( struct vtnet_softc *sc );
+  uint16_t          num,
+static void vtnet_init( void *xsc );
+static void vtnet_negotiate_features( struct vtnet_softc *sc );
+static void vtnet_start( struct ifnet *ifp );
+  caddr_t         data
+static int vtnet_setup_intr( struct vtpci_softc *sc );
+static rtems_isr vtnet_intr( rtems_vector_number v );
+static void vtnet_daemon( void *xsc );
+static void vtnet_tick( void *xsc );
+static int vtnet_watchdog( struct vtnet_softc *sc );
+static void vtnet_callout_stop( struct vtnet_softc *sc );
+static void vtnet_callout_reset( struct vtnet_softc *sc );
+static int vtnet_rxq_populate( struct vtnet_softc *sc );
+static int vtnet_rxq_eof( struct vtnet_softc *sc );
+  struct mbuf        *m,
+  int                 len
+  int                 nbufs,
+  struct mbuf        *m0,
+  int                 len0
+static void vtnet_txq_eof( struct vtnet_softc *sc );
+#endif /* _IF_VTNET_H_ */
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtio.c
b/c/src/lib/libbsp/i386/pc386/virtio/virtio.c
index 0000000..85251fa
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtio.c
@@ -0,0 +1,220 @@
+ * @file virtio.c
+ * @brief Functions for virtqueue, vring
+ * are met:
+ *    disclaimer.
WARRANTIES
USE,
+#include <rtems.h>
+void *virtqueue_dequeue(
+  uint32_t         *len
+  struct vring_used_elem *uep;
+  void                   *cookie;
+  uint16_t                used_idx, desc_idx;
+  if ( vq->vq_used_cons_idx == vq->vq_ring.used->idx ) {
+    return NULL;
+  used_idx = vq->vq_used_cons_idx++ & ( vq->vq_nentries - 1 );
+  uep = &vq->vq_ring.used->ring[ used_idx ];
+  rmb();
+  desc_idx = (uint16_t) uep->id;
+  if ( len != NULL ) {
+    *len = uep->len;
+  vq_ring_free_chain( vq, desc_idx );
+  cookie = vq->vq_descx[ desc_idx ].cookie;
+  vq->vq_descx[ desc_idx ].cookie = NULL;
+  return cookie;
+void *virtqueue_drain(
+  int              *last
+  void *cookie;
+  int   idx;
+  cookie = NULL;
+  idx = *last;
+  while ( idx < vq->vq_nentries && cookie == NULL ) {
+    if ( ( cookie = vq->vq_descx[ idx ].cookie ) != NULL ) {
+      vq->vq_descx[ idx ].cookie = NULL;
+      vq_ring_free_chain( vq, idx );
+    idx++;
+  *last = idx;
+  return cookie;
+void virtqueue_disable_intr( struct virtqueue *vq )
+  vq->vq_ring.avail->flags |= VRING_AVAIL_F_NO_INTERRUPT;
+int virtqueue_postpone_intr(
+  vq_postpone_t     hint
+  uint16_t ndesc, avail_idx;
+  avail_idx = vq->vq_ring.avail->idx;
+  ndesc = (uint16_t) ( avail_idx - vq->vq_used_cons_idx );
+  switch ( hint ) {
+    case VQ_POSTPONE_SHORT:
+      ndesc = ndesc / 4;
+      break;
+    case VQ_POSTPONE_LONG:
+      ndesc = ( ndesc * 3 ) / 4;
+      break;
+    case VQ_POSTPONE_EMPTIED:
+      break;
+  return vq_ring_enable_interrupt( vq, ndesc );
+void vq_ring_init( struct virtqueue *vq )
+  struct vring *vr;
+  uint8_t      *ring_mem;
+  int           i, size;
+  ring_mem = vq->vq_ring_mem;
+  size = vq->vq_nentries;
+  vr = &vq->vq_ring;
+  vr->num = size;
+  vr->desc = (struct vring_desc *) ring_mem;
+  vr->avail =
+    (struct vring_avail *) ( ring_mem + size * sizeof( struct vring_desc )
+  vr->used = (void *)
+             ( ( (unsigned long) &vr->avail->ring[ size ] +
vq->vq_alignment -
+                 1 ) & ~( vq->vq_alignment - 1 ) );
+  for ( i = 0; i < size - 1; i++ ) {
+    vr->desc[ i ].next = i + 1;
+  vr->desc[ i ].next = VQ_RING_DESC_CHAIN_END;
+void vq_ring_free_chain(
+  uint16_t          desc_idx
+  struct vring_desc    *dp;
+  dp = &vq->vq_ring.desc[ desc_idx ];
+  dxp = &vq->vq_descx[ desc_idx ];
+  vq->vq_free_cnt += dxp->ndescs;
+  dxp->ndescs--;
+  while ( dp->flags & VRING_DESC_F_NEXT ) {
+    dp = &vq->vq_ring.desc[ dp->next ];
+    dxp->ndescs--;
+  dp->next = vq->vq_desc_head_idx;
+  vq->vq_desc_head_idx = desc_idx;
+void vq_ring_update_avail(
+  uint16_t          desc_idx
+  uint16_t avail_idx;
+  avail_idx = vq->vq_ring.avail->idx & ( vq->vq_nentries - 1 );
+  vq->vq_ring.avail->ring[ avail_idx ] = desc_idx;
+  wmb();
+  vq->vq_ring.avail->idx++;
+  vq->vq_queued_cnt++;
+int vq_ring_must_notify_host( struct virtqueue *vq )
+  return ( ( vq->vq_ring.used->flags & VRING_USED_F_NO_NOTIFY ) == 0 );
+int vq_ring_enable_interrupt(
+  uint16_t          ndesc
+  uint16_t used_idx, nused;
+  vq->vq_ring.avail->flags &= ~VRING_AVAIL_F_NO_INTERRUPT;
+  mb();
+  used_idx = vq->vq_ring.used->idx;
+  nused = (uint16_t) ( used_idx - vq->vq_used_cons_idx );
+  if ( nused > ndesc ) {
+    return 1;
+  return 0;
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtio.h
b/c/src/lib/libbsp/i386/pc386/virtio/virtio.h
index 0000000..47a61e8
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtio.h
@@ -0,0 +1,167 @@
+ * @file virtio.h
+ * @brief Header for virtio.c
implement
+ * are met:
LIMITED
PARTICULAR
CONSEQUENTIAL
STRICT
WAY
+ * SUCH DAMAGE.
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/virtio.h 252708 2013-07-04
17:59:09Z bryanv $
+#ifndef _VIRTIO_H_
+#define _VIRTIO_H_
+#define mb() asm volatile ( "lock; addl $0,0(%%esp) " ::: "memory" );
+#define rmb() mb()
+#define wmb() asm volatile ( "lock; addl $0, (%%esp)" ::: "memory", "cc" )
+#define vring_used_event( vr ) ( ( vr )->avail->ring[ ( vr )->num ] )
+#define vring_avail_event( vr ) ( *(uint16_t *) &( vr )->used->ring[ ( vr
+        num ]
+#define vring_need_event( event_idx, new_idx, old ) \
+  ( (uint16_t) ( new_idx - event_idx - 1 ) < (uint16_t) ( new_idx - old ) )
+/* VirtIO PCI vendor/device ID. */
+#define VIRTIO_VENDOR_ID 0x1AF4
+#define VIRTIO_DEVICE_ID_MIN 0x1000
+#define VIRTIO_DEVICE_ID_MAX 0x1040
+#define VRING_DESC_F_NEXT 1
+#define VRING_DESC_F_WRITE 2
+#define VRING_DESC_F_INDIRECT 4
+#define VRING_USED_F_NO_NOTIFY 1
+#define VRING_AVAIL_F_NO_INTERRUPT 1
+#define VQ_RING_DESC_CHAIN_END 32768
+typedef enum {
+  VQ_POSTPONE_SHORT,
+  VQ_POSTPONE_LONG,
+  VQ_POSTPONE_EMPTIED
+} vq_postpone_t;
+struct vring_desc {
+  uint64_t addr;
+  uint32_t len;
+  uint16_t flags;
+  uint16_t next;
+struct vring_avail {
+  uint16_t flags;
+  uint16_t idx;
+  uint16_t ring[];
+struct vring_used_elem {
+  uint32_t id;
+  uint32_t len;
+struct vring_used {
+  uint16_t flags;
+  uint16_t idx;
+  struct vring_used_elem ring[];
+struct vring {
+  unsigned int num;
+  struct vring_desc *desc;
+  struct vring_avail *avail;
+  struct vring_used *used;
+struct vq_desc_extra {
+  void *cookie;
+  struct vring_desc *indirect;
+  uint32_t indirect_paddr;
+  uint16_t ndescs;
+struct virtqueue {
+  uint16_t vq_queue_index;
+  uint16_t vq_nentries;
+  uint32_t vq_flags;
+  uint16_t vq_free_cnt;
+  uint16_t vq_queued_cnt;
+  int vq_alignment;
+  int vq_ring_size;
+  struct vring vq_ring;
+  void *vq_ring_mem;
+  int vq_max_indirect_size;
+  int vq_indirect_mem_size;
+  uint16_t vq_desc_head_idx;
+  uint16_t vq_used_cons_idx;
+  struct vq_desc_extra vq_descx[ 0 ];
+  uint32_t         *len
+  int              *last
+void virtqueue_disable_intr( struct virtqueue *vq );
+void vq_ring_init( struct virtqueue *vq );
+  uint16_t          desc_idx
+  uint16_t          desc_idx
+int vq_ring_must_notify_host( struct virtqueue *vq );
+  uint16_t          ndesc
+#endif /* _VIRTIO_H_ */
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.c
b/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.c
index 0000000..8ba9365
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.c
@@ -0,0 +1,176 @@
+ * @file virtio_pci.c
+ * @brief Driver for the virtio PCI interface
+ * are met:
+ *    disclaimer.
WARRANTIES
USE,
+/* Driver for the VirtIO PCI interface. */
+#ifdef __i386__
+#include <rtems.h>
+#include <bsp.h>
+__inline uint8_t vtpci_io_read_1(
+  struct vtpci_softc *sc,
+  int                 reg
+  uint8_t val;
+  inport_byte( sc->pci_io_base + reg, val );
+  return val;
+__inline uint16_t vtpci_io_read_2(
+  int                 reg
+  uint16_t val;
+  inport_word( sc->pci_io_base + reg, val );
+  return val;
+__inline uint32_t vtpci_io_read_4(
+  int                 reg
+  uint32_t val;
+  inport_long( sc->pci_io_base + reg, val );
+  return val;
+__inline void vtpci_io_write_1(
+  int                 reg,
+  uint8_t             val
+  outport_byte( sc->pci_io_base + reg, val );
+__inline void vtpci_io_write_2(
+  int                 reg,
+  uint16_t            val
+  outport_word( sc->pci_io_base + reg, val );
+__inline void vtpci_io_write_4(
+  int                 reg,
+  uint32_t            val
+  outport_long( sc->pci_io_base + reg, val );
+int vtpci_attach(
+  int      i, ret;
+  uint8_t  val8;
+  uint16_t val16;
+  uint32_t val32;
+  /* Parse NIC_NAME & Init structures */
+  if ( ( sc->unit_number =
+           rtems_bsdnet_parse_driver_name( config, &sc->unit_name ) ) < 0 )
+    return 0;
+  /* Find device on pci bus */
+    int pbus, pdev, pfun;
+    for ( i = VIRTIO_DEVICE_ID_MIN; i < VIRTIO_DEVICE_ID_MAX; i++ ) {
+      ret = pci_find_device( VIRTIO_VENDOR_ID, i, sc->unit_number,
+        &pbus, &pdev, &pfun );
+      if ( ret == PCIB_ERR_SUCCESS ) {
+        sc->pci_signature = PCIB_DEVSIG_MAKE( pbus, pdev, pfun );
+        break;
+  /* Enable bus matering */
+  pcib_conf_read16( sc->pci_signature, PCI_COMMAND, &val16 );
+  val16 |= PCI_COMMAND_MASTER;
+  pcib_conf_write16( sc->pci_signature, PCI_COMMAND, val16 );
+  /* Set latency timer */
+  pcib_conf_read8( sc->pci_signature, PCI_LATENCY_TIMER, &val8 );
+  val8 |= 0x00;
+  pcib_conf_write8( sc->pci_signature, PCI_LATENCY_TIMER, val8 );
+  /* Get IO Address */
+  pcib_conf_read32( sc->pci_signature, PCI_BASE_ADDRESS_0, &val32 );
+  val32 &= PCI_BASE_ADDRESS_IO_MASK;
+  sc->pci_io_base = val32;
+  return 0;
+void vtpci_notify(
+  mb();
+  if ( vq_ring_must_notify_host( vq ) ) {
+    vtpci_io_write_2( sc, VIRTIO_PCI_QUEUE_NOTIFY, vq->vq_queue_index );
+#endif /* __i386__ */
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.h
b/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.h
index 0000000..7d0db9e
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.h
@@ -0,0 +1,131 @@
+ * @file virtio_pci.h
+ * @brief Header for virtio_pci.c
+ * Copyright IBM Corp. 2007
+ * Authors:
+ *  Anthony Liguori  <mailto:aliguori at us.ibm.com>
implement
+ * are met:
LIMITED
PARTICULAR
CONSEQUENTIAL
STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY `
+ * SUCH DAMAGE.
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/pci/virtio_pci.h 238360
2012-07-11 02:57:19Z grehan $
+#ifndef _VIRTIO_PCI_H_
+#define _VIRTIO_PCI_H_
+/* VirtIO Header, located in BAR 0. */
+#define VIRTIO_PCI_HOST_FEATURES 0   /* host's supported features (32bit,
RO)*/
+#define VIRTIO_PCI_GUEST_FEATURES 4  /* guest's supported features (32, RW)
+#define VIRTIO_PCI_QUEUE_PFN 8       /* physical address of VQ (32, RW) */
+#define VIRTIO_PCI_QUEUE_NUM 12      /* number of ring entries (16, RO) */
+#define VIRTIO_PCI_QUEUE_SEL 14      /* current VQ selection (16, RW) */
+#define VIRTIO_PCI_QUEUE_NOTIFY 16   /* notify host regarding VQ (16, RW)
+#define VIRTIO_PCI_STATUS 18         /* device status register (8, RW) */
+#define VIRTIO_PCI_ISR 19            /* interrupt status register, reading
+#define VIRTIO_MSI_CONFIG_VECTOR 20
+#define VIRTIO_MSI_QUEUE_VECTOR 22
+#define VIRTIO_PCI_QUEUE_SEL_RX 0
+#define VIRTIO_PCI_QUEUE_SEL_TX 1
+#define VIRTIO_PCI_ISR_INTR 0x1
+#define VIRTIO_PCI_ISR_CONFIG 0x2
+#define VIRTIO_MSI_NO_VECTOR 0xFFFF
+/* How many bits to shift physical queue address written to QUEUE_PFN */
+#define VIRTIO_PCI_QUEUE_ADDR_SHIFT 12
+/* The alignment to use between consumer and producer parts of vring */
+#define VIRTIO_PCI_VRING_ALIGN 4096
+/* Status byte for guest to report progress. */
+#define VIRTIO_CONFIG_STATUS_RESET 0x00
+#define VIRTIO_CONFIG_STATUS_ACK 0x01
+#define VIRTIO_CONFIG_STATUS_DRIVER 0x02
+#define VIRTIO_CONFIG_STATUS_DRIVER_OK 0x04
+#define VIRTIO_CONFIG_STATUS_FAILED 0x80
+struct vtpci_softc {
+  int unit_number;
+  char *unit_name;
+  int pci_signature;
+  uint32_t pci_io_base;
+  int                 reg
+  int                 reg
+  int                 reg
+  int                 reg,
+  uint8_t             val
+  int                 reg,
+  uint16_t            val
+  int                 reg,
+  uint32_t            val
+int vtpci_attach(
+void vtpci_notify(
+#endif /* _VIRTIO_PCI_H_ */
devel mailing list
mailto:devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
