Bringing the Scheduling Simulator in synch with RTEMS master
Darshit Shah
darnir at gmail.com
Fri Apr 1 14:13:43 UTC 2016
On 03/30, Joel Sherrill wrote:
>On Wed, Mar 30, 2016 at 9:03 AM, Darshit Shah <darnir at gmail.com> wrote:
>> I've started trying to bring the scheduling simulator in synch with the
>> current RTEMS master. Joel has created Trac Ticket #2679 (
>> https://devel.rtems.org/ticket/2679) for this task.
>> While trying to get the simulator to compile, GCC spits out the following
>> error:
>> In file included from
>> /home/thedoctor/Programming/rtems/rtems/cpukit/score/include/rtems/score/threadq.h:25:0,
>> from
>> /home/thedoctor/Programming/rtems/rtems/cpukit/score/include/rtems/score/thread.h:35,
>> from
>> /home/thedoctor/Programming/rtems/rtems/cpukit/score/include/rtems/score/heap.h:22,
>> from
>> /home/thedoctor/Programming/rtems/rtems/cpukit/rtems/include/rtems/rtems/types.h:26,
>> from
>> /home/thedoctor/Programming/rtems/rtems/cpukit/rtems/include/rtems/rtems/config.h:24,
>> from
>> /home/thedoctor/Programming/rtems/rtems/cpukit/sapi/include/rtems/config.h:57,
>> from
>> ../../../rtems-schedsim/schedsim/rtems/rtems_init.c:25:
>> /home/thedoctor/Programming/rtems/rtems/cpukit/score/include/rtems/score/rbtree.h:21:22:
>> fatal error: sys/tree.h: No such file or directory
>> Some scouting around reveals that the sys/tree.h header file is available
>> in Newlib. However, I am unable to find a way to point the compiler in that
>> direction for the scheduling simulator. Can someone please point me to the
>> right set of Automake directives I'd require for this?
>There are two alternatives for missing libc files like this.
>1) hope they really aren't needed and ifdef out the include. I suspect this
>won't work here.
That could work for a few cases, but in this case I doubt that'll help.
>2) put a copy in schedsim/rtems/sched_cpu/sys. Looks like I hit other
>issues like a missing
>cpuset.h method and had to add a stub sys/lock.h.
Is this the only solution we have? Because, I see a few new issues where
newlib now has a newer version of the BSD time.h file and the schedsim
fails to build without it. Currently, the only way is to copy all those
header files into schedsim/rtems/sched_cpu/sys. Would it possible to
extend schedsim to directly use newlib just like the RTEMS build does?
Then we won't need to copy all these files around and keep duplicate
copies.
>Add a section to the instructions in the ticket. I forgot about this case.
>Hopefully this isn't a bad thing to fix. Since you are layering BSD
>capabilities on top of
>glibc, it can be tricky to avoid naming conflicts.
>--joel
>> Thanking You,
>> Darshit Shah
>> devel mailing list
>> devel at rtems.org
Thanking You,
Darshit Shah
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160401/666c655a/attachment.bin>
