Building a rtems image
Sambeet Panigrahi
sambeet161616 at gmail.com
Mon Apr 4 04:23:24 UTC 2016
I have been trying to build a RTEMS image for GRUB2 following the
instructions from:
https://devel.rtems.org/wiki/Building/Grub
I have followed all instructions and placed the image and the directory
structure in /home/sambeet/SimulRTEMS, the tree command in the directory
gives
|-- examples
| `-- ticker.exe
|-- grub.cfg
|-- mkimage.sh
|-- qemu.sh
`-- rtems-boot.img
But when I do the following:
Holmes sambeet # ./qemu.sh
qemu-system-i386: -hda -hdb: Could not open '-hdb': No such file or
directory
I get the following output instead of Ticker.exe running and GRUB screen
appearing.
I have also followed the instructions from
http://jin-yang.github.io/blog/build-a-RTEMS-environment.html. There's the
same error there too.
I want to create and build a RTEMS image without using the usual
RTEMS-testing module to understand the process in detail.Can someone please
help?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160404/ef3896e2/attachment.html>
