[rtems commit] or1k/generic_or1k: Add per-section compilation and linking support
Hesham Almatary
heshamelmatary at gmail.com
Mon Apr 4 05:00:17 UTC 2016
Should I "undo" this patch to get it working again?
On Sat, Apr 2, 2016 at 11:57 AM Gedare Bloom <gedare at rtems.org> wrote:
> ---------- Forwarded message ----------
> From: Hesham Almatary <heshamelmatary at gmail.com>
> Date: Fri, Apr 1, 2016 at 8:45 PM
> Subject: Re: [rtems commit] or1k/generic_or1k: Add per-section
> To: vc at rtems.org
> Cc: Stefan Wallentowitz <stefan at wallentowitz.de>
> hello and ticker fail to run with this commit.
> On Sat, Mar 12, 2016 at 7:14 AM Joel Sherrill <joel at rtems.org> wrote:
> > Module: rtems
> > Branch: master
> > Commit: e1768fdd950fb24004183cdfdbef0bcd1a07908c
> > Changeset:
> http://git.rtems.org/rtems/commit/?id=e1768fdd950fb24004183cdfdbef0bcd1a07908c
> > Author: Joel Sherrill <joel at rtems.org>
> > Date: Thu Mar 10 16:28:12 2016 -0600
> > updates #2577.
> > For the generic_or1k BSP variant without this option sample
> > executables sizes were as follows:
> > text data bss dec hex filename
> > 255044 1780 33297600 33554424 1fffff8 ticker.exe
> > 188484 1496 33364448 33554428 1fffffc minimum.exe
> > 829728 77432 32647264 33554424 1fffff8 cxx_iostream.exe
> > 1110588 6112 32437728 33554428 1fffffc fileio.exe
> > 881676 14420 32658304 33554400 1ffffe0 pppd.exe
> > 428200 2556 33123648 33554404 1ffffe4 capture.exe
> > 274012 1868 33278528 33554408 1ffffe8 nsecs.exe
> > 398084 2184 33154144 33554412 1ffffec paranoia.exe
> > 387348 7420 33159648 33554416 1fffff0 cdtest.exe
> > 247752 1780 33304896 33554428 1fffffc base_sp.exe
> > 253888 1808 33298720 33554416 1fffff0 unlimited.exe
> > 261792 1752 33290880 33554424 1fffff8 hello.exe
> > 569612 6792 32978016 33554420 1fffff4 loopback.exe
> > For the generic_or1k BSP variant with this option sample executables
> > 229804 1760 33314592 33546156 1ffdfac ticker.exe
> > 118744 1424 33425984 33546152 1ffdfa8 minimum.exe
> > 607344 29188 32909632 33546164 1ffdfb4 cxx_iostream.exe
> > 1064124 6088 32475936 33546148 1ffdfa4 fileio.exe
> > 801832 14156 32730176 33546164 1ffdfb4 pppd.exe
> > 392908 2508 33150752 33546168 1ffdfb8 capture.exe
> > 249932 1848 33294368 33546148 1ffdfa4 nsecs.exe
> > 372320 2164 33171680 33546164 1ffdfb4 paranoia.exe
> > 361148 6980 33178016 33546144 1ffdfa0 cdtest.exe
> > 222004 1760 33322400 33546164 1ffdfb4 base_sp.exe
> > 222812 1772 33321568 33546152 1ffdfa8 unlimited.exe
> > 229764 1704 33314688 33546156 1ffdfac hello.exe
> > 515572 6576 33024000 33546148 1ffdfa4 loopback.exe
> > c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg | 3 +++
> > 1 file changed, 3 insertions(+)
> > diff --git
> a/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg
> b/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg
> > index fff00ae..9a00643 100644
> > --- a/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg
> > +++ b/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg
> > @@ -5,3 +5,6 @@ RTEMS_CPU = or1k
> > CPU_CFLAGS = -O2
> > CFLAGS_OPTIMIZE_V ?= -O0 -g
> > +CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
> > +LDFLAGS = -Wl,--gc-sections
> > vc mailing list
> > vc at rtems.org
> > http://lists.rtems.org/mailman/listinfo/vc
> vc mailing list
> vc at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160404/e4d07a09/attachment.html>
