Building a rtems image
Tue Apr 5 01:30:51 UTC 2016
On 5/04/2016 10:18 AM, Sambeet Panigrahi wrote:
> ---------- Forwarded message ----------
> From: "Sambeet Panigrahi" <sambeet161616 at gmail.com>
> Date: Apr 5, 2016 5:47 AM
> Subject: Re: Building a rtems image
> To: "Chris Johns" <chrisj at rtems.org>
> Cc:
> I gave the command and the output is as follows::
> $file examples/ticker.exe
> examples/ticker.exe:32 bit MSB executable, SPARC version 1 (SYSV),
> statically linked,not stripped
> Is this because I have built the examples for sparc architecture. Do I need
> to build them again for i386?
Yes.
> Can you please explain the output of the file command?
Suggest you Google the command. There is plenty of info about it o nthe net.
