[PATCH] cpukit: pppd: fix compile warning
Peng Fan van.freenix at gmail.com
Tue Apr 5 12:45:55 UTC 2016
rcsid is defined, but not used. So discard it.
Signed-off-by: Peng Fan <van.freenix at gmail.com>
 cpukit/pppd/auth.c      | 4 ----
 cpukit/pppd/ccp.c       | 4 ----
 cpukit/pppd/chap.c      | 4 ----
 cpukit/pppd/demand.c    | 4 ----
 cpukit/pppd/fsm.c       | 4 ----
 cpukit/pppd/ipcp.c      | 4 ----
 cpukit/pppd/lcp.c       | 4 ----
 cpukit/pppd/magic.c     | 4 ----
 cpukit/pppd/options.c   | 4 ----
 cpukit/pppd/rtemsmain.c | 4 ----
 cpukit/pppd/sys-rtems.c | 5 -----
 cpukit/pppd/upap.c      | 4 ----
 cpukit/pppd/utils.c     | 4 ----
 13 files changed, 53 deletions(-)
diff --git a/cpukit/pppd/auth.c b/cpukit/pppd/auth.c
index fb84f1e..9df1d32 100644
--- a/cpukit/pppd/auth.c
+++ b/cpukit/pppd/auth.c
@@ -32,8 +32,6 @@
  * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
-#define RCSID	"$Id$"
 #include <stddef.h>
@@ -75,8 +73,6 @@
 #endif
 #include "pathnames.h"
-static const char rcsid[] = RCSID;
 /* The name by which the peer authenticated itself to us. */
 char peer_authname[MAXNAMELEN];
diff --git a/cpukit/pppd/ccp.c b/cpukit/pppd/ccp.c
index d80df27..6ada96c 100644
--- a/cpukit/pppd/ccp.c
+++ b/cpukit/pppd/ccp.c
@@ -25,8 +25,6 @@
  * OR MODIFICATIONS.
@@ -35,8 +33,6 @@
 #include "ccp.h"
 #include <net/ppp_comp.h>
  * Command-line options.
diff --git a/cpukit/pppd/chap.c b/cpukit/pppd/chap.c
index 3fe766f..55f1896 100644
--- a/cpukit/pppd/chap.c
+++ b/cpukit/pppd/chap.c
@@ -33,8 +33,6 @@
  * TODO:
@@ -52,8 +50,6 @@
 #include "chap_ms.h"
 #endif
diff --git a/cpukit/pppd/demand.c b/cpukit/pppd/demand.c
index a094a15..a5c13f7 100644
--- a/cpukit/pppd/demand.c
+++ b/cpukit/pppd/demand.c
@@ -17,8 +17,6 @@
-#define RCSID	"$Id$";
@@ -43,8 +41,6 @@
 #include "ipcp.h"
 #include "lcp.h"
 static unsigned char *frame;
 static int framelen;
 static int framemax;
diff --git a/cpukit/pppd/fsm.c b/cpukit/pppd/fsm.c
index ce06401..4ff17d8 100644
--- a/cpukit/pppd/fsm.c
+++ b/cpukit/pppd/fsm.c
@@ -17,8 +17,6 @@
  * TODO:
  * Randomize fsm id on link/init.
@@ -32,8 +30,6 @@
 #include "pppd.h"
 #include "fsm.h"
 static void fsm_timeout(void *);
 static void fsm_rconfreq(fsm *, u_char, u_char *, int);
 static void fsm_rconfack(fsm *, int, u_char *, int);
diff --git a/cpukit/pppd/ipcp.c b/cpukit/pppd/ipcp.c
index fd23ddd..a9a8f24 100644
--- a/cpukit/pppd/ipcp.c
+++ b/cpukit/pppd/ipcp.c
@@ -17,8 +17,6 @@
  * TODO:
@@ -40,8 +38,6 @@
 #include <rtems/bsdnet/servers.h>
 /* global vars */
 ipcp_options ipcp_wantoptions[NUM_PPP];	/* Options that we want to request */
 ipcp_options ipcp_gotoptions[NUM_PPP];	/* Options that peer ack'd */
diff --git a/cpukit/pppd/lcp.c b/cpukit/pppd/lcp.c
index 9da1326..e09e8fb 100644
--- a/cpukit/pppd/lcp.c
+++ b/cpukit/pppd/lcp.c
@@ -17,8 +17,6 @@
  * TODO:
@@ -33,8 +31,6 @@
 #include "chap.h"
 #include "magic.h"
  * LCP-related command-line options.
diff --git a/cpukit/pppd/magic.c b/cpukit/pppd/magic.c
index 3d297e5..46add2f 100644
--- a/cpukit/pppd/magic.c
+++ b/cpukit/pppd/magic.c
@@ -17,8 +17,6 @@
 #include <unistd.h>
@@ -28,8 +26,6 @@
 #include "pppd.h"
 #include "magic.h"
  * magic_init - Initialize the magic number generator.
diff --git a/cpukit/pppd/options.c b/cpukit/pppd/options.c
index 8a39266..9086e55 100644
--- a/cpukit/pppd/options.c
+++ b/cpukit/pppd/options.c
@@ -17,8 +17,6 @@
 #include <ctype.h>
@@ -53,8 +51,6 @@
  * Option variables and default values.
diff --git a/cpukit/pppd/rtemsmain.c b/cpukit/pppd/rtemsmain.c
index 89ed776..030bebe 100644
--- a/cpukit/pppd/rtemsmain.c
+++ b/cpukit/pppd/rtemsmain.c
@@ -17,8 +17,6 @@
 #include <ctype.h>
@@ -68,8 +66,6 @@
 #include "atcp.h"
 #endif
 /* interface vars */
 char ifname[32];		/* Interface name */
 int pppifunit;			/* Interface unit number */
diff --git a/cpukit/pppd/sys-rtems.c b/cpukit/pppd/sys-rtems.c
index ac87957..3fdca9e 100644
--- a/cpukit/pppd/sys-rtems.c
+++ b/cpukit/pppd/sys-rtems.c
@@ -20,8 +20,6 @@
@@ -66,9 +64,6 @@ extern rtems_id rtems_pppd_taskid;
 #include "fsm.h"
 #include "ipcp.h"
 static int initdisc = -1;	/* Initial TTY discipline for ppp_fd */
 static int initfdflags = -1;	/* Initial file descriptor flags for ppp_fd */
 static int ppp_fd = -1;		/* fd which is set to PPP discipline */
diff --git a/cpukit/pppd/upap.c b/cpukit/pppd/upap.c
index e8115a6..55700c5 100644
--- a/cpukit/pppd/upap.c
+++ b/cpukit/pppd/upap.c
@@ -17,8 +17,6 @@
  * TODO:
@@ -29,8 +27,6 @@
 #include "pppd.h"
 #include "upap.h"
 static bool hide_password = true;
diff --git a/cpukit/pppd/utils.c b/cpukit/pppd/utils.c
index af39226..cb1dab3 100644
--- a/cpukit/pppd/utils.c
+++ b/cpukit/pppd/utils.c
@@ -17,8 +17,6 @@
 #include <ctype.h>
@@ -44,8 +42,6 @@
 #include "pppd.h"
 static void pr_log(void *, char *, ...);
 static void logit(int, char *, va_list);
 static void vslp_printer(void *, char *, ...);
2.6.2
