[PATCH] score: Delete Thread_Wait_information::id
Sebastian Huber
Tue Apr 5 12:48:55 UTC 2016
This field was only by the monitor in non-multiprocessing
configurations. Add new field Thread_Wait_information::remote_id in
multiprocessing configurations and use it for the remote procedure call
thread queue.
Add _Thread_Wait_get_id() to obtain the object identifier for debug and
system information tools. Ensure the object layout via static asserts.
Add test cases to sptests/spthreadq01.
cpukit/libmisc/monitor/mon-task.c | 32 +-
cpukit/posix/include/rtems/posix/cond.h | 2 +-
cpukit/posix/include/rtems/posix/mqueue.h | 2 +-
cpukit/posix/include/rtems/posix/mutex.h | 2 +-
cpukit/posix/include/rtems/posix/semaphore.h | 2 +-
cpukit/posix/src/condwaitsupp.c | 7 +-
cpukit/posix/src/mqueuerecvsupp.c | 6 +
cpukit/posix/src/mutexlocksupp.c | 3 +
cpukit/posix/src/pbarrierwait.c | 4 +-
cpukit/posix/src/prwlockwrlock.c | 4 +-
cpukit/posix/src/semaphorewaitsupp.c | 6 +
cpukit/rtems/include/rtems/rtems/barrier.h | 4 +-
cpukit/rtems/include/rtems/rtems/message.h | 4 +-
cpukit/rtems/include/rtems/rtems/sem.h | 14 +-
cpukit/rtems/src/barrierwait.c | 4 +-
cpukit/rtems/src/msgqreceive.c | 7 +-
cpukit/rtems/src/regiongetsegment.c | 1 -
cpukit/rtems/src/semobtain.c | 12 +-
cpukit/score/Makefile.am | 1 +
cpukit/score/include/rtems/score/coremuteximpl.h | 1 -
cpukit/score/include/rtems/score/coresemimpl.h | 1 -
cpukit/score/include/rtems/score/thread.h | 9 +-
cpukit/score/include/rtems/score/threadimpl.h | 36 +++
cpukit/score/src/corebarrierwait.c | 2 -
cpukit/score/src/coremsgseize.c | 1 -
cpukit/score/src/coremsgsubmit.c | 1 -
cpukit/score/src/corerwlockobtainread.c | 1 -
cpukit/score/src/corerwlockobtainwrite.c | 1 -
cpukit/score/src/mpci.c | 2 +-
cpukit/score/src/threadmp.c | 1 -
cpukit/score/src/threadqextractwithproxy.c | 2 +-
cpukit/score/src/threadwaitgetid.c | 54 ++++
testsuites/sptests/spthreadq01/init.c | 365 ++++++++++++++++++++++-
33 files changed, 550 insertions(+), 44 deletions(-)
create mode 100644 cpukit/score/src/threadwaitgetid.c
diff --git a/cpukit/libmisc/monitor/mon-task.c b/cpukit/libmisc/monitor/mon-task.c
index 341a403..96891e2 100644
--- a/cpukit/libmisc/monitor/mon-task.c
+++ b/cpukit/libmisc/monitor/mon-task.c
@@ -14,26 +14,46 @@
#include <string.h> /* memcpy() */
+static void
+rtems_monitor_task_wait_info(
+ rtems_monitor_task_t *canonical_task,
+ Thread_Control *rtems_thread
+ ISR_lock_Context lock_context;
+ void *lock;
+ lock = _Thread_Lock_acquire( rtems_thread, &lock_context );
+ canonical_task->state = rtems_thread->current_state;
+ canonical_task->wait_id = _Thread_Wait_get_id( rtems_thread );
+ canonical_task->wait_queue = rtems_thread->Wait.queue;
+ canonical_task->wait_operations = rtems_thread->Wait.operations;
+ _Thread_Lock_release( lock, &lock_context );
void
rtems_monitor_task_canonical(
const void *thread_void
- const Thread_Control *rtems_thread = (const Thread_Control *) thread_void;
- RTEMS_API_Control *api;
+ Thread_Control *rtems_thread;
+ RTEMS_API_Control *api;
+ rtems_thread =
+ RTEMS_DECONST( Thread_Control *, (const Thread_Control *) thread_void );
api = rtems_thread->API_Extensions[ THREAD_API_RTEMS ];
+ rtems_monitor_task_wait_info( canonical_task, rtems_thread );
canonical_task->entry = rtems_thread->Start.Entry;
canonical_task->stack = rtems_thread->Start.Initial_stack.area;
canonical_task->stack_size = rtems_thread->Start.Initial_stack.size;
canonical_task->cpu = _Per_CPU_Get_index( _Thread_Get_CPU( rtems_thread ) );
canonical_task->priority = rtems_thread->current_priority;
- canonical_task->state = rtems_thread->current_state;
- canonical_task->wait_id = rtems_thread->Wait.id;
- canonical_task->wait_queue = rtems_thread->Wait.queue;
- canonical_task->wait_operations = rtems_thread->Wait.operations;
canonical_task->events = api->Event.pending_events;
* FIXME: make this optionally cpu_time_executed
diff --git a/cpukit/posix/include/rtems/posix/cond.h b/cpukit/posix/include/rtems/posix/cond.h
index 00a0fdb..1839279 100644
--- a/cpukit/posix/include/rtems/posix/cond.h
+++ b/cpukit/posix/include/rtems/posix/cond.h
@@ -42,9 +42,9 @@ extern "C" {
typedef struct {
Objects_Control Object;
+ Thread_queue_Control Wait_queue;
int process_shared;
pthread_mutex_t Mutex;
- Thread_queue_Control Wait_queue;
} POSIX_Condition_variables_Control;
#ifdef __cplusplus
diff --git a/cpukit/posix/include/rtems/posix/mqueue.h b/cpukit/posix/include/rtems/posix/mqueue.h
index 473183d..9e74fb6 100644
--- a/cpukit/posix/include/rtems/posix/mqueue.h
+++ b/cpukit/posix/include/rtems/posix/mqueue.h
@@ -54,11 +54,11 @@ extern "C" {
typedef struct {
+ CORE_message_queue_Control Message_queue;
int process_shared;
bool named;
bool linked;
uint32_t open_count;
- CORE_message_queue_Control Message_queue;
struct sigevent notification;
} POSIX_Message_queue_Control;
diff --git a/cpukit/posix/include/rtems/posix/mutex.h b/cpukit/posix/include/rtems/posix/mutex.h
index 5243d4c..bc8e529 100644
--- a/cpukit/posix/include/rtems/posix/mutex.h
+++ b/cpukit/posix/include/rtems/posix/mutex.h
@@ -42,8 +42,8 @@ extern "C" {
typedef struct {
- int process_shared;
CORE_mutex_Control Mutex;
+ int process_shared;
} POSIX_Mutex_Control;
diff --git a/cpukit/posix/include/rtems/posix/semaphore.h b/cpukit/posix/include/rtems/posix/semaphore.h
index 5aef39b..45de4a9 100644
--- a/cpukit/posix/include/rtems/posix/semaphore.h
+++ b/cpukit/posix/include/rtems/posix/semaphore.h
@@ -42,11 +42,11 @@ extern "C" {
typedef struct {
+ CORE_semaphore_Control Semaphore;
int process_shared;
bool named;
bool linked;
- CORE_semaphore_Control Semaphore;
* sem_t is 32-bit. If Object_Id is 16-bit, then they are not
* interchangeable. We have to be able to return a pointer to
diff --git a/cpukit/posix/src/condwaitsupp.c b/cpukit/posix/src/condwaitsupp.c
index d4e2403..0a7e308 100644
--- a/cpukit/posix/src/condwaitsupp.c
+++ b/cpukit/posix/src/condwaitsupp.c
@@ -24,9 +24,15 @@
+#include <rtems/score/threadimpl.h>
#include <rtems/posix/condimpl.h>
+THREAD_WAIT_QUEUE_OBJECT_ASSERT(
+ POSIX_Condition_variables_Control,
+ Wait_queue
int _POSIX_Condition_variables_Wait_support(
pthread_cond_t *cond,
pthread_mutex_t *mutex,
@@ -75,7 +81,6 @@ int _POSIX_Condition_variables_Wait_support(
executing = _Thread_Executing;
executing->Wait.return_code = 0;
- executing->Wait.id = *cond;
_Thread_queue_Enqueue(
&the_cond->Wait_queue,
diff --git a/cpukit/posix/src/mqueuerecvsupp.c b/cpukit/posix/src/mqueuerecvsupp.c
index 54d0ac1..bbbc234 100644
--- a/cpukit/posix/src/mqueuerecvsupp.c
+++ b/cpukit/posix/src/mqueuerecvsupp.c
@@ -28,9 +28,15 @@
#include <rtems/seterr.h>
#include <rtems/posix/mqueueimpl.h>
+ POSIX_Message_queue_Control,
+ Message_queue.Wait_queue
* _POSIX_Message_queue_Receive_support
diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
index cd95a97..0ec9b85 100644
--- a/cpukit/posix/src/mutexlocksupp.c
+++ b/cpukit/posix/src/mutexlocksupp.c
@@ -24,9 +24,12 @@
+THREAD_WAIT_QUEUE_OBJECT_ASSERT( POSIX_Mutex_Control, Mutex.Wait_queue );
* _POSIX_Mutex_Lock_support
diff --git a/cpukit/posix/src/pbarrierwait.c b/cpukit/posix/src/pbarrierwait.c
index df4472b..560e101 100644
--- a/cpukit/posix/src/pbarrierwait.c
+++ b/cpukit/posix/src/pbarrierwait.c
@@ -22,7 +22,9 @@
#include <rtems/posix/barrierimpl.h>
-#include <rtems/score/thread.h>
+THREAD_WAIT_QUEUE_OBJECT_ASSERT( POSIX_Barrier_Control, Barrier.Wait_queue );
* This directive allows a thread to wait at a barrier.
diff --git a/cpukit/posix/src/prwlockwrlock.c b/cpukit/posix/src/prwlockwrlock.c
index 6777464..1905460 100644
--- a/cpukit/posix/src/prwlockwrlock.c
+++ b/cpukit/posix/src/prwlockwrlock.c
@@ -24,7 +24,9 @@
#include <rtems/posix/rwlockimpl.h>
+THREAD_WAIT_QUEUE_OBJECT_ASSERT( POSIX_RWLock_Control, RWLock.Wait_queue );
* pthread_rwlock_wrlock
diff --git a/cpukit/posix/src/semaphorewaitsupp.c b/cpukit/posix/src/semaphorewaitsupp.c
index 5c055be..cf8fe63 100644
--- a/cpukit/posix/src/semaphorewaitsupp.c
+++ b/cpukit/posix/src/semaphorewaitsupp.c
@@ -27,9 +27,15 @@
#include <limits.h>
#include <rtems/posix/semaphoreimpl.h>
+ POSIX_Semaphore_Control,
+ Semaphore.Wait_queue
int _POSIX_Semaphore_Wait_support(
sem_t *sem,
bool blocking,
diff --git a/cpukit/rtems/include/rtems/rtems/barrier.h b/cpukit/rtems/include/rtems/rtems/barrier.h
index 8c3b9d3..2eea90f 100644
--- a/cpukit/rtems/include/rtems/rtems/barrier.h
+++ b/cpukit/rtems/include/rtems/rtems/barrier.h
@@ -55,10 +55,10 @@ extern "C" {
typedef struct {
/** This is used to manage a barrier as an object. */
- /** This is used to specify the attributes of a barrier. */
- rtems_attribute attribute_set;
/** This is used to implement the barrier. */
CORE_barrier_Control Barrier;
+ /** This is used to specify the attributes of a barrier. */
+ rtems_attribute attribute_set;
} Barrier_Control;
diff --git a/cpukit/rtems/include/rtems/rtems/message.h b/cpukit/rtems/include/rtems/rtems/message.h
index 0fad595..8ae9e15 100644
--- a/cpukit/rtems/include/rtems/rtems/message.h
+++ b/cpukit/rtems/include/rtems/rtems/message.h
@@ -53,10 +53,10 @@ extern "C" {
typedef struct {
/** This field is the inherited object characteristics. */
- /** This field is the attribute set as defined by the API. */
/** This field is the instance of the SuperCore Message Queue. */
CORE_message_queue_Control message_queue;
+ /** This field is the attribute set as defined by the API. */
} Message_queue_Control;
diff --git a/cpukit/rtems/include/rtems/rtems/sem.h b/cpukit/rtems/include/rtems/rtems/sem.h
index 6c71a9d..b3950a2 100644
--- a/cpukit/rtems/include/rtems/rtems/sem.h
+++ b/cpukit/rtems/include/rtems/rtems/sem.h
@@ -65,13 +65,6 @@ typedef struct {
- * This is the Classic API attribute provided to the create directive.
- * It is translated into behavioral attributes on the SuperCore Semaphore
- * or Mutex instance.
* This contains the memory associated with the SuperCore Semaphore or
* Mutex instance that provides the primary functionality of each
* Classic API Semaphore instance. The structure used is dependent
@@ -97,6 +90,13 @@ typedef struct {
MRSP_Control mrsp;
#endif
} Core_control;
+ * This is the Classic API attribute provided to the create directive.
+ * It is translated into behavioral attributes on the SuperCore Semaphore
+ * or Mutex instance.
} Semaphore_Control;
diff --git a/cpukit/rtems/src/barrierwait.c b/cpukit/rtems/src/barrierwait.c
index fa7ab8e..3a30593 100644
--- a/cpukit/rtems/src/barrierwait.c
+++ b/cpukit/rtems/src/barrierwait.c
@@ -22,7 +22,9 @@
#include <rtems/rtems/barrierimpl.h>
+THREAD_WAIT_QUEUE_OBJECT_ASSERT( Barrier_Control, Barrier.Wait_queue );
rtems_status_code rtems_barrier_wait(
rtems_id id,
diff --git a/cpukit/rtems/src/msgqreceive.c b/cpukit/rtems/src/msgqreceive.c
index 2b9a4e7..3b4945e 100644
--- a/cpukit/rtems/src/msgqreceive.c
+++ b/cpukit/rtems/src/msgqreceive.c
@@ -22,7 +22,7 @@
#include <rtems/score/isr.h>
@@ -30,6 +30,11 @@
#include <rtems/rtems/optionsimpl.h>
+ Message_queue_Control,
+ message_queue.Wait_queue
rtems_status_code rtems_message_queue_receive(
rtems_id id,
void *buffer,
diff --git a/cpukit/rtems/src/regiongetsegment.c b/cpukit/rtems/src/regiongetsegment.c
index b040ebe..0d1ac57 100644
--- a/cpukit/rtems/src/regiongetsegment.c
+++ b/cpukit/rtems/src/regiongetsegment.c
@@ -75,7 +75,6 @@ rtems_status_code rtems_region_get_segment(
_Thread_Disable_dispatch();
_RTEMS_Unlock_allocator();
- executing->Wait.id = id;
executing->Wait.count = size;
executing->Wait.return_argument = segment;
diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
index bda39fa..0b43af4 100644
--- a/cpukit/rtems/src/semobtain.c
+++ b/cpukit/rtems/src/semobtain.c
@@ -27,10 +27,20 @@
#include <rtems/score/coresemimpl.h>
#include <rtems/score/interr.h>
+ Semaphore_Control,
+ Core_control.mutex.Wait_queue
+ Core_control.semaphore.Wait_queue
rtems_status_code rtems_semaphore_obtain(
rtems_id id,
rtems_option option_set,
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 6ff4e02..5d5f688 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -308,6 +308,7 @@ libscore_a_SOURCES += src/threadentryadaptorpointer.c
libscore_a_SOURCES += src/threadgetcputimeused.c
libscore_a_SOURCES += src/threadglobalconstruction.c
libscore_a_SOURCES += src/threadtimeout.c
+libscore_a_SOURCES += src/threadwaitgetid.c
libscore_a_SOURCES += src/threadyield.c
if HAS_SMP
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index b22f4a7..a1cbb17 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -265,7 +265,6 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize_body(
CORE_MUTEX_STATUS_UNSATISFIED_NOWAIT;
} else {
_CORE_mutex_Seize_interrupt_blocking(
the_mutex,
executing,
diff --git a/cpukit/score/include/rtems/score/coresemimpl.h b/cpukit/score/include/rtems/score/coresemimpl.h
index c70e54f..46033a8 100644
--- a/cpukit/score/include/rtems/score/coresemimpl.h
+++ b/cpukit/score/include/rtems/score/coresemimpl.h
@@ -251,7 +251,6 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize(
return;
_Thread_queue_Enqueue_critical(
&the_semaphore->Wait_queue.Queue,
the_semaphore->operations,
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index ffca164..949e8ca 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -291,8 +291,13 @@ typedef struct {
RBTree_Node RBTree;
} Node;
- /** This field is the Id of the object this thread is waiting upon. */
- Objects_Id id;
+#if defined(RTEMS_MULTIPROCESSING)
+ * @brief This field is the identifier of the remote object this thread is
+ * waiting upon.
+ Objects_Id remote_id;
+#endif
/** This field is used to return an integer while when blocked. */
uint32_t count;
/** This field is for a pointer to a user return argument. */
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 516441e..6b65e8e 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -1449,6 +1449,42 @@ RTEMS_INLINE_ROUTINE void _Thread_Wait_set_timeout_code(
+ * @brief Helper structure to ensure that all objects containing a thread queue
+ * have the right layout.
+ * @see _Thread_Wait_get_id() and THREAD_WAIT_QUEUE_OBJECT_ASSERT().
+typedef struct {
+ Objects_Control Object;
+} Thread_Wait_queue_object;
+#define THREAD_WAIT_QUEUE_OBJECT_ASSERT( object_type, wait_queue_member ) \
+ RTEMS_STATIC_ASSERT( \
+ offsetof( object_type, wait_queue_member ) \
+ == offsetof( Thread_Wait_queue_object, Wait_queue ) \
+ && ( &( ( (object_type *) 0 )->wait_queue_member ) \
+ == ( &( (Thread_Wait_queue_object *) 0 )->Wait_queue ) ), \
+ object_type \
+ * @brief Returns the object identifier of the object containing the current
+ * thread wait queue.
+ * This function may be used for debug and system information purposes. The
+ * caller must be the owner of the thread lock.
+ * @retval 0 The thread waits on no thread queue currently, the thread wait
+ * queue is not contained in an object, or the current thread state provides
+ * insufficient information, e.g. the thread is in the middle of a blocking
+ * operation.
+ * @retval other The object identifier of the object containing the thread wait
+ * queue.
+Objects_Id _Thread_Wait_get_id( const Thread_Control *the_thread );
* @brief General purpose thread wait timeout.
* @param[in] watchdog The thread timer watchdog.
diff --git a/cpukit/score/src/corebarrierwait.c b/cpukit/score/src/corebarrierwait.c
index 4fadc03..52cbe74 100644
--- a/cpukit/score/src/corebarrierwait.c
+++ b/cpukit/score/src/corebarrierwait.c
@@ -47,8 +47,6 @@ void _CORE_barrier_Wait(
&the_barrier->Wait_queue.Queue,
CORE_BARRIER_TQ_OPERATIONS,
diff --git a/cpukit/score/src/coremsgseize.c b/cpukit/score/src/coremsgseize.c
index 9d26fb1..34a3c50 100644
--- a/cpukit/score/src/coremsgseize.c
+++ b/cpukit/score/src/coremsgseize.c
@@ -127,7 +127,6 @@ void _CORE_message_queue_Seize(
return;
executing->Wait.return_argument_second.mutable_object = buffer;
executing->Wait.return_argument = size_p;
/* Wait.count will be filled in with the message priority */
diff --git a/cpukit/score/src/coremsgsubmit.c b/cpukit/score/src/coremsgsubmit.c
index 5f61c5e..02de12f 100644
--- a/cpukit/score/src/coremsgsubmit.c
+++ b/cpukit/score/src/coremsgsubmit.c
@@ -126,7 +126,6 @@ CORE_message_queue_Status _CORE_message_queue_Submit(
* it as a variable. Doing this emphasizes how dangerous it
* would be to use this variable prior to here.
executing->Wait.return_argument_second.immutable_object = buffer;
executing->Wait.option = (uint32_t) size;
executing->Wait.count = submit_type;
diff --git a/cpukit/score/src/corerwlockobtainread.c b/cpukit/score/src/corerwlockobtainread.c
index 97d7b9e..4676dd7 100644
--- a/cpukit/score/src/corerwlockobtainread.c
+++ b/cpukit/score/src/corerwlockobtainread.c
@@ -81,7 +81,6 @@ void _CORE_RWLock_Obtain_for_reading(
* We need to wait to enter this critical section
executing->Wait.option = CORE_RWLOCK_THREAD_WAITING_FOR_READ;
executing->Wait.return_code = CORE_RWLOCK_SUCCESSFUL;
diff --git a/cpukit/score/src/corerwlockobtainwrite.c b/cpukit/score/src/corerwlockobtainwrite.c
index 28de842..0441650 100644
--- a/cpukit/score/src/corerwlockobtainwrite.c
+++ b/cpukit/score/src/corerwlockobtainwrite.c
@@ -68,7 +68,6 @@ void _CORE_RWLock_Obtain_for_writing(
executing->Wait.option = CORE_RWLOCK_THREAD_WAITING_FOR_WRITE;
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index 76ca4c8..20d5084 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -242,7 +242,7 @@ uint32_t _MPCI_Send_request_packet (
the_packet->to_convert =
( the_packet->to_convert - sizeof(MP_packet_Prefix) ) / sizeof(uint32_t);
- executing->Wait.id = the_packet->id;
+ executing->Wait.remote_id = the_packet->id;
(*_MPCI_table->send_packet)( destination, the_packet );
diff --git a/cpukit/score/src/threadmp.c b/cpukit/score/src/threadmp.c
index 2d7e924..33c9078 100644
--- a/cpukit/score/src/threadmp.c
+++ b/cpukit/score/src/threadmp.c
@@ -95,7 +95,6 @@ Thread_Control *_Thread_MP_Allocate_proxy (
the_proxy->current_state = _States_Set( STATES_DORMANT, the_state );
- the_proxy->Wait.id = executing->Wait.id;
the_proxy->Wait.count = executing->Wait.count;
the_proxy->Wait.return_argument = executing->Wait.return_argument;
the_proxy->Wait.return_argument_second = executing->Wait.return_argument_second;
diff --git a/cpukit/score/src/threadqextractwithproxy.c b/cpukit/score/src/threadqextractwithproxy.c
index 9bbf9c6..efe0940 100644
--- a/cpukit/score/src/threadqextractwithproxy.c
+++ b/cpukit/score/src/threadqextractwithproxy.c
@@ -41,7 +41,7 @@ void _Thread_queue_Extract_with_proxy(
Objects_Information *the_information;
Objects_Thread_queue_Extract_callout proxy_extract_callout;
- id = the_thread->Wait.id;
+ id = the_thread->Wait.remote_id;
the_information = _Objects_Get_information_id( id );
proxy_extract_callout = the_information->extract;
diff --git a/cpukit/score/src/threadwaitgetid.c b/cpukit/score/src/threadwaitgetid.c
new file mode 100644
index 0000000..0851e8f
--- /dev/null
+++ b/cpukit/score/src/threadwaitgetid.c
@@ -0,0 +1,54 @@
+ * Copyright (c) 2016 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#define THREAD_WAIT_QUEUE_OBJECT_STATES \
+ ( STATES_WAITING_FOR_BARRIER \
+ | STATES_WAITING_FOR_CONDITION_VARIABLE \
+ | STATES_WAITING_FOR_MESSAGE \
+ | STATES_WAITING_FOR_MUTEX \
+ | STATES_WAITING_FOR_RWLOCK \
+ | STATES_WAITING_FOR_SEMAPHORE )
+ States_Control current_state;
+ current_state = the_thread->current_state;
+ if ( ( current_state & STATES_WAITING_FOR_RPC_REPLY ) != 0 ) {
+ return the_thread->Wait.remote_id;
+#endif
+ if ( ( current_state & THREAD_WAIT_QUEUE_OBJECT_STATES ) != 0 ) {
+ const Thread_Wait_queue_object *queue_object;
+ queue_object = RTEMS_CONTAINER_OF(
+ the_thread->Wait.queue,
+ Thread_Wait_queue_object,
+ Wait_queue.Queue
+ return queue_object->Object.id;
+ return 0;
diff --git a/testsuites/sptests/spthreadq01/init.c b/testsuites/sptests/spthreadq01/init.c
index 6eef0c7..9bf15e8 100644
--- a/testsuites/sptests/spthreadq01/init.c
+++ b/testsuites/sptests/spthreadq01/init.c
@@ -13,17 +13,354 @@
#include <tmacros.h>
-#include <sys/types.h>
-#include <rtems/score/threadqimpl.h>
+#include <rtems.h>
+#if defined(RTEMS_POSIX_API)
+ #include <fcntl.h>
+ #include <mqueue.h>
+ #include <semaphore.h>
+ #include <string.h>
+ #include <pthread.h>
+ #include <rtems/posix/mqueueimpl.h>
+#endif
const char rtems_test_name[] = "SPTHREADQ 1";
static Thread_queue_Control queue = THREAD_QUEUE_INITIALIZER( "Queue" );
+typedef struct {
+ Thread_Control *master;
+ rtems_id master_id;
+ rtems_id worker_id;
+ rtems_id sem;
+ rtems_id mtx;
+ rtems_id mq;
+ rtems_id br;
+ sem_t psem;
+ pthread_mutex_t pmtx;
+ pthread_cond_t pcv;
+ pthread_rwlock_t prw;
+ mqd_t pmq;
+#endif
+} test_context;
+static test_context test_instance;
+static void wait_for_worker(test_context *ctx)
+ rtems_status_code sc;
+ sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+static void wake_up_master(test_context *ctx)
+ sc = rtems_event_transient_send(ctx->master_id);
+static rtems_id get_wait_id(test_context *ctx)
+ void *lock;
+ rtems_id id;
+ lock = _Thread_Lock_acquire(ctx->master, &lock_context);
+ id = _Thread_Wait_get_id(ctx->master);
+ _Thread_Lock_release(lock, &lock_context);
+ return id;
+static void classic_worker(test_context *ctx)
+ char buf[1];
+ wake_up_master(ctx);
+ rtems_test_assert(get_wait_id(ctx) == ctx->sem);
+ sc = rtems_semaphore_release(ctx->sem);
+ sc = rtems_semaphore_obtain(ctx->mtx, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ rtems_test_assert(get_wait_id(ctx) == ctx->mtx);
+ sc = rtems_semaphore_release(ctx->mtx);
+ rtems_test_assert(get_wait_id(ctx) == ctx->mq);
+ buf[0] = 'X';
+ sc = rtems_message_queue_send(ctx->mq, &buf[0], sizeof(buf));
+ rtems_test_assert(get_wait_id(ctx) == ctx->br);
+ sc = rtems_barrier_wait(ctx->br, RTEMS_NO_TIMEOUT);
+static void posix_worker(test_context *ctx)
+ int rv;
+ int eno;
+ char buf[1];
+ POSIX_Message_queue_Control_fd *the_mq_fd;
+ Objects_Locations location;
+ rtems_test_assert(get_wait_id(ctx) == ctx->psem);
+ rv = sem_post(&ctx->psem);
+ rtems_test_assert(rv == 0);
+ eno = pthread_mutex_lock(&ctx->pmtx);
+ rtems_test_assert(eno == 0);
+ rtems_test_assert(get_wait_id(ctx) == ctx->pmtx);
+ eno = pthread_mutex_unlock(&ctx->pmtx);
+ rtems_test_assert(get_wait_id(ctx) == ctx->pcv);
+ eno = pthread_cond_signal(&ctx->pcv);
+ eno = pthread_rwlock_wrlock(&ctx->prw);
+ rtems_test_assert(get_wait_id(ctx) == ctx->prw);
+ eno = pthread_rwlock_unlock(&ctx->prw);
+ the_mq_fd = _POSIX_Message_queue_Get_fd_interrupt_disable(
+ ctx->pmq,
+ &location,
+ &lock_context
+ _ISR_lock_ISR_enable(&lock_context);
+ rtems_test_assert(the_mq_fd != NULL);
+ rtems_test_assert(location == OBJECTS_LOCAL);
+ rtems_test_assert(get_wait_id(ctx) == the_mq_fd->Queue->Object.id);
+ buf[0] = 'x';
+ rv = mq_send(ctx->pmq, &buf[0], sizeof(buf), 0);
+#endif
+static rtems_task worker(rtems_task_argument arg)
+ test_context *ctx = (test_context *) arg;
+ rtems_test_assert(get_wait_id(ctx) == 0);
+ classic_worker(ctx);
+ posix_worker(ctx);
+static void test_classic_init(test_context *ctx)
+ sc = rtems_semaphore_create(
+ rtems_build_name('S', 'E', 'M', ' '),
+ 0,
+ RTEMS_COUNTING_SEMAPHORE,
+ 0,
+ &ctx->sem
+ rtems_build_name('M', 'T', 'X', ' '),
+ 1,
+ RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
+ 0,
+ &ctx->mtx
+ sc = rtems_message_queue_create(
+ rtems_build_name('M', 'Q', ' ', ' '),
+ 1,
+ 1,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &ctx->mq
+ sc = rtems_barrier_create(
+ rtems_build_name('B', 'R', ' ', ' '),
+ RTEMS_BARRIER_AUTOMATIC_RELEASE,
+ 2,
+ &ctx->br
+static void test_posix_init(test_context *ctx)
+ int rv;
+ int eno;
+ struct mq_attr attr;
+ rv = sem_init(&ctx->psem, 0, 0);
+ eno = pthread_mutex_init(&ctx->pmtx, NULL);
+ eno = pthread_cond_init(&ctx->pcv, NULL);
+ eno = pthread_rwlock_init(&ctx->prw, NULL);
+ memset(&attr, 0, sizeof(attr));
+ attr.mq_maxmsg = 1;
+ attr.mq_msgsize = sizeof(char);
+ ctx->pmq = mq_open("mq", O_CREAT | O_RDWR, 0x777, &attr);
+ rtems_test_assert(ctx->mq != -1);
+#endif
+static void test_context_init(test_context *ctx)
+ ctx->master = _Thread_Get_executing();
+ ctx->master_id = rtems_task_self();
+ test_classic_init(ctx);
+ test_posix_init(ctx);
+ sc = rtems_task_create(
+ rtems_build_name('W', 'O', 'R', 'K'),
+ 2,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ &ctx->worker_id
+ sc = rtems_task_start(ctx->worker_id, worker, (rtems_task_argument) ctx);
+static void test_classic_obj(test_context *ctx)
+ char buf[1];
+ size_t n;
+ wait_for_worker(ctx);
+ sc = rtems_semaphore_obtain(ctx->sem, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ buf[0] = 'Y';
+ n = 123;
+ sc = rtems_message_queue_receive(
+ ctx->mq,
+ &buf[0],
+ &n,
+ RTEMS_WAIT,
+ RTEMS_NO_TIMEOUT
+ rtems_test_assert(buf[0] == 'X');
+ rtems_test_assert(n == sizeof(buf));
+static void test_posix_obj(test_context *ctx)
+ int rv;
+ int eno;
+ char buf[1];
+ unsigned prio;
+ ssize_t n;
+ rv = sem_wait(&ctx->psem);
+ eno = pthread_cond_wait(&ctx->pcv, &ctx->pmtx);
+ buf[0] = 'y';
+ prio = 1;
+ n = mq_receive(ctx->pmq, &buf[0], sizeof(buf), &prio);
+ rtems_test_assert(n == (ssize_t) sizeof(buf));
+ rtems_test_assert(buf[0] == 'x');
+ rtems_test_assert(prio == 0);
+#endif
static rtems_task Init(
rtems_task_argument ignored
+ test_context *ctx = &test_instance;
TEST_BEGIN();
puts( "Init - _Thread_queue_Extract - thread not blocked on a thread queue" );
@@ -32,6 +369,10 @@ static rtems_task Init(
_Thread_Enable_dispatch();
/* is there more to check? */
+ test_context_init(ctx);
+ test_classic_obj(ctx);
+ test_posix_obj(ctx);
rtems_test_assert( queue.Queue.heads == NULL );
TEST_END();
@@ -43,7 +384,25 @@ static rtems_task Init(
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_MAXIMUM_SEMAPHORES 2
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
+#define CONFIGURE_MAXIMUM_BARRIERS 1
+ #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 1
+ #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 1
+ #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 1
+ #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS 1
+ #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 1
+ #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS 1
+ #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
+ (2 * CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(1, 1))
+#else
+ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(1, 1)
+#endif
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
1.8.4.5
