[PATCH 02/15] posix: Make _POSIX_signals_Check_signal() static
Tue Apr 5 13:09:47 UTC 2016
 cpukit/posix/Makefile.am                       |   2 +-
 cpukit/posix/include/rtems/posix/psignalimpl.h |   9 --
 cpukit/posix/src/psignal.c                     |  74 ++++++++++++++++
 cpukit/posix/src/psignalchecksignal.c          | 113 -------------------------
 4 files changed, 75 insertions(+), 123 deletions(-)
 delete mode 100644 cpukit/posix/src/psignalchecksignal.c
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index dcedf5b..ed62232 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -147,7 +147,7 @@ endif
 ## PSIGNAL_C_FILES
 libposix_a_SOURCES += src/psignal.c src/alarm.c src/kill.c src/killinfo.c \
     src/kill_r.c src/pause.c src/psignalclearprocesssignals.c \
-    src/psignalsetprocesssignals.c src/psignalchecksignal.c \
+    src/psignalsetprocesssignals.c \
     src/psignalclearsignals.c src/psignalunblockthread.c src/pthreadkill.c \
     src/pthreadsigmask.c src/sigaction.c
 endif
diff --git a/cpukit/posix/include/rtems/posix/psignalimpl.h b/cpukit/posix/include/rtems/posix/psignalimpl.h
index eeb060e..7c1424c 100644
--- a/cpukit/posix/include/rtems/posix/psignalimpl.h
+++ b/cpukit/posix/include/rtems/posix/psignalimpl.h
@@ -96,15 +96,6 @@ bool _POSIX_signals_Unblock_thread(
- *  @brief Check POSIX signal.
-bool _POSIX_signals_Check_signal(
-  POSIX_API_Control  *api,
-  int                 signo,
-  bool                is_global
  * @brief Clear POSIX signals.
 bool _POSIX_signals_Clear_signals(
diff --git a/cpukit/posix/src/psignal.c b/cpukit/posix/src/psignal.c
index 18aad96..354fb33 100644
--- a/cpukit/posix/src/psignal.c
+++ b/cpukit/posix/src/psignal.c
@@ -107,6 +107,80 @@ Chain_Control _POSIX_signals_Siginfo[ SIG_ARRAY_MAX ];
     (STATES_WAITING_FOR_SIGNAL|STATES_INTERRUPTIBLE_BY_SIGNAL)) == \
+static void _POSIX_signals_Check_signal(
+  POSIX_API_Control  *api,
+  int                 signo,
+  bool                is_global
+  siginfo_t                   siginfo_struct;
+  sigset_t                    saved_signals_unblocked;
+  Thread_Wait_information     stored_thread_wait_information;
+  Thread_Control             *executing;
+  if ( ! _POSIX_signals_Clear_signals( api, signo, &siginfo_struct,
+                                       is_global, true, true ) )
+    return;
+   *  Since we made a union of these, only one test is necessary but this is
+   *  safer.
+  #if defined(RTEMS_DEBUG)
+    assert( _POSIX_signals_Vectors[ signo ].sa_handler ||
+            _POSIX_signals_Vectors[ signo ].sa_sigaction );
+  #endif
+   *  Just to prevent sending a signal which is currently being ignored.
+  if ( _POSIX_signals_Vectors[ signo ].sa_handler == SIG_IGN )
+    return;
+   *  Block the signals requested in sa_mask
+  saved_signals_unblocked = api->signals_unblocked;
+  api->signals_unblocked &= ~_POSIX_signals_Vectors[ signo ].sa_mask;
+  executing = _Thread_Get_executing();
+   *  We have to save the blocking information of the current wait queue
+   *  because the signal handler may subsequently go on and put the thread
+   *  on a wait queue, for its own purposes.
+  memcpy( &stored_thread_wait_information, &executing->Wait,
+          sizeof( stored_thread_wait_information ));
+   *  Here, the signal handler function executes
+  switch ( _POSIX_signals_Vectors[ signo ].sa_flags ) {
+    case SA_SIGINFO:
+      (*_POSIX_signals_Vectors[ signo ].sa_sigaction)(
+        signo,
+        &siginfo_struct,
+        NULL        /* context is undefined per 1003.1b-1993, p. 66 */
+      break;
+    default:
+      (*_POSIX_signals_Vectors[ signo ].sa_handler)( signo );
+      break;
+   *  Restore the blocking information
+  memcpy( &executing->Wait, &stored_thread_wait_information,
+          sizeof( executing->Wait ));
+   *  Restore the previous set of unblocked signals
+  api->signals_unblocked = saved_signals_unblocked;
 void _POSIX_signals_Action_handler(
   Thread_Control  *executing,
   Thread_Action   *action,
diff --git a/cpukit/posix/src/psignalchecksignal.c b/cpukit/posix/src/psignalchecksignal.c
deleted file mode 100644
index 990bcc2..0000000
--- a/cpukit/posix/src/psignalchecksignal.c
+++ /dev/null
@@ -1,113 +0,0 @@
- *  @file
- *  @brief POSIX Signals Check Signal
- *  @ingroup POSIX_SIGNALS
- *  COPYRIGHT (c) 1989-2007.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#if defined(RTEMS_DEBUG)
-  #include <assert.h>
-#endif
-#include <errno.h>
-#include <pthread.h>
-#include <signal.h>
-#include <string.h>
-#include <rtems/system.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/wkspace.h>
-#include <rtems/seterr.h>
-#include <rtems/posix/threadsup.h>
-#include <rtems/posix/psignalimpl.h>
-#include <rtems/posix/pthreadimpl.h>
-#include <stdio.h>
-  int                 signo,
-  bool                is_global
-  siginfo_t                   siginfo_struct;
-  sigset_t                    saved_signals_unblocked;
-  Thread_Wait_information     stored_thread_wait_information;
-  Thread_Control             *executing;
-  if ( ! _POSIX_signals_Clear_signals( api, signo, &siginfo_struct,
-                                       is_global, true, true ) )
-    return false;
-   *  Since we made a union of these, only one test is necessary but this is
-   *  safer.
-  #if defined(RTEMS_DEBUG)
-    assert( _POSIX_signals_Vectors[ signo ].sa_handler ||
-            _POSIX_signals_Vectors[ signo ].sa_sigaction );
-  #endif
-   *  Just to prevent sending a signal which is currently being ignored.
-  if ( _POSIX_signals_Vectors[ signo ].sa_handler == SIG_IGN )
-    return false;
-   *  Block the signals requested in sa_mask
-  saved_signals_unblocked = api->signals_unblocked;
-  api->signals_unblocked &= ~_POSIX_signals_Vectors[ signo ].sa_mask;
-  executing = _Thread_Get_executing();
-   *  We have to save the blocking information of the current wait queue
-   *  because the signal handler may subsequently go on and put the thread
-   *  on a wait queue, for its own purposes.
-  memcpy( &stored_thread_wait_information, &executing->Wait,
-          sizeof( stored_thread_wait_information ));
-   *  Here, the signal handler function executes
-  switch ( _POSIX_signals_Vectors[ signo ].sa_flags ) {
-    case SA_SIGINFO:
-      (*_POSIX_signals_Vectors[ signo ].sa_sigaction)(
-        signo,
-        &siginfo_struct,
-        NULL        /* context is undefined per 1003.1b-1993, p. 66 */
-      break;
-    default:
-      (*_POSIX_signals_Vectors[ signo ].sa_handler)( signo );
-      break;
-   *  Restore the blocking information
-  memcpy( &executing->Wait, &stored_thread_wait_information,
-          sizeof( executing->Wait ));
-   *  Restore the previous set of unblocked signals
-  api->signals_unblocked = saved_signals_unblocked;
-  return true;
1.8.4.5
