[PATCH 06/15] score: Use red-black tree for active global objects
Tue Apr 5 13:09:51 UTC 2016
Use a red-black tree to lookup active global objects by identifier or
name.
Update #2555.
 cpukit/sapi/include/confdefs.h                 |   9 -
 cpukit/score/include/rtems/score/object.h      |  46 ++-
 cpukit/score/include/rtems/score/objectimpl.h  |  16 +-
 cpukit/score/include/rtems/score/objectmp.h    |  39 +--
 cpukit/score/src/objectget.c                   |   6 +-
 cpukit/score/src/objectgetisr.c                |   4 +-
 cpukit/score/src/objectinitializeinformation.c |  18 +-
 cpukit/score/src/objectmp.c                    | 374 +++++++++++++++++--------
 testsuites/sptests/spsize/size.c               |   5 -
 9 files changed, 318 insertions(+), 199 deletions(-)
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 6b7aa90..807ea92 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2973,17 +2973,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  * This is an internal parameter.
 #ifdef CONFIGURE_MP_APPLICATION
-  #define CONFIGURE_OBJECT_GLOBAL_TABLE_SIZE(_max) \
-    _Configure_From_workspace( \
-      (CONFIGURE_MP_MAXIMUM_NODES + 1) * sizeof(Chain_Control) \
   #define CONFIGURE_MEMORY_FOR_MP \
     (CONFIGURE_MEMORY_FOR_PROXIES(CONFIGURE_MP_MAXIMUM_PROXIES) + \
-     CONFIGURE_OBJECT_GLOBAL_TABLE_SIZE(CONFIGURE_TASKS) + \
-     CONFIGURE_OBJECT_GLOBAL_TABLE_SIZE(CONFIGURE_MAXIMUM_PARTITIONS) + \
-     CONFIGURE_OBJECT_GLOBAL_TABLE_SIZE(CONFIGURE_SEMAPHORES) + \
-     CONFIGURE_OBJECT_GLOBAL_TABLE_SIZE(CONFIGURE_MAXIMUM_MESSAGE_QUEUES) + \
      CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS(CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS))
 #else
   #define CONFIGURE_MEMORY_FOR_MP  0
diff --git a/cpukit/score/include/rtems/score/object.h b/cpukit/score/include/rtems/score/object.h
index 70e5fe6..c2acb2d 100644
--- a/cpukit/score/include/rtems/score/object.h
+++ b/cpukit/score/include/rtems/score/object.h
@@ -23,6 +23,7 @@
 #include <rtems/score/cpu.h>
+#include <rtems/score/rbtree.h>
 #ifdef __cplusplus
 extern "C" {
@@ -240,18 +241,45 @@ typedef struct {
 #if defined( RTEMS_MULTIPROCESSING )
- *  This defines the Global Object Control Block used to manage
- *  objects resident on other nodes.  It is derived from Object.
+ * @brief This defines the Global Object Control Block used to manage objects
+ * resident on other nodes.
 typedef struct {
-  /** This is an object control structure. */
-  Objects_Control Object;
-  /** This is the name of the object.  Using an unsigned thirty two
-   *  bit value is broken but works.  If any API is MP with variable
-   *  length names .. BOOM!!!!
+   * @brief Nodes to manage active and inactive global objects.
+  union {
+     * @brief Inactive global objects reside on a chain.
+    Chain_Node Inactive;
+    struct {
+       * @brief Node to lookup an active global object by identifier.
+      RBTree_Node Id_lookup;
+       * @brief Node to lookup an active global object by name.
+      RBTree_Node Name_lookup;
+    } Active;
+  } Nodes;
+   * @brief The global object identifier.
+  Objects_Id id;
+   * @brief The global object name.
+   * Using an unsigned thirty two bit value is broken but works.  If any API is
+   * MP with variable length names .. BOOM!!!!
-  uint32_t        name;
-}   Objects_MP_Control;
+  uint32_t name;
+} Objects_MP_Control;
 #endif
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index 786910e..aed7faf 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -172,8 +172,20 @@ typedef struct {
   #if defined(RTEMS_MULTIPROCESSING)
     /** This is this object class' method called when extracting a thread. */
     Objects_Thread_queue_Extract_callout extract;
-    /** This is this object class' pointer to the global name table */
-    Chain_Control    *global_table;
+     * @brief The global objects of this object information sorted by object
+     * identifier.
+    RBTree_Control   Global_by_id;
+     * name.
+     * Objects with the same name are sorted according to their identifier.
+    RBTree_Control   Global_by_name;
   #endif
 }   Objects_Information;
diff --git a/cpukit/score/include/rtems/score/objectmp.h b/cpukit/score/include/rtems/score/objectmp.h
index a78ca82..83fcfad 100644
--- a/cpukit/score/include/rtems/score/objectmp.h
+++ b/cpukit/score/include/rtems/score/objectmp.h
@@ -153,21 +153,24 @@ Objects_Name_or_id_lookup_errors _Objects_MP_Global_name_search (
  *  location is set to objects_error.  In both cases, the_object
  *  is undefined.
+ *  A returned object is actually of type Objects_MP_Control which has nothing
+ *  to do with Objects_Control.  So, be careful.  This is actually a hack to
+ *  simplify rtems_task_create().  The only useful operation with the returned
+ *  pointer is to pass it to _Objects_MP_Free_global_object().
  *  @param[in] information points to the object information table for this
  *             object class.
  *  @param[in] the_id is the Id of the object being opened.
  *  @param[in] location will contain the location of the object.
- *  @param[in] the_object will contain a pointer to the object.
- *  @retval This method fills in @a location to indicate successful location
+ *  @return This method fills in @a location to indicate successful location
  *          of the object or error.  On success, @a the_object will be
- *          filled in.
+ *          returned.
-void _Objects_MP_Is_remote (
+Objects_Control *_Objects_MP_Get_remote(
   Objects_Information  *information,
   Objects_Id            the_id,
-  Objects_Locations    *location,
-  Objects_Control     **the_object
+  Objects_Locations    *location
@@ -176,36 +179,16 @@ void _Objects_MP_Is_remote (
 extern uint32_t _Objects_MP_Maximum_global_objects;
- *  The following chain header is used to manage the set of
- *  inactive global object control blocks.
-extern Chain_Control _Objects_MP_Inactive_global_objects;
  * This function allocates a Global Object control block.
-RTEMS_INLINE_ROUTINE Objects_MP_Control *_Objects_MP_Allocate_global_object (
-  void
-  return (Objects_MP_Control *)
-           _Chain_Get( &_Objects_MP_Inactive_global_objects );
+Objects_MP_Control *_Objects_MP_Allocate_global_object( void );
  * This routine deallocates a Global Object control block.
-RTEMS_INLINE_ROUTINE void _Objects_MP_Free_global_object (
-  Objects_MP_Control *the_object
-  _Chain_Append(
-    &_Objects_MP_Inactive_global_objects,
-    &the_object->Object.Node
+void _Objects_MP_Free_global_object( Objects_MP_Control *the_object );
  * This function returns whether the global object is NULL or not.
diff --git a/cpukit/score/src/objectget.c b/cpukit/score/src/objectget.c
index 89fc59d..2610495 100644
--- a/cpukit/score/src/objectget.c
+++ b/cpukit/score/src/objectget.c
@@ -69,12 +69,10 @@ Objects_Control *_Objects_Get(
    *  it may be global in a multiprocessing system.  But it is clearly
    *  invalid on a single processor system.
-  *location = OBJECTS_ERROR;
-  _Objects_MP_Is_remote( information, id, location, &the_object );
-  return the_object;
+  return _Objects_MP_Get_remote( information, id, location );
 #else
+  *location = OBJECTS_ERROR;
   return NULL;
 #endif
diff --git a/cpukit/score/src/objectgetisr.c b/cpukit/score/src/objectgetisr.c
index b1212ac..d934e95 100644
--- a/cpukit/score/src/objectgetisr.c
+++ b/cpukit/score/src/objectgetisr.c
@@ -45,9 +45,9 @@ Objects_Control *_Objects_Get_isr_disable(
 #else
   return NULL;
 #endif
diff --git a/cpukit/score/src/objectinitializeinformation.c b/cpukit/score/src/objectinitializeinformation.c
index 3cd0c98..3149bb1 100644
--- a/cpukit/score/src/objectinitializeinformation.c
+++ b/cpukit/score/src/objectinitializeinformation.c
@@ -42,9 +42,6 @@ void _Objects_Initialize_information(
   static Objects_Control *null_local_table = NULL;
   uint32_t                minimum_index;
   Objects_Maximum         maximum_per_allocation;
-  #if defined(RTEMS_MULTIPROCESSING)
-    uint32_t              index;
-  #endif
   information->the_api            = the_api;
   information->the_class          = the_class;
@@ -131,18 +128,7 @@ void _Objects_Initialize_information(
     information->extract = extract;
-    if ( (supports_global == true) && _System_state_Is_multiprocessing ) {
-      information->global_table =
-        (Chain_Control *) _Workspace_Allocate_or_fatal_error(
-          (_Objects_Maximum_nodes + 1) * sizeof(Chain_Control)
-      for ( index=1; index <= _Objects_Maximum_nodes ; index++ )
-        _Chain_Initialize_empty( &information->global_table[ index ] );
-     else
-       information->global_table = NULL;
+    _RBTree_Initialize_empty( &information->Global_by_id );
+    _RBTree_Initialize_empty( &information->Global_by_name );
   #endif
diff --git a/cpukit/score/src/objectmp.c b/cpukit/score/src/objectmp.c
index c8f431f..fae5ca3 100644
--- a/cpukit/score/src/objectmp.c
+++ b/cpukit/score/src/objectmp.c
@@ -20,17 +20,141 @@
 #include <rtems/score/interr.h>
-#include <rtems/score/threaddispatch.h>
+#include <rtems/score/isrlock.h>
 #include <rtems/config.h>
+#define OBJECTS_MP_CONTROL_OF_ID_LOOKUP_NODE( node ) \
+  RTEMS_CONTAINER_OF( node, Objects_MP_Control, Nodes.Active.Id_lookup )
+#define OBJECTS_MP_CONTROL_OF_NAME_LOOKUP_NODE( node ) \
+  RTEMS_CONTAINER_OF( node, Objects_MP_Control, Nodes.Active.Name_lookup )
+typedef struct {
+  uint32_t name;
+  uint32_t node;
+} Objects_MP_Name_and_node;
 uint16_t _Objects_Local_node;
 uint16_t _Objects_Maximum_nodes;
-Chain_Control _Objects_MP_Inactive_global_objects;
+static CHAIN_DEFINE_EMPTY( _Objects_MP_Inactive_global_objects );
+ISR_LOCK_DEFINE( static, _Objects_MP_Global_lock, "MP Objects" )
+static void _Objects_MP_Global_acquire( ISR_lock_Context *lock_context )
+  _ISR_lock_ISR_disable_and_acquire( &_Objects_MP_Global_lock, lock_context );
+static void _Objects_MP_Global_release( ISR_lock_Context *lock_context )
+  _ISR_lock_Release_and_ISR_enable( &_Objects_MP_Global_lock, lock_context );
+static bool _Objects_MP_Id_equal(
+  const void        *left,
+  const RBTree_Node *right
+  const Objects_Id         *the_left;
+  const Objects_MP_Control *the_right;
+  the_left = left;
+  the_right = OBJECTS_MP_CONTROL_OF_ID_LOOKUP_NODE( right );
+  return *the_left == the_right->id;
+static bool _Objects_MP_Id_less(
+  const void        *left,
+  the_left = left;
+  return *the_left < the_right->id;
+static void *_Objects_MP_Id_adjust( RBTree_Node *node )
+  return OBJECTS_MP_CONTROL_OF_ID_LOOKUP_NODE( node );
+static bool _Objects_MP_Name_equal(
+  const void        *left,
+  const uint32_t           *the_left;
+  the_left = left;
+  the_right = OBJECTS_MP_CONTROL_OF_NAME_LOOKUP_NODE( right );
+  return *the_left == the_right->name;
+static bool _Objects_MP_Name_less(
+  const void        *left,
+  the_left = left;
+  return *the_left < the_right->name;
+static void *_Objects_MP_Name_adjust( RBTree_Node *node )
+  return OBJECTS_MP_CONTROL_OF_NAME_LOOKUP_NODE( node );
+static bool _Objects_MP_Name_and_node_equal(
+  const void        *left,
+  const Objects_MP_Name_and_node *the_left;
+  the_left = left;
+  return the_left->name == the_right->name
+    && the_left->node == _Objects_Get_node( the_right->id );
+static bool _Objects_MP_Name_and_node_less(
+  const void        *left,
+  the_left = left;
+   * Use > for the node to find smaller numbered nodes first in case of equal
+   * names.
+  return the_left->name < the_right->name
+    || ( the_left->name == the_right->name
+      && the_left->node > _Objects_Get_node( the_right->id ) );
 void _Objects_MP_Handler_early_initialization(void)
@@ -51,22 +175,15 @@ void _Objects_MP_Handler_early_initialization(void)
   _Objects_Maximum_nodes = maximum_nodes;
- *  _Objects_MP_Handler_initialization
-void _Objects_MP_Handler_initialization(void)
+void _Objects_MP_Handler_initialization( void )
-  uint32_t   maximum_global_objects;
+  uint32_t maximum_global_objects;
   maximum_global_objects = _Configuration_MP_table->maximum_global_objects;
   _Objects_MP_Maximum_global_objects = maximum_global_objects;
   if ( maximum_global_objects == 0 ) {
-    _Chain_Initialize_empty( &_Objects_MP_Inactive_global_objects );
     return;
@@ -78,7 +195,6 @@ void _Objects_MP_Handler_initialization(void)
     maximum_global_objects,
     sizeof( Objects_MP_Control )
 void _Objects_MP_Open (
@@ -88,16 +204,31 @@ void _Objects_MP_Open (
   Objects_Id           the_id
-  the_global_object->Object.id = the_id;
-  the_global_object->name      = the_name;
+  Objects_MP_Name_and_node name_and_node;
+  ISR_lock_Context         lock_context;
-  _Assert( _Objects_Allocator_is_owner() );
+  the_global_object->id = the_id;
+  the_global_object->name = the_name;
-  _Chain_Prepend_unprotected(
-    &information->global_table[ _Objects_Get_node( the_id ) ],
-    &the_global_object->Object.Node
+  name_and_node.name = the_name;
+  name_and_node.node = _Objects_Get_node( the_id );
+  _Objects_MP_Global_acquire( &lock_context );
+  _RBTree_Insert_inline(
+    &information->Global_by_id,
+    &the_global_object->Nodes.Active.Id_lookup,
+    &the_id,
+    _Objects_MP_Id_less
+    &information->Global_by_name,
+    &the_global_object->Nodes.Active.Name_lookup,
+    &name_and_node,
+    _Objects_MP_Name_and_node_less
+  _Objects_MP_Global_release( &lock_context );
 bool _Objects_MP_Allocate_and_open (
@@ -133,152 +264,147 @@ void _Objects_MP_Close (
   Objects_Id           the_id
-  Chain_Control      *the_chain;
-  Chain_Node         *the_node;
-  Objects_MP_Control *the_object;
-  the_chain = &information->global_table[ _Objects_Get_node( the_id ) ];
-  for ( the_node = _Chain_First( the_chain ) ;
-        !_Chain_Is_tail( the_chain, the_node ) ;
-        the_node = _Chain_Next( the_node ) ) {
+  Objects_MP_Control *the_global_object;
-    the_object = (Objects_MP_Control *) the_node;
-    if ( _Objects_Are_ids_equal( the_object->Object.id, the_id ) ) {
+  the_global_object = _RBTree_Find_inline(
+    &the_id,
+    _Objects_MP_Id_equal,
+    _Objects_MP_Id_less,
+    _Objects_MP_Id_adjust
-      _Chain_Extract_unprotected( the_node );
-      _Objects_MP_Free_global_object( the_object );
-      return;
+  if ( the_global_object != NULL ) {
+    _RBTree_Extract(
+    _RBTree_Extract(
+    _Objects_MP_Free_global_object( the_global_object );
+  } else {
+    _Terminate(
+      INTERNAL_ERROR_CORE,
+      true,
+      INTERNAL_ERROR_INVALID_GLOBAL_ID
-  _Terminate(
-    INTERNAL_ERROR_CORE,
-    true,
-    INTERNAL_ERROR_INVALID_GLOBAL_ID
-Objects_Name_or_id_lookup_errors _Objects_MP_Global_name_search (
+Objects_Name_or_id_lookup_errors _Objects_MP_Global_name_search(
   Objects_Name         the_name,
   uint32_t             nodes_to_search,
   Objects_Id          *the_id
-  uint32_t            low_node;
-  uint32_t            high_node;
-  uint32_t            node_index;
-  uint32_t            name_to_use;
-  name_to_use = the_name.name_u32;  /* XXX only fixed length names */
+  Objects_Name_or_id_lookup_errors  status;
-  if ( nodes_to_search > _Objects_Maximum_nodes )
+  if ( nodes_to_search > _Objects_Maximum_nodes ) {
     return OBJECTS_INVALID_NODE;
-  if ( information->global_table == NULL )
-    return OBJECTS_INVALID_NAME;
-  if ( nodes_to_search == OBJECTS_SEARCH_ALL_NODES ||
-       nodes_to_search == OBJECTS_SEARCH_OTHER_NODES ) {
-    low_node = 1;
-    high_node = _Objects_Maximum_nodes;
-  } else {
-    low_node  =
-    high_node = nodes_to_search;
-  _Objects_Allocator_lock();
-  for ( node_index = low_node ; node_index <= high_node ; node_index++ ) {
-     *  NOTE: The local node was search (if necessary) by
-     *        _Objects_Name_to_id_XXX before this was invoked.
-    if ( !_Objects_Is_local_node( node_index ) ) {
-      the_chain = &information->global_table[ node_index ];
+  if ( nodes_to_search == OBJECTS_SEARCH_ALL_NODES ) {
+      &the_name.name_u32,
+      _Objects_MP_Name_equal,
+      _Objects_MP_Name_less,
+      _Objects_MP_Name_adjust
+  } else {
+    name_and_node.name = the_name.name_u32;
+    name_and_node.node = nodes_to_search;
+      &name_and_node,
+      _Objects_MP_Name_and_node_equal,
+      _Objects_MP_Name_and_node_less,
-        if ( the_object->name == name_to_use ) {
-          *the_id = the_object->Object.id;
-          _Objects_Allocator_unlock();
-          return OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL;
+    *the_id = the_global_object->id;
+    status = OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL;
+  } else {
+    status = OBJECTS_INVALID_NAME;
+  return status;
   Objects_Id            the_id,
-  uint32_t            node;
-  node = _Objects_Get_node( the_id );
-   *        The NODE field of an object id cannot be 0
-   *        because 0 is an invalid node number.
+    &the_id,
-  if ( node == 0 ||
-       _Objects_Is_local_node( node ) ||
-       node > _Objects_Maximum_nodes ||
-       information->global_table == NULL ) {
-    *the_object = NULL;
-    return;
+    *location = OBJECTS_REMOTE;
+  } else {
+  return (Objects_Control *) the_global_object;
-  the_chain = &information->global_table[ node ];
-    the_global_object = (Objects_MP_Control *) the_node;
+  the_global_object = (Objects_MP_Control *)
+    _Chain_Get_unprotected( &_Objects_MP_Inactive_global_objects );
-    if ( _Objects_Are_ids_equal( the_global_object->Object.id, the_id ) ) {
-      *location   = OBJECTS_REMOTE;
-      *the_object = (Objects_Control *) the_global_object;
-      return;
+  return the_global_object;
+void _Objects_MP_Free_global_object( Objects_MP_Control *the_global_object )
+  _Chain_Append_unprotected(
+    &_Objects_MP_Inactive_global_objects,
+    &the_global_object->Nodes.Inactive
diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
index 251ed36..3414ec0 100644
--- a/testsuites/sptests/spsize/size.c
+++ b/testsuites/sptests/spsize/size.c
@@ -315,11 +315,6 @@ uninitialized =
                 (sizeof _Objects_Maximum_nodes)           +
                 (sizeof _Objects_Information_table)       +
-#if defined(RTEMS_MULTIPROCESSING)
-/*objectmp.h*/  (sizeof _Objects_MP_Maximum_global_objects) +
-                (sizeof _Objects_MP_Inactive_global_objects) +
-#endif
 /*options.h*/   0                                         +
 /*partimpl.h*/  (sizeof _Partition_Information)           +
1.8.4.5
