[PATCH] cpukit: pppd: fix compile warning
Tue Apr 5 14:23:00 UTC 2016
This should be fine. I don't know, does pppd have an active maintainer?
On Tue, Apr 5, 2016 at 8:45 AM, Peng Fan <van.freenix at gmail.com> wrote:
> rcsid is defined, but not used. So discard it.
> Signed-off-by: Peng Fan <van.freenix at gmail.com>
>  cpukit/pppd/auth.c      | 4 ----
>  cpukit/pppd/ccp.c       | 4 ----
>  cpukit/pppd/chap.c      | 4 ----
>  cpukit/pppd/demand.c    | 4 ----
>  cpukit/pppd/fsm.c       | 4 ----
>  cpukit/pppd/ipcp.c      | 4 ----
>  cpukit/pppd/lcp.c       | 4 ----
>  cpukit/pppd/magic.c     | 4 ----
>  cpukit/pppd/options.c   | 4 ----
>  cpukit/pppd/rtemsmain.c | 4 ----
>  cpukit/pppd/sys-rtems.c | 5 -----
>  cpukit/pppd/upap.c      | 4 ----
>  cpukit/pppd/utils.c     | 4 ----
>  13 files changed, 53 deletions(-)
> diff --git a/cpukit/pppd/auth.c b/cpukit/pppd/auth.c
> index fb84f1e..9df1d32 100644
> --- a/cpukit/pppd/auth.c
> +++ b/cpukit/pppd/auth.c
> @@ -32,8 +32,6 @@
>   * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
> -#define RCSID  "$Id$"
>  #include <stdio.h>
>  #include <stddef.h>
>  #include <stdlib.h>
> @@ -75,8 +73,6 @@
>  #endif
>  #include "pathnames.h"
> -static const char rcsid[] = RCSID;
>  /* The name by which the peer authenticated itself to us. */
>  char peer_authname[MAXNAMELEN];
> diff --git a/cpukit/pppd/ccp.c b/cpukit/pppd/ccp.c
> index d80df27..6ada96c 100644
> --- a/cpukit/pppd/ccp.c
> +++ b/cpukit/pppd/ccp.c
> @@ -25,8 +25,6 @@
>   * OR MODIFICATIONS.
>  #include <stdlib.h>
>  #include <string.h>
> @@ -35,8 +33,6 @@
>  #include "ccp.h"
>  #include <net/ppp_comp.h>
>   * Command-line options.
> diff --git a/cpukit/pppd/chap.c b/cpukit/pppd/chap.c
> index 3fe766f..55f1896 100644
> --- a/cpukit/pppd/chap.c
> +++ b/cpukit/pppd/chap.c
> @@ -33,8 +33,6 @@
>   * TODO:
> @@ -52,8 +50,6 @@
>  #include "chap_ms.h"
>  #endif
> diff --git a/cpukit/pppd/demand.c b/cpukit/pppd/demand.c
> index a094a15..a5c13f7 100644
> --- a/cpukit/pppd/demand.c
> +++ b/cpukit/pppd/demand.c
> @@ -17,8 +17,6 @@
> -#define RCSID  "$Id$";
>  #include <stdio.h>
>  #include <stdlib.h>
>  #include <string.h>
> @@ -43,8 +41,6 @@
>  #include "ipcp.h"
>  #include "lcp.h"
>  static unsigned char *frame;
>  static int framelen;
>  static int framemax;
> diff --git a/cpukit/pppd/fsm.c b/cpukit/pppd/fsm.c
> index ce06401..4ff17d8 100644
> --- a/cpukit/pppd/fsm.c
> +++ b/cpukit/pppd/fsm.c
> @@ -17,8 +17,6 @@
>   * TODO:
>   * Randomize fsm id on link/init.
> @@ -32,8 +30,6 @@
>  #include "pppd.h"
>  #include "fsm.h"
>  static void fsm_timeout(void *);
>  static void fsm_rconfreq(fsm *, u_char, u_char *, int);
>  static void fsm_rconfack(fsm *, int, u_char *, int);
> diff --git a/cpukit/pppd/ipcp.c b/cpukit/pppd/ipcp.c
> index fd23ddd..a9a8f24 100644
> --- a/cpukit/pppd/ipcp.c
> +++ b/cpukit/pppd/ipcp.c
> @@ -17,8 +17,6 @@
>   * TODO:
> @@ -40,8 +38,6 @@
>  #include <rtems/bsdnet/servers.h>
>  /* global vars */
>  ipcp_options ipcp_wantoptions[NUM_PPP];        /* Options that we want to request */
>  ipcp_options ipcp_gotoptions[NUM_PPP]; /* Options that peer ack'd */
> diff --git a/cpukit/pppd/lcp.c b/cpukit/pppd/lcp.c
> index 9da1326..e09e8fb 100644
> --- a/cpukit/pppd/lcp.c
> +++ b/cpukit/pppd/lcp.c
> @@ -17,8 +17,6 @@
>   * TODO:
> @@ -33,8 +31,6 @@
>  #include "chap.h"
>  #include "magic.h"
>   * LCP-related command-line options.
> diff --git a/cpukit/pppd/magic.c b/cpukit/pppd/magic.c
> index 3d297e5..46add2f 100644
> --- a/cpukit/pppd/magic.c
> +++ b/cpukit/pppd/magic.c
> @@ -17,8 +17,6 @@
>  #include <stdio.h>
>  #include <stdlib.h>
>  #include <unistd.h>
> @@ -28,8 +26,6 @@
>  #include "pppd.h"
>  #include "magic.h"
>   * magic_init - Initialize the magic number generator.
> diff --git a/cpukit/pppd/options.c b/cpukit/pppd/options.c
> index 8a39266..9086e55 100644
> --- a/cpukit/pppd/options.c
> +++ b/cpukit/pppd/options.c
> @@ -17,8 +17,6 @@
>  #include <ctype.h>
>  #include <stdio.h>
>  #include <errno.h>
> @@ -53,8 +51,6 @@
>   * Option variables and default values.
> diff --git a/cpukit/pppd/rtemsmain.c b/cpukit/pppd/rtemsmain.c
> index 89ed776..030bebe 100644
> --- a/cpukit/pppd/rtemsmain.c
> +++ b/cpukit/pppd/rtemsmain.c
> @@ -17,8 +17,6 @@
>  #include <stdio.h>
>  #include <ctype.h>
>  #include <stdlib.h>
> @@ -68,8 +66,6 @@
>  #include "atcp.h"
>  #endif
>  /* interface vars */
>  char ifname[32];               /* Interface name */
>  int pppifunit;                 /* Interface unit number */
> diff --git a/cpukit/pppd/sys-rtems.c b/cpukit/pppd/sys-rtems.c
> index ac87957..3fdca9e 100644
> --- a/cpukit/pppd/sys-rtems.c
> +++ b/cpukit/pppd/sys-rtems.c
> @@ -20,8 +20,6 @@
>  #include <stdio.h>
>  #include <string.h>
>  #include <stdlib.h>
> @@ -66,9 +64,6 @@ extern rtems_id rtems_pppd_taskid;
>  #include "fsm.h"
>  #include "ipcp.h"
>  static int initdisc = -1;      /* Initial TTY discipline for ppp_fd */
>  static int initfdflags = -1;   /* Initial file descriptor flags for ppp_fd */
>  static int ppp_fd = -1;                /* fd which is set to PPP discipline */
> diff --git a/cpukit/pppd/upap.c b/cpukit/pppd/upap.c
> index e8115a6..55700c5 100644
> --- a/cpukit/pppd/upap.c
> +++ b/cpukit/pppd/upap.c
> @@ -17,8 +17,6 @@
>   * TODO:
> @@ -29,8 +27,6 @@
>  #include "pppd.h"
>  #include "upap.h"
>  static bool hide_password = true;
> diff --git a/cpukit/pppd/utils.c b/cpukit/pppd/utils.c
> index af39226..cb1dab3 100644
> --- a/cpukit/pppd/utils.c
> +++ b/cpukit/pppd/utils.c
> @@ -17,8 +17,6 @@
>  #include <stdio.h>
>  #include <ctype.h>
>  #include <stdlib.h>
> @@ -44,8 +42,6 @@
>  #include "pppd.h"
>  static void pr_log(void *, char *, ...);
>  static void logit(int, char *, va_list);
>  static void vslp_printer(void *, char *, ...);
> 2.6.2
> devel mailing list
> devel at rtems.org
