[PATCH 04/15] score: Add node adjust to _RBTree_Find_inline()
Tue Apr 5 15:35:49 UTC 2016
----- Gedare Bloom <gedare at rtems.org> schrieb:
> I don't understand the name "adjust"? I think of adjusting as
> something that would cause a change or modify, which is not the case
> here. I don't have any great replacement, but I guess I might suggest
> "dereference"?
You may adjust the pointer value, e.g. node + offset.  Dereference is wrong, since you are not supposed to do a *node.  Maybe "fixup"?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
