[PATCH 06/15] score: Use red-black tree for active global objects
Tue Apr 5 15:37:53 UTC 2016
----- Gedare Bloom <gedare at rtems.org> schrieb:
> Generally ok. I have a question and comment.
> Would it make sense to unify the object management and use an rbtree
> in the uni/smp cases too?
You mean for Object_Control objects? No, this would be a performance problem I guess if you do a tree lookup each time you do a semaphore obtain/release instead of the table lookup.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
