[PATCH 04/15] score: Add node adjust to _RBTree_Find_inline()
Gedare Bloom
gedare at rtems.org
Tue Apr 5 14:27:54 UTC 2016
I don't understand the name "adjust"? I think of adjusting as
something that would cause a change or modify, which is not the case
here. I don't have any great replacement, but I guess I might suggest
"dereference"?
On Tue, Apr 5, 2016 at 9:09 AM, Sebastian Huber
> cpukit/posix/include/rtems/posix/keyimpl.h | 14 ++++++++++----
> cpukit/posix/src/keygetspecific.c | 15 ++++++---------
> cpukit/posix/src/keysetspecific.c | 29 +++++++++++++----------------
> cpukit/score/include/rtems/score/rbtree.h | 12 ++++++++----
> 4 files changed, 37 insertions(+), 33 deletions(-)
> diff --git a/cpukit/posix/include/rtems/posix/keyimpl.h b/cpukit/posix/include/rtems/posix/keyimpl.h
> index 7095a16..a534b7e 100644
> --- a/cpukit/posix/include/rtems/posix/keyimpl.h
> +++ b/cpukit/posix/include/rtems/posix/keyimpl.h
> @@ -139,16 +139,22 @@ RTEMS_INLINE_ROUTINE bool _POSIX_Keys_Key_value_less(
> return *the_left < the_right->key;
> -RTEMS_INLINE_ROUTINE RBTree_Node *_POSIX_Keys_Key_value_find(
> - pthread_key_t key,
> - Thread_Control *the_thread
> +RTEMS_INLINE_ROUTINE void *_POSIX_Keys_Key_value_adjust( RBTree_Node *node )
> + return POSIX_KEYS_RBTREE_NODE_TO_KEY_VALUE_PAIR( node );
> +RTEMS_INLINE_ROUTINE POSIX_Keys_Key_value_pair *_POSIX_Keys_Key_value_find(
> + pthread_key_t key,
> + Thread_Control *the_thread
> return _RBTree_Find_inline(
> &the_thread->Keys.Key_value_pairs,
> &key,
> _POSIX_Keys_Key_value_equal,
> - _POSIX_Keys_Key_value_less
> + _POSIX_Keys_Key_value_less,
> + _POSIX_Keys_Key_value_adjust
> diff --git a/cpukit/posix/src/keygetspecific.c b/cpukit/posix/src/keygetspecific.c
> index 08ac1ed..ae29955 100644
> --- a/cpukit/posix/src/keygetspecific.c
> +++ b/cpukit/posix/src/keygetspecific.c
> @@ -30,20 +30,17 @@ void *pthread_getspecific(
> pthread_key_t key
> - Thread_Control *executing;
> - ISR_lock_Context lock_context;
> - RBTree_Node *node;
> - void *value;
> + Thread_Control *executing;
> + ISR_lock_Context lock_context;
> + POSIX_Keys_Key_value_pair *key_value_pair;
> + void *value;
> executing = _Thread_Get_executing();
> _POSIX_Keys_Key_value_acquire( executing, &lock_context );
> - node = _POSIX_Keys_Key_value_find( key, executing );
> + key_value_pair = _POSIX_Keys_Key_value_find( key, executing );
> - if ( node != NULL ) {
> - POSIX_Keys_Key_value_pair *key_value_pair;
> - key_value_pair = POSIX_KEYS_RBTREE_NODE_TO_KEY_VALUE_PAIR( node );
> + if ( key_value_pair != NULL ) {
> value = key_value_pair->value;
> } else {
> value = NULL;
> diff --git a/cpukit/posix/src/keysetspecific.c b/cpukit/posix/src/keysetspecific.c
> index 8b0f517..7034d8e 100644
> --- a/cpukit/posix/src/keysetspecific.c
> +++ b/cpukit/posix/src/keysetspecific.c
> @@ -24,11 +24,11 @@
> #include <errno.h>
> -static int _POSIX_Keys_Set_value( RBTree_Node *node, const void *value )
> +static int _POSIX_Keys_Set_value(
> + POSIX_Keys_Key_value_pair *key_value_pair,
> + const void *value
> key_value_pair->value = RTEMS_DECONST( void *, value );
> return 0;
> @@ -91,16 +91,13 @@ static int _POSIX_Keys_Delete_value(
> the_key = _POSIX_Keys_Get( key );
> if ( the_key != NULL ) {
> _RBTree_Extract(
> &executing->Keys.Key_value_pairs,
> &key_value_pair->Lookup_node
> @@ -138,14 +135,14 @@ int pthread_setspecific(
> if ( value != NULL ) {
> - eno = _POSIX_Keys_Set_value( node, value );
> + eno = _POSIX_Keys_Set_value( key_value_pair, value );
> _POSIX_Keys_Key_value_release( executing, &lock_context );
> } else {
> diff --git a/cpukit/score/include/rtems/score/rbtree.h b/cpukit/score/include/rtems/score/rbtree.h
> index 2057612..1d17365 100644
> --- a/cpukit/score/include/rtems/score/rbtree.h
> +++ b/cpukit/score/include/rtems/score/rbtree.h
> @@ -532,15 +532,19 @@ RTEMS_INLINE_ROUTINE void _RBTree_Insert_inline(
> * node, otherwise false.
> * @param less Must return true if the specified key is less than the key of
> * the node, otherwise false.
> + * @param adjust In case a node is found, then this function is called to get
> + * the return value. Usually it performs some offset operation via
> + * RTEMS_CONTAINER_OF().
> - * @retval node A node with the specified key.
> + * @retval node An adjusted node with the specified key.
> * @retval NULL No node with the specified key exists in the red-black tree.
> -RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Find_inline(
> +RTEMS_INLINE_ROUTINE void *_RBTree_Find_inline(
> RBTree_Control *the_rbtree,
> const void *key,
> bool ( *equal )( const void *, const RBTree_Node * ),
> - bool ( *less )( const void *, const RBTree_Node * )
> + bool ( *less )( const void *, const RBTree_Node * ),
> + void *( *adjust )( RBTree_Node * )
> RBTree_Node **link;
> @@ -553,7 +557,7 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Find_inline(
> parent = *link;
> if ( ( *equal )( key, parent ) ) {
> - return parent;
> + return ( *adjust )( parent );
> } else if ( ( *less )( key, parent ) ) {
> link = _RBTree_Left_reference( parent );
> } else {
> 1.8.4.5
> devel mailing list
> devel at rtems.org
