Move POSIX network headers like <sys/socket.h> etc. to Newlib?
Thu Apr 7 09:25:54 UTC 2016
On 07/04/16 11:05, Chris Johns wrote:
> On 7/04/2016 4:45 PM, Sebastian Huber wrote:
>> Hello,
>> what about moving the POSIX network headers
>> arpa/inet.h
>> netdb.h
>> net/if.h
>> netinet/in.h
>> netinet/tcp.h
>> syslog.h
>> sys/socket.h
>> sys/uio.h
>> sys/un.h
>> to Newlib?
> Where are these taken from?
 From the POSIX standard:
http://pubs.opengroup.org/onlinepubs/9699919799/
http://pubs.opengroup.org/onlinepubs/9699919799/idx/head.html
> Do they allow the in-tree stack to build? [1]
Probably not without modifications, but it is the goal. Before we start
working on this we have to be sure that the general change is acceptable.
>> This has the following benefits.
>> 1. It ensures compatibility between the standard and libbsd network
>> stack at user API level.
> Would this have to have a broader reach than just libbsd? What about
> other parts of the networking software API a package may depend on?
> How are those parts added onto this base level?
> For example I have an app which also includes ..
>  #include <net/if_types.h>
>  #include <net/if_dl.h>
>  #include <sys/sockio.h>
These header are not defined by POSIX. However, it probably makes sense
to add the usual network headers as well.
> Would we support all these?
> Maybe looking at boosts source for asio would be worth doing.
Yes, but we do not plan to work on this.
>> 2. These files may be used by lwIP to provide the standard API.
> Is this something to be added to lwIP or this is there now?
As far as I know lwIP doesn't provide the standard headers. They must be
supplied externally.
>> 3. It allows 3rd party code depending only on the POSIX network headers
>> to build without RTEMS, e.g. GCC Ada and Go languages, libressl library
>> etc. Allows build of libraries per multilib.
> Does this mean networking is always shown to be present even if the
> user does not want to enable networking functionality in a 3rd party
> package?
Yes, in case it only checks the header files.
> If this helps us remove the in-tree stack from the source tree I am
> all for it.
> Would this allow the existing NSF client to build with the new stack?
I don't think so, due to the dependency on the RPC support (which is a
real hack and a ticking security bomb).
> In general I think this is a good idea, however I do see some detail
> we need to sort out. Thanks for raising this.
> Chris
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
