Move POSIX network headers like <sys/socket.h> etc. to Newlib?
Thu Apr 7 10:56:29 UTC 2016
On 07/04/16 11:56, Chris Johns wrote:
> On 7/04/2016 7:25 PM, Sebastian Huber wrote:
>> On 07/04/16 11:05, Chris Johns wrote:
>>> Do they allow the in-tree stack to build? [1]
>> Probably not without modifications, but it is the goal.
> Removing the stack from RTEMS is something I would like to see happen
> but this effects the other networking code in the tree.
> The plan is to make the stack build externally.
>> Before we start
>> working on this we have to be sure that the general change is
>> acceptable.
> What sort of time frame are you thinking about?
Our primary goal is to make it possible to compile libressl per multilib
and to simplify the standard/libbsd stack handling. We only have a very
limited time budget for this and is should be available as soon as possible.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
