[PATCH 1/2] Move kernel dependent parts of <sys/time.h>
Thu Apr 7 10:58:43 UTC 2016
Move the kernel dependent parts of <sys/time.h> to new system-specific
header file <machine/_time.h>.  Provide an empty default implementation.
Add a specialized implementation for RTEMS.
Signed-off-by: Sebastian Huber <sebastian.huber at embedded-brains.de>
 newlib/libc/include/machine/_time.h           |   3 +
 newlib/libc/include/sys/time.h                | 151 +------------------
 newlib/libc/sys/rtems/include/machine/_time.h | 199 ++++++++++++++++++++++++++
 3 files changed, 204 insertions(+), 149 deletions(-)
 create mode 100644 newlib/libc/include/machine/_time.h
 create mode 100644 newlib/libc/sys/rtems/include/machine/_time.h
diff --git a/newlib/libc/include/machine/_time.h b/newlib/libc/include/machine/_time.h
new file mode 100644
index 0000000..476760c
--- /dev/null
+++ b/newlib/libc/include/machine/_time.h
@@ -0,0 +1,3 @@
+#ifndef _SYS_TIME_H_
+#error "must be included via <sys/time.h>"
+#endif /* !_SYS_TIME_H_ */
diff --git a/newlib/libc/include/sys/time.h b/newlib/libc/include/sys/time.h
index 326d1a6..84c2ad2 100644
--- a/newlib/libc/include/sys/time.h
+++ b/newlib/libc/include/sys/time.h
@@ -251,47 +251,6 @@ tvtosbt(struct timeval _tv)
 #endif /* __BSD_VISIBLE */
-#ifdef _KERNEL
-/* Operations on timespecs */
-#define	timespecclear(tvp)	((tvp)->tv_sec = (tvp)->tv_nsec = 0)
-#define	timespecisset(tvp)	((tvp)->tv_sec || (tvp)->tv_nsec)
-#define	timespeccmp(tvp, uvp, cmp)					\
-	(((tvp)->tv_sec == (uvp)->tv_sec) ?				\
-	    ((tvp)->tv_nsec cmp (uvp)->tv_nsec) :			\
-	    ((tvp)->tv_sec cmp (uvp)->tv_sec))
-#define	timespecadd(vvp, uvp)						\
-	do {								\
-		(vvp)->tv_sec += (uvp)->tv_sec;				\
-		(vvp)->tv_nsec += (uvp)->tv_nsec;			\
-		if ((vvp)->tv_nsec >= 1000000000) {			\
-			(vvp)->tv_sec++;				\
-			(vvp)->tv_nsec -= 1000000000;			\
-	} while (0)
-#define	timespecsub(vvp, uvp)						\
-	do {								\
-		(vvp)->tv_sec -= (uvp)->tv_sec;				\
-		(vvp)->tv_nsec -= (uvp)->tv_nsec;			\
-		if ((vvp)->tv_nsec < 0) {				\
-			(vvp)->tv_sec--;				\
-			(vvp)->tv_nsec += 1000000000;			\
-	} while (0)
-/* Operations on timevals. */
-#define	timevalclear(tvp)		((tvp)->tv_sec = (tvp)->tv_usec = 0)
-#define	timevalisset(tvp)		((tvp)->tv_sec || (tvp)->tv_usec)
-#define	timevalcmp(tvp, uvp, cmp)					\
-	    ((tvp)->tv_usec cmp (uvp)->tv_usec) :			\
-/* timevaladd and timevalsub are not inlined */
-#endif /* _KERNEL */
  * Names of the interval timers, and structure
  * defining a timer setting.
@@ -305,116 +264,9 @@ struct itimerval {
 	struct	timeval it_value;	/* current value */
-#ifdef _KERNEL
- * Kernel to clock driver interface.
-void	inittodr(time_t base);
-void	resettodr(void);
-extern volatile time_t	time_second;
-extern volatile time_t	time_uptime;
-extern struct bintime boottimebin;
-extern struct timeval boottime;
-extern struct bintime tc_tick_bt;
-extern sbintime_t tc_tick_sbt;
-extern struct bintime tick_bt;
-extern sbintime_t tick_sbt;
-extern int tc_precexp;
-extern int tc_timepercentage;
-extern struct bintime bt_timethreshold;
-extern struct bintime bt_tickthreshold;
-extern sbintime_t sbt_timethreshold;
-extern sbintime_t sbt_tickthreshold;
- * Functions for looking at our clock: [get]{bin,nano,micro}[up]time()
- * Functions without the "get" prefix returns the best timestamp
- * we can produce in the given format.
- * "bin"   == struct bintime  == seconds + 64 bit fraction of seconds.
- * "nano"  == struct timespec == seconds + nanoseconds.
- * "micro" == struct timeval  == seconds + microseconds.
- * Functions containing "up" returns time relative to boot and
- * should be used for calculating time intervals.
- * Functions without "up" returns UTC time.
- * Functions with the "get" prefix returns a less precise result
- * much faster than the functions without "get" prefix and should
- * be used where a precision of 1/hz seconds is acceptable or where
- * performance is priority. (NB: "precision", _not_ "resolution" !)
-void	binuptime(struct bintime *bt);
-void	nanouptime(struct timespec *tsp);
-void	microuptime(struct timeval *tvp);
-static __inline sbintime_t
-sbinuptime(void)
-	struct bintime _bt;
-	binuptime(&_bt);
-	return (bttosbt(_bt));
-void	bintime(struct bintime *bt);
-void	nanotime(struct timespec *tsp);
-void	microtime(struct timeval *tvp);
-void	getbinuptime(struct bintime *bt);
-void	getnanouptime(struct timespec *tsp);
-void	getmicrouptime(struct timeval *tvp);
-getsbinuptime(void)
-	getbinuptime(&_bt);
-void	getbintime(struct bintime *bt);
-void	getnanotime(struct timespec *tsp);
-void	getmicrotime(struct timeval *tvp);
-/* Other functions */
-int	itimerdecr(struct itimerval *itp, int usec);
-int	itimerfix(struct timeval *tv);
-int	ppsratecheck(struct timeval *, int *, int);
-int	ratecheck(struct timeval *, const struct timeval *);
-void	timevaladd(struct timeval *t1, const struct timeval *t2);
-void	timevalsub(struct timeval *t1, const struct timeval *t2);
-int	tvtohz(struct timeval *tv);
-#define	TC_DEFAULTPERC		5
-#define	BT2FREQ(bt)                                                     \
-	(((uint64_t)0x8000000000000000 + ((bt)->frac >> 2)) /           \
-	    ((bt)->frac >> 1))
-#define	SBT2FREQ(sbt)	((SBT_1S + ((sbt) >> 1)) / (sbt))
-#define	FREQ2BT(freq, bt)                                               \
-	(bt)->sec = 0;                                                  \
-	(bt)->frac = ((uint64_t)0x8000000000000000  / (freq)) << 1;     \
-#define	TIMESEL(sbt, sbt2)						\
-	(((sbt2) >= sbt_timethreshold) ?				\
-	    ((*(sbt) = getsbinuptime()), 1) : ((*(sbt) = sbinuptime()), 0))
-#else /* !_KERNEL */
+#ifndef _KERNEL
 #include <time.h>
-#include <sys/cdefs.h>
 __BEGIN_DECLS
 int _EXFUN(utimes, (const char *__path, const struct timeval *__tvp));
@@ -444,5 +296,6 @@ int _EXFUN(_gettimeofday, (struct timeval *__p, void *__tz));
 __END_DECLS
 #endif /* !_KERNEL */
+#include <machine/_time.h>
diff --git a/newlib/libc/sys/rtems/include/machine/_time.h b/newlib/libc/sys/rtems/include/machine/_time.h
index 0000000..44a220d
--- /dev/null
+++ b/newlib/libc/sys/rtems/include/machine/_time.h
@@ -0,0 +1,199 @@
+ * Copyright (c) 1982, 1986, 1993
+ *	The Regents of the University of California.  All rights reserved.
+ * are met:
+ * 4. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ *	@(#)time.h	8.5 (Berkeley) 5/4/95
+ * $FreeBSD$
+#else /* _SYS_TIME_H_ */
+__BEGIN_DECLS
+extern volatile time_t _Timecounter_Time_second;
+extern volatile time_t _Timecounter_Time_uptime;
+extern struct bintime _Timecounter_Boottimebin;
+void	_Timecounter_Binuptime(struct bintime *);
+void	_Timecounter_Nanouptime(struct timespec *);
+void	_Timecounter_Microuptime(struct timeval *);
+void	_Timecounter_Bintime(struct bintime *);
+void	_Timecounter_Nanotime(struct timespec *);
+void	_Timecounter_Microtime(struct timeval *);
+void	_Timecounter_Getbinuptime(struct bintime *);
+void	_Timecounter_Getnanouptime(struct timespec *);
+void	_Timecounter_Getmicrouptime(struct timeval *);
+void	_Timecounter_Getbintime(struct bintime *);
+void	_Timecounter_Getnanotime(struct timespec *);
+void	_Timecounter_Getmicrotime(struct timeval *);
+__END_DECLS
+#ifdef _KERNEL
+/* Operations on timespecs */
+#define	timespecclear(tvp)	((tvp)->tv_sec = (tvp)->tv_nsec = 0)
+#define	timespecisset(tvp)	((tvp)->tv_sec || (tvp)->tv_nsec)
+#define	timespeccmp(tvp, uvp, cmp)					\
+	(((tvp)->tv_sec == (uvp)->tv_sec) ?				\
+	    ((tvp)->tv_nsec cmp (uvp)->tv_nsec) :			\
+	    ((tvp)->tv_sec cmp (uvp)->tv_sec))
+#define	timespecadd(vvp, uvp)						\
+	do {								\
+		(vvp)->tv_sec += (uvp)->tv_sec;				\
+		(vvp)->tv_nsec += (uvp)->tv_nsec;			\
+		if ((vvp)->tv_nsec >= 1000000000) {			\
+			(vvp)->tv_sec++;				\
+			(vvp)->tv_nsec -= 1000000000;			\
+	} while (0)
+#define	timespecsub(vvp, uvp)						\
+	do {								\
+		(vvp)->tv_sec -= (uvp)->tv_sec;				\
+		(vvp)->tv_nsec -= (uvp)->tv_nsec;			\
+		if ((vvp)->tv_nsec < 0) {				\
+			(vvp)->tv_sec--;				\
+			(vvp)->tv_nsec += 1000000000;			\
+	} while (0)
+/* Operations on timevals. */
+#define	timevalclear(tvp)		((tvp)->tv_sec = (tvp)->tv_usec = 0)
+#define	timevalisset(tvp)		((tvp)->tv_sec || (tvp)->tv_usec)
+#define	timevalcmp(tvp, uvp, cmp)					\
+	    ((tvp)->tv_usec cmp (uvp)->tv_usec) :			\
+/* timevaladd and timevalsub are not inlined */
+ * Kernel to clock driver interface.
+void	inittodr(time_t base);
+void	resettodr(void);
+#define	time_second _Timecounter_Time_second
+#define	time_uptime _Timecounter_Time_uptime
+#define	boottimebin _Timecounter_Boottimebin
+extern struct timeval boottime;
+extern struct bintime tc_tick_bt;
+extern sbintime_t tc_tick_sbt;
+extern struct bintime tick_bt;
+extern sbintime_t tick_sbt;
+extern int tc_precexp;
+extern int tc_timepercentage;
+extern struct bintime bt_timethreshold;
+extern struct bintime bt_tickthreshold;
+extern sbintime_t sbt_timethreshold;
+extern sbintime_t sbt_tickthreshold;
+ * Functions for looking at our clock: [get]{bin,nano,micro}[up]time()
+ * Functions without the "get" prefix returns the best timestamp
+ * we can produce in the given format.
+ * "bin"   == struct bintime  == seconds + 64 bit fraction of seconds.
+ * "nano"  == struct timespec == seconds + nanoseconds.
+ * "micro" == struct timeval  == seconds + microseconds.
+ * Functions containing "up" returns time relative to boot and
+ * should be used for calculating time intervals.
+ * Functions without "up" returns UTC time.
+ * Functions with the "get" prefix returns a less precise result
+ * much faster than the functions without "get" prefix and should
+ * be used where a precision of 1/hz seconds is acceptable or where
+ * performance is priority. (NB: "precision", _not_ "resolution" !)
+#define	binuptime(_bt) _Timecounter_Binuptime(_bt)
+#define	nanouptime(_tsp) _Timecounter_Nanouptime(_tsp)
+#define	microuptime(_tvp) _Timecounter_Microuptime(_tvp)
+static __inline sbintime_t
+sbinuptime(void)
+	struct bintime _bt;
+	binuptime(&_bt);
+	return (bttosbt(_bt));
+#define	bintime(_bt) _Timecounter_Bintime(_bt)
+#define	nanotime(_tsp) _Timecounter_Nanotime(_tsp)
+#define	microtime(_tvp) _Timecounter_Microtime(_tvp)
+#define	getbinuptime(_bt) _Timecounter_Getbinuptime(_bt)
+#define	getnanouptime(_tsp) _Timecounter_Getnanouptime(_tsp)
+#define	getmicrouptime(_tvp) _Timecounter_Getmicrouptime(_tvp)
+getsbinuptime(void)
+	getbinuptime(&_bt);
+#define	getbintime(_bt) _Timecounter_Getbintime(_bt)
+#define	getnanotime(_tsp) _Timecounter_Getnanotime(_tsp)
+#define	getmicrotime(_tvp) _Timecounter_Getmicrotime(_tvp)
+/* Other functions */
+int	itimerdecr(struct itimerval *itp, int usec);
+int	itimerfix(struct timeval *tv);
+int	ppsratecheck(struct timeval *, int *, int);
+int	ratecheck(struct timeval *, const struct timeval *);
+void	timevaladd(struct timeval *t1, const struct timeval *t2);
+void	timevalsub(struct timeval *t1, const struct timeval *t2);
+int	tvtohz(struct timeval *tv);
+#define	TC_DEFAULTPERC		5
+#define	BT2FREQ(bt)                                                     \
+	(((uint64_t)0x8000000000000000 + ((bt)->frac >> 2)) /           \
+	    ((bt)->frac >> 1))
+#define	SBT2FREQ(sbt)	((SBT_1S + ((sbt) >> 1)) / (sbt))
+#define	FREQ2BT(freq, bt)                                               \
+	(bt)->sec = 0;                                                  \
+	(bt)->frac = ((uint64_t)0x8000000000000000  / (freq)) << 1;     \
+#define	TIMESEL(sbt, sbt2)						\
+	(((sbt2) >= sbt_timethreshold) ?				\
+	    ((*(sbt) = getsbinuptime()), 1) : ((*(sbt) = sbinuptime()), 0))
+#endif /* _KERNEL */
+#endif /* _SYS_TIME_H_ */
1.8.4.5
