[PATCH 07/12] score: Simplify _Objects_Get_no_protection()
Fri Apr 8 06:49:22 UTC 2016
This functions supports only local objects.  Thus, drop the location
parameter which was unused by all callers.
Remove superfluous includes from Classic Region implementation.
 cpukit/posix/include/rtems/posix/keyimpl.h    |   9 +-
 cpukit/rtems/include/rtems/rtems/regionimpl.h |  16 +---
 cpukit/rtems/src/regiondelete.c               |  45 +++-------
 cpukit/rtems/src/regionextend.c               |  73 ++++++----------
 cpukit/rtems/src/regiongetfreeinfo.c          |  48 ++++------
 cpukit/rtems/src/regiongetinfo.c              |  39 +++------
 cpukit/rtems/src/regiongetsegment.c           | 121 ++++++++++++--------------
 cpukit/rtems/src/regiongetsegmentsize.c       |  41 ++++-----
 cpukit/rtems/src/regionprocessqueue.c         |  12 +--
 cpukit/rtems/src/regionresizesegment.c        |  71 ++++++---------
 cpukit/rtems/src/regionreturnsegment.c        |  51 ++++-------
 cpukit/score/include/rtems/score/objectimpl.h |   6 +-
 cpukit/score/src/objectgetnext.c              |   9 +-
 cpukit/score/src/objectgetnoprotection.c      |   7 +-
 14 files changed, 207 insertions(+), 341 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/keyimpl.h b/cpukit/posix/include/rtems/posix/keyimpl.h
index 0f255ba..1f87470 100644
--- a/cpukit/posix/include/rtems/posix/keyimpl.h
+++ b/cpukit/posix/include/rtems/posix/keyimpl.h
@@ -76,13 +76,8 @@ RTEMS_INLINE_ROUTINE void _POSIX_Keys_Free(
 RTEMS_INLINE_ROUTINE POSIX_Keys_Control *_POSIX_Keys_Get( pthread_key_t key )
-  Objects_Locations location;
-  return (POSIX_Keys_Control *) _Objects_Get_no_protection(
-    &_POSIX_Keys_Information,
-    (Objects_Id) key,
-    &location
+  return (POSIX_Keys_Control *)
+    _Objects_Get_no_protection( &_POSIX_Keys_Information, (Objects_Id) key );
 RTEMS_INLINE_ROUTINE void _POSIX_Keys_Key_value_acquire(
diff --git a/cpukit/rtems/include/rtems/rtems/regionimpl.h b/cpukit/rtems/include/rtems/rtems/regionimpl.h
index 4598351..60cf50c 100644
--- a/cpukit/rtems/include/rtems/rtems/regionimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/regionimpl.h
@@ -67,23 +67,11 @@ RTEMS_INLINE_ROUTINE void _Region_Free (
   _Objects_Free( &_Region_Information, &the_region->Object );
- *  @brief Region_Get
- *  This function maps region IDs to region control blocks.
- *  If ID corresponds to a local region, then it returns
- *  the_region control pointer which maps to ID and location
- *  is set to OBJECTS_LOCAL.  Otherwise, location is set
- *  to OBJECTS_ERROR and the_region is undefined.
-RTEMS_INLINE_ROUTINE Region_Control *_Region_Get (
-  Objects_Id         id,
-  Objects_Locations *location
+RTEMS_INLINE_ROUTINE Region_Control *_Region_Get( Objects_Id id )
   _Assert( _RTEMS_Allocator_is_owner() );
   return (Region_Control *)
-    _Objects_Get_no_protection( &_Region_Information, id, location );
+    _Objects_Get_no_protection( &_Region_Information, id );
diff --git a/cpukit/rtems/src/regiondelete.c b/cpukit/rtems/src/regiondelete.c
index f256423..3927a54 100644
--- a/cpukit/rtems/src/regiondelete.c
+++ b/cpukit/rtems/src/regiondelete.c
@@ -18,50 +18,33 @@
 #include "config.h"
 #endif
-#include <rtems/system.h>
-#include <rtems/rtems/status.h>
-#include <rtems/rtems/support.h>
-#include <rtems/rtems/options.h>
 #include <rtems/rtems/regionimpl.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/apimutex.h>
 rtems_status_code rtems_region_delete(
   rtems_id id
-  rtems_status_code   return_status;
-  Region_Control     *the_region;
+  rtems_status_code  status;
+  Region_Control    *the_region;
   _Objects_Allocator_lock();
   _RTEMS_Lock_allocator();
-    the_region = _Region_Get( id, &location );
-    switch ( location ) {
+  the_region = _Region_Get( id );
-      case OBJECTS_LOCAL:
-        if ( the_region->number_of_used_blocks != 0 )
-          return_status = RTEMS_RESOURCE_IN_USE;
-        else {
-          _Objects_Close( &_Region_Information, &the_region->Object );
-          _Region_Free( the_region );
-          return_status = RTEMS_SUCCESSFUL;
-        break;
-#if defined(RTEMS_MULTIPROCESSING)
-      case OBJECTS_REMOTE:        /* this error cannot be returned */
-#endif
-      case OBJECTS_ERROR:
-      default:
-        return_status = RTEMS_INVALID_ID;
-        break;
+  if ( the_region != NULL ) {
+    if ( the_region->number_of_used_blocks != 0 ) {
+      status = RTEMS_RESOURCE_IN_USE;
+    } else {
+      _Objects_Close( &_Region_Information, &the_region->Object );
+      _Region_Free( the_region );
+      status = RTEMS_SUCCESSFUL;
+  } else {
+    status = RTEMS_INVALID_ID;
   _RTEMS_Unlock_allocator();
   _Objects_Allocator_unlock();
-  return return_status;
+  return status;
diff --git a/cpukit/rtems/src/regionextend.c b/cpukit/rtems/src/regionextend.c
index 2ee2b99..b1df066 100644
--- a/cpukit/rtems/src/regionextend.c
+++ b/cpukit/rtems/src/regionextend.c
@@ -18,13 +18,7 @@
 #include "config.h"
 #endif
 rtems_status_code rtems_region_extend(
   rtems_id   id,
@@ -32,48 +26,37 @@ rtems_status_code rtems_region_extend(
   uintptr_t  length
-  uintptr_t           amount_extended;
+  uintptr_t          amount_extended;
-  if ( !starting_address )
+  if ( starting_address == NULL ) {
     return RTEMS_INVALID_ADDRESS;
-  _RTEMS_Lock_allocator(); /* to prevent deletion */
-        amount_extended = _Heap_Extend(
-          &the_region->Memory,
-          starting_address,
-          length,
-          0
-        if ( amount_extended > 0 ) {
-          the_region->length                += amount_extended;
-          the_region->maximum_segment_size  += amount_extended;
-        } else {
-          return_status = RTEMS_INVALID_ADDRESS;
-        break;
-#endif
-      default:
-        break;
+  _RTEMS_Lock_allocator();
+    amount_extended = _Heap_Extend(
+      &the_region->Memory,
+      starting_address,
+      length,
+      0
+    if ( amount_extended > 0 ) {
+      the_region->length               += amount_extended;
+      the_region->maximum_segment_size += amount_extended;
+    } else {
+      status = RTEMS_INVALID_ADDRESS;
+  } else {
+  return status;
diff --git a/cpukit/rtems/src/regiongetfreeinfo.c b/cpukit/rtems/src/regiongetfreeinfo.c
index 6ebd1ab..7924c0f 100644
--- a/cpukit/rtems/src/regiongetfreeinfo.c
+++ b/cpukit/rtems/src/regiongetfreeinfo.c
@@ -18,52 +18,34 @@
 #include "config.h"
 #endif
+#include <string.h>
 rtems_status_code rtems_region_get_free_information(
   rtems_id                id,
   Heap_Information_block *the_info
-  if ( !the_info )
+  if ( the_info == NULL ) {
-        the_info->Used.number   = 0;
-        the_info->Used.total    = 0;
-        the_info->Used.largest  = 0;
-        _Heap_Get_free_information( &the_region->Memory, &the_info->Free );
-        break;
-#endif
-      default:
-        break;
+    memset( &the_info->Used, 0, sizeof( the_info->Used ) );
+    _Heap_Get_free_information( &the_region->Memory, &the_info->Free );
+  } else {
+  return status;
diff --git a/cpukit/rtems/src/regiongetinfo.c b/cpukit/rtems/src/regiongetinfo.c
index d5eee72..2ab3d40 100644
--- a/cpukit/rtems/src/regiongetinfo.c
+++ b/cpukit/rtems/src/regiongetinfo.c
@@ -18,46 +18,31 @@
 #include "config.h"
 #endif
 rtems_status_code rtems_region_get_information(
   rtems_id                id,
-  if ( !the_info )
-        _Heap_Get_information( &the_region->Memory, the_info );
-        break;
-#endif
-      default:
-        break;
+    _Heap_Get_information( &the_region->Memory, the_info );
+  } else {
+  return status;
diff --git a/cpukit/rtems/src/regiongetsegment.c b/cpukit/rtems/src/regiongetsegment.c
index 0d1ac57..5a98e85 100644
--- a/cpukit/rtems/src/regiongetsegment.c
+++ b/cpukit/rtems/src/regiongetsegment.c
@@ -20,7 +20,6 @@
 #include <rtems/rtems/optionsimpl.h>
@@ -32,79 +31,73 @@ rtems_status_code rtems_region_get_segment(
   void              **segment
-  Thread_Control     *executing;
-  void               *the_segment;
-  if ( !segment )
+  if ( segment == NULL ) {
   *segment = NULL;
-  if ( size == 0 )
+  if ( size == 0 ) {
     return RTEMS_INVALID_SIZE;
-    executing  = _Thread_Get_executing();
-        if ( size > the_region->maximum_segment_size )
-          return_status = RTEMS_INVALID_SIZE;
-        else {
-          the_segment = _Region_Allocate_segment( the_region, size );
-          if ( the_segment ) {
-            the_region->number_of_used_blocks += 1;
-            *segment = the_segment;
-          } else if ( _Options_Is_no_wait( option_set ) ) {
-            return_status = RTEMS_UNSATISFIED;
-          } else {
-             *  Switch from using the memory allocation mutex to using a
-             *  dispatching disabled critical section.  We have to do this
-             *  because this thread is going to block.
-            /* FIXME: Lock order reversal */
-            _Thread_Disable_dispatch();
-            _RTEMS_Unlock_allocator();
-            executing->Wait.count           = size;
-            executing->Wait.return_argument = segment;
-            _Thread_queue_Enqueue(
-              &the_region->Wait_queue,
-              the_region->wait_operations,
-              executing,
-              STATES_WAITING_FOR_SEGMENT,
-              timeout,
-              RTEMS_TIMEOUT
-            _Objects_Put( &the_region->Object );
-            return (rtems_status_code) executing->Wait.return_code;
-        break;
-#endif
-      default:
-        break;
+    if ( size > the_region->maximum_segment_size ) {
+      status = RTEMS_INVALID_SIZE;
+    } else {
+      void *the_segment;
+      the_segment = _Region_Allocate_segment( the_region, size );
+      if ( the_segment != NULL ) {
+        the_region->number_of_used_blocks += 1;
+        *segment = the_segment;
+      } else if ( _Options_Is_no_wait( option_set ) ) {
+        status = RTEMS_UNSATISFIED;
+      } else {
+        Per_CPU_Control *cpu_self;
+        Thread_Control  *executing;
+         *  Switch from using the memory allocation mutex to using a
+         *  dispatching disabled critical section.  We have to do this
+         *  because this thread is going to block.
+        /* FIXME: This is a home grown condition variable */
+        cpu_self = _Thread_Dispatch_disable();
+        _RTEMS_Unlock_allocator();
+        executing  = _Per_CPU_Get_executing( cpu_self );
+        executing->Wait.count           = size;
+        executing->Wait.return_argument = segment;
+        _Thread_queue_Enqueue(
+          &the_region->Wait_queue,
+          the_region->wait_operations,
+          executing,
+          STATES_WAITING_FOR_SEGMENT,
+          timeout,
+          RTEMS_TIMEOUT
+        _Thread_Dispatch_enable( cpu_self );
+        return (rtems_status_code) executing->Wait.return_code;
+  } else {
+  return status;
diff --git a/cpukit/rtems/src/regiongetsegmentsize.c b/cpukit/rtems/src/regiongetsegmentsize.c
index ab07a56..21a2bb4 100644
--- a/cpukit/rtems/src/regiongetsegmentsize.c
+++ b/cpukit/rtems/src/regiongetsegmentsize.c
@@ -18,12 +18,7 @@
 #include "config.h"
 #endif
 rtems_status_code rtems_region_get_segment_size(
   rtems_id   id,
@@ -31,35 +26,31 @@ rtems_status_code rtems_region_get_segment_size(
   uintptr_t *size
-  rtems_status_code        return_status = RTEMS_SUCCESSFUL;
-  if ( !segment )
-  if ( !size )
+  if ( size == NULL ) {
-        if ( !_Heap_Size_of_alloc_area( &the_region->Memory, segment, size ) )
-        break;
-#endif
-        break;
+    if ( _Heap_Size_of_alloc_area( &the_region->Memory, segment, size ) ) {
+    } else {
+  } else {
+  return status;
diff --git a/cpukit/rtems/src/regionprocessqueue.c b/cpukit/rtems/src/regionprocessqueue.c
index a1f2601..a28d68c 100644
--- a/cpukit/rtems/src/regionprocessqueue.c
+++ b/cpukit/rtems/src/regionprocessqueue.c
@@ -19,15 +19,16 @@
 #endif
 void _Region_Process_queue(
-  Thread_Control *the_thread;
+  Thread_Control  *the_thread;
@@ -38,7 +39,7 @@ void _Region_Process_queue(
    *        since we do not want to open a window where a context
    *        switch could occur.
@@ -67,5 +68,6 @@ void _Region_Process_queue(
     _Thread_queue_Extract( the_thread );
     the_thread->Wait.return_code = RTEMS_SUCCESSFUL;
-  _Thread_Enable_dispatch();
diff --git a/cpukit/rtems/src/regionresizesegment.c b/cpukit/rtems/src/regionresizesegment.c
index 86d8a77..a21d1b9 100644
--- a/cpukit/rtems/src/regionresizesegment.c
+++ b/cpukit/rtems/src/regionresizesegment.c
@@ -18,13 +18,7 @@
 #include "config.h"
 #endif
 rtems_status_code rtems_region_resize_segment(
   rtems_id    id,
@@ -33,55 +27,48 @@ rtems_status_code rtems_region_resize_segment(
   uintptr_t  *old_size
-  uintptr_t                avail_size;
-  uintptr_t                osize;
-  Heap_Resize_status       status;
+  uintptr_t           avail_size;
+  uintptr_t           osize;
+  Heap_Resize_status  resize_status;
-  if ( !old_size )
+  if ( old_size == NULL ) {
-        status = _Heap_Resize_block(
-          segment,
-          (uint32_t) size,
-          &osize,
-          &avail_size
-        *old_size = (uint32_t) osize;
+    resize_status = _Heap_Resize_block(
+      segment,
+      (uint32_t) size,
+      &osize,
+      &avail_size
+    *old_size = (uint32_t) osize;
-        if ( status == HEAP_RESIZE_SUCCESSFUL )
-          /* unlocks allocator */
-          _Region_Process_queue( the_region );
-        else
+    switch ( resize_status ) {
+      case HEAP_RESIZE_SUCCESSFUL:
+        /* Unlocks allocator */
+        _Region_Process_queue( the_region );
+        return RTEMS_SUCCESSFUL;
-        if (status == HEAP_RESIZE_SUCCESSFUL)
-          return RTEMS_SUCCESSFUL;
-        if (status == HEAP_RESIZE_UNSATISFIED)
-          return RTEMS_UNSATISFIED;
-        return RTEMS_INVALID_ADDRESS;
+      case HEAP_RESIZE_UNSATISFIED:
         break;
-#endif
       default:
         break;
+  } else {
+  return status;
diff --git a/cpukit/rtems/src/regionreturnsegment.c b/cpukit/rtems/src/regionreturnsegment.c
index aeff1df..c7147bb 100644
--- a/cpukit/rtems/src/regionreturnsegment.c
+++ b/cpukit/rtems/src/regionreturnsegment.c
@@ -18,53 +18,34 @@
 #include "config.h"
 #endif
 rtems_status_code rtems_region_return_segment(
   rtems_id  id,
   void     *segment
-  int                      status;
-          status = _Region_Free_segment( the_region, segment );
+     if ( _Region_Free_segment( the_region, segment ) ) {
+       the_region->number_of_used_blocks -= 1;
-          if ( !status )
-          else {
-            the_region->number_of_used_blocks -= 1;
-            _Region_Process_queue(the_region); /* unlocks allocator */
-        break;
-#endif
-      default:
-        break;
+     } else {
+  } else {
+  return status;
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index aed7faf..ee9da93 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -614,7 +614,6 @@ Objects_Control *_Objects_Get_local(
  *  @param[in] information points to an object class information block.
  *  @param[in] id is the Id of the object whose name we are locating.
- *  @param[in] location will contain an indication of success or failure.
  *  @retval This method returns one of the values from the
  *          @ref Objects_Name_or_id_lookup_errors enumeration to indicate
@@ -627,9 +626,8 @@ Objects_Control *_Objects_Get_local(
  *  objects.
 Objects_Control *_Objects_Get_no_protection(
-  Objects_Information *information,
-  Objects_Id           id,
+  const Objects_Information *information,
+  Objects_Id                 id
diff --git a/cpukit/score/src/objectgetnext.c b/cpukit/score/src/objectgetnext.c
index 544ded7..c0ebbbe 100644
--- a/cpukit/score/src/objectgetnext.c
+++ b/cpukit/score/src/objectgetnext.c
@@ -28,7 +28,7 @@ _Objects_Get_next(
     Objects_Id          *next_id_p
-    Objects_Control *object;
+    Objects_Control *the_object;
     Objects_Id       next_id;
     if ( !information )
@@ -58,12 +58,13 @@ _Objects_Get_next(
         /* try to grab one */
-        object = _Objects_Get_no_protection(information, next_id, location_p);
+        the_object = _Objects_Get_no_protection( information, next_id );
         next_id++;
-    } while (*location_p != OBJECTS_LOCAL);
+    } while ( the_object == NULL );
+    *location_p = OBJECTS_LOCAL;
     *next_id_p = next_id;
-    return object;
+    return the_object;
diff --git a/cpukit/score/src/objectgetnoprotection.c b/cpukit/score/src/objectgetnoprotection.c
index aebe6c7..eaa172c 100644
--- a/cpukit/score/src/objectgetnoprotection.c
+++ b/cpukit/score/src/objectgetnoprotection.c
@@ -21,9 +21,8 @@
-  Objects_Id           id,
+  Objects_Id                 id
@@ -37,7 +36,6 @@ Objects_Control *_Objects_Get_no_protection(
   if ( information->maximum >= index ) {
     if ( (the_object = information->local_table[ index ]) != NULL ) {
-      *location = OBJECTS_LOCAL;
       return the_object;
@@ -46,6 +44,5 @@ Objects_Control *_Objects_Get_no_protection(
    *  This isn't supported or required yet for Global objects so
    *  if it isn't local, we don't find it.
-  *location = OBJECTS_ERROR;
   return NULL;
1.8.4.5
