[PATCH 02/12] score: Add ticks per second to configuration
Fri Apr 8 07:35:48 UTC 2016
On 08/04/16 09:06, Chris Johns wrote:
> On 8/04/2016 4:49 PM, Sebastian Huber wrote:
>> This avoids the calculation of this value at run-time, similar to
>> rtems_configuration_get_nanoseconds_per_tick().
>> Delete TOD_TICKS_PER_SECOND and replace it with
>> rtems_configuration_get_ticks_per_second().
>> --- a/cpukit/sapi/include/confdefs.h
>> +++ b/cpukit/sapi/include/confdefs.h
>> @@ -3413,6 +3413,7 @@ extern rtems_initialization_tasks_table
>> Initialization_tasks[];
>>       CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS,  /*   enabled */
>>       CONFIGURE_MICROSECONDS_PER_TICK,          /* microseconds per
>> clock tick */
>>       1000 * CONFIGURE_MICROSECONDS_PER_TICK,   /* nanoseconds per
>> clock tick */
>> +    1000000 / CONFIGURE_MICROSECONDS_PER_TICK,/* ticks per second */
>>       CONFIGURE_TICKS_PER_TIMESLICE,            /* ticks per
>> timeslice quantum */
>>       CONFIGURE_IDLE_TASK_BODY,                 /* user's IDLE task */
>>       CONFIGURE_IDLE_TASK_STACK_SIZE,           /* IDLE task stack
>> size */
> I assume the microsecond, nanosecond and tick per sec values all need
> to agree.
> Does anything check this is the case and raise a fatal error if they
> do not?
Currently nobody checks this. Should we check this via an _Assert()? If
we add new fatal errors, it will get difficult. We need to test it. The
Configuration is read-only. We would have to avoid <rtems/confdefs.h> to
create a corrupt Configuration and this is very bad.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
