[PATCH 02/12] score: Add ticks per second to configuration
Fri Apr 8 09:22:51 UTC 2016
On 8/04/2016 6:30 PM, Sebastian Huber wrote:
> The _Assert() is only active in case you use RTEMS_DEBUG.
Then that is no good.
> I don't think its feasible to avoid <rtems/confdefs.h>. Its now the only
> way to create a configuration.
Sorry, but I do not like confdefs getting these values in this way. This
is not a great long term solution. Easy to add very hard to remove.
Maybe you need make some score level variables and compute the values
during configuration.
