Move POSIX network headers like <sys/socket.h> etc. to Newlib?
Fri Apr 8 09:25:43 UTC 2016
On 8/04/2016 6:34 PM, Sebastian Huber wrote:
> On 08/04/16 04:22, Chris Johns wrote:
>> On 8/04/2016 12:37 AM, Joel Sherrill wrote:
>>> Chris and I have discussed at least some of the network services being
>>> considered packages beyond the stack. Stuff like httpd, ftpd, and
>>> telnetd should be able to work with either stack. Having one instance of
>>> those to maintain would be great.
>>> I'm happy to see all this happen. Hopefully it can show up in digestable
>>> pieces.
>> We need to maintain our current functionality and I am prepared to
>> bridge but not abandon. The libbsd stack has made progress but does
>> not support as much as the old stack does. Until it does I feel we
>> need to keep the old stack going and to support it.
> The old stack is still a valid option since it uses considerably less
> memory than the new stack.
I agree.
>> To me this means adding headers to newlib requires the in-tree stack
>> and libbsd work with out impacting users and existing applications.
>> If I understand what is bring proposed any suitable networking
>> software should be able to be built against just the compiler, newlib
>> etc and it does not need a built and installed RTEMS with a specific
>> networking implementation. This means networking could become a link
>> time setting. An interesting challenge.
> Yes, this is the goal.
Awesome.
>> Sebastian, I know you have talked about libressl, but it is still not
>> clear to me why doing this is needed. Do you have a specific use case?
> Its not needed, but would simplify things.
Great.
> We want to update the
> mongoose HTTP server to support HTTPS.
Does this mean we have forked mongoose? Maybe it needs to be called
something else if this happens.
> We also want to use it with the old and new stack.
This is great.
