[PATCH 02/12] score: Add ticks per second to configuration
Fri Apr 8 09:34:15 UTC 2016
On 08/04/16 11:22, Chris Johns wrote:
>> I don't think its feasible to avoid <rtems/confdefs.h>. Its now the only
>> way to create a configuration.
> Sorry, but I do not like confdefs getting these values in this way.
> This is not a great long term solution. Easy to add very hard to remove.
> Maybe you need make some score level variables and compute the values
> during configuration.
In this case they are no longer read-only.
One way to test it would be to use
#define CONFIGURE_MICROSECONDS_PER_TICK 1000000000
and exploit the limited integer ranges. Doesn't work if we check this
configuration error in <rtems/confdefs.h>.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
