[PATCH 0/5] Tool Updates
Joel Sherrill
joel at rtems.org
Sun Apr 10 19:01:46 UTC 2016
This patch series updates newlib to 2.4.0 for all targets. For most,
this was done by changing the default. But some targets use older gcc
versions. Those required special attention.
Joel Sherrill (5):
4.12/rtems-moxie.bset: Include dtc needed by gdb build
4.12/rtems-default.bset: Update to gcc 6.20160327 and newlib-2.4.0
4.12/rtems-or1k.bset: Update newlib to 2.4.0
4.12/rtems-epiphany.bset: Update to newlib 2.4.0
4.12/rtems-m32c.bset: Update to newlib 2.4.0
rtems/config/4.12/rtems-default.bset | 2 +-
rtems/config/4.12/rtems-epiphany.bset | 2 +-
rtems/config/4.12/rtems-m32c.bset | 2 +-
rtems/config/4.12/rtems-moxie.bset | 3 +++
rtems/config/4.12/rtems-or1k.bset | 2 +-
.../tools/rtems-gcc-4.8.3-newlib-2.4.0-1.cfg | 14 ++++++++++++++
.../tools/rtems-gcc-4.9.2-newlib-2.4.0-1.cfg | 15 +++++++++++++++
.../tools/rtems-gcc-4.9.3-newlib-2.4.0-1.cfg | 15 +++++++++++++++
.../tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg | 22 ++++++++++++++++++++++
9 files changed, 73 insertions(+), 4 deletions(-)
create mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.4.0-1.cfg
create mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.4.0-1.cfg
create mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0-1.cfg
create mode 100644 rtems/config/tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg
1.8.3.1
