[PATCH 1/5] 4.12/rtems-moxie.bset: Include dtc needed by gdb build
Sun Apr 10 19:01:47 UTC 2016
 rtems/config/4.12/rtems-moxie.bset | 3 +++
 1 file changed, 3 insertions(+)
diff --git a/rtems/config/4.12/rtems-moxie.bset b/rtems/config/4.12/rtems-moxie.bset
index bfc649f..d9d6c16 100644
--- a/rtems/config/4.12/rtems-moxie.bset
+++ b/rtems/config/4.12/rtems-moxie.bset
@@ -5,4 +5,7 @@
 %define rtems_arch moxie
 %define win32-gdb-disable-sim
 %define with_libgomp
+# Moxie needs dtc to build gdb, then pick up the rest of the set
+devel/dtc-1.4.1-1
 %include 4.12/rtems-default.bset
1.8.3.1
