[PATCH 02/12] score: Add ticks per second to configuration
Mon Apr 11 22:33:27 UTC 2016
On 11/04/2016 23:37, Joel Sherrill wrote:
> Ultimately we have to rely on something to do the right thing.
The design issue is a struct and code in the score is dependent on
something in a header in another file in another part of RTEMS, ie
confdefs.h to actually work as expected. It is easy to see the
relationship now but in time will that happen. We need to either bring
the functionality closer together or check the values are valid or
something else or all of the above. The optimisation is a good one and
worth doing, we just need a way to handle the implementation issues.
> What errors are you two worried about that couldn't happen now?
The values are different and so different pieces of code have different
timeouts. This would be very hard to see on a live system.
