[PATCH v3 1/2] Eliminate use of Newlib-specific <machine/types.h>
Sebastian Huber
Wed Apr 13 11:10:15 UTC 2016
This change solves a glibc/BSD compatibility problem.
glibc and BSD use double underscore types for internal types. The Linux
port of Newlib uses some glibc provided internal type definitions which
are not protected by guard defines, e.g. __off_t. To avoid a conflict
Newlib uses single underscore types for some internal types, e.g.
_off_t. However, for BSD compatibility we have to define the internal
types with double underscore names in <sys/_types.h>.
The header file <machine/types.h> is Newlib-specific. It was used
instead of <sys/_types.h> to provide the internal type definitions
_CLOCK_T, _TIME_T_, _CLOCKID_T_, _TIMER_T_, and __suseconds_t. Move
these definitions to <sys/_types.h> (there exist two instances of this
file, one for Linux and one for all other targets). This makes the
_HAVE_SYSTYPES configuration define obsolete (could possibly break the
__RDOS__ target). Use the standard <sys/_types.h> include throughout.
Move __loff_t defintion to default (non-Linux) <sys/_types.h>. Define
it via _off64_t to avoid a dependency on the compiler.
Provide the __off_t definition via default (non-Linux) <sys/_types.h>
based on _off_t for all systems except Cygwin. For Cygwin use _off64_t.
Define off_t via __off_t.
Provide the __pid_t definition via default (non-Linux) <sys/_types.h>.
This prevents a potential __pid_t and pid_t incompatibility. Add BSD
guard defines for pid_t.
Signed-off-by: Sebastian Huber <sebastian.huber at embedded-brains.de>
newlib/libc/include/machine/types.h | 27 +++-----------------------
newlib/libc/include/reent.h | 1 -
newlib/libc/include/sys/_timespec.h | 2 +-
newlib/libc/include/sys/_timeval.h | 2 +-
newlib/libc/include/sys/_types.h | 21 ++++++++++++++++++++
newlib/libc/include/sys/config.h | 1 -
newlib/libc/include/sys/timeb.h | 2 +-
newlib/libc/include/sys/times.h | 2 +-
newlib/libc/include/sys/types.h | 8 +++-----
newlib/libc/sys/linux/sys/_types.h | 7 +++++++
newlib/libc/sys/linux/sys/types.h | 1 -
newlib/libc/sys/rtems/include/machine/_types.h | 3 ---
newlib/libc/sys/sparc64/sys/_timeval.h | 2 +-
winsup/cygwin/include/cygwin/types.h | 7 +------
14 files changed, 40 insertions(+), 46 deletions(-)
diff --git a/newlib/libc/include/machine/types.h b/newlib/libc/include/machine/types.h
index 4250ee3..669242b 100644
--- a/newlib/libc/include/machine/types.h
+++ b/newlib/libc/include/machine/types.h
@@ -2,31 +2,10 @@
#define _MACHTYPES_H_
- * The following section is RTEMS specific and is needed to more
- * closely match the types defined in the BSD machine/types.h.
- * This is needed to let the RTEMS/BSD TCP/IP stack compile.
+ * This file is provided for backward compatibility. It is no longer used in
+ * Newlib. Do not add new things to it.
-#if defined(__rtems__)
-#include <machine/_types.h>
-#endif
-#define _CLOCK_T_ unsigned long /* clock() */
-#define _TIME_T_ long /* time() */
-#define _CLOCKID_T_ unsigned long
-#define _TIMER_T_ unsigned long
-#ifndef _HAVE_SYSTYPES
-typedef long int __off_t;
-typedef int __pid_t;
-#ifdef __GNUC__
-__extension__ typedef long long int __loff_t;
-#else
-typedef long int __loff_t;
-#endif
-#endif
-typedef long __suseconds_t; /* microseconds (signed) */
+#include <sys/_types.h>
#endif /* _MACHTYPES_H_ */
diff --git a/newlib/libc/include/reent.h b/newlib/libc/include/reent.h
index 861be71..b7664b0 100644
--- a/newlib/libc/include/reent.h
+++ b/newlib/libc/include/reent.h
@@ -92,7 +92,6 @@ extern "C" {
#include <sys/reent.h>
-#include <machine/types.h>
#define __need_size_t
#define __need_ptrdiff_t
diff --git a/newlib/libc/include/sys/_timespec.h b/newlib/libc/include/sys/_timespec.h
index bd66dfc..4a7aabc 100644
--- a/newlib/libc/include/sys/_timespec.h
+++ b/newlib/libc/include/sys/_timespec.h
@@ -34,7 +34,7 @@
#ifndef _SYS__TIMESPEC_H_
#define _SYS__TIMESPEC_H_
#ifndef __time_t_defined
typedef _TIME_T_ time_t;
diff --git a/newlib/libc/include/sys/_timeval.h b/newlib/libc/include/sys/_timeval.h
index 0a4c539..d813d1f 100644
--- a/newlib/libc/include/sys/_timeval.h
+++ b/newlib/libc/include/sys/_timeval.h
@@ -29,7 +29,7 @@
#ifndef _SYS__TIMEVAL_H_
#define _SYS__TIMEVAL_H_
#ifndef _SUSECONDS_T_DECLARED
typedef __suseconds_t suseconds_t;
diff --git a/newlib/libc/include/sys/_types.h b/newlib/libc/include/sys/_types.h
index 07bc276..b38a161 100644
--- a/newlib/libc/include/sys/_types.h
+++ b/newlib/libc/include/sys/_types.h
@@ -16,6 +16,12 @@
typedef long _off_t;
#endif
+#if defined(__XMK__)
+typedef signed char __pid_t;
+#else
+typedef int __pid_t;
+#endif
#ifndef __dev_t_defined
typedef short __dev_t;
#endif
@@ -31,6 +37,14 @@ typedef unsigned short __gid_t;
__extension__ typedef long long _off64_t;
#endif
+#ifdef __CYGWIN__
+typedef _off64_t __off_t;
+#else
+typedef _off_t __off_t;
+#endif
+typedef _off64_t __loff_t;
* We need fpos_t for the following, but it doesn't have a leading "_",
* so we use _fpos_t instead.
@@ -88,4 +102,11 @@ typedef _LOCK_RECURSIVE_T _flock_t;
typedef void *_iconv_t;
#endif
+#define _CLOCK_T_ unsigned long /* clock() */
+#define _TIME_T_ long /* time() */
+#define _CLOCKID_T_ unsigned long
+#define _TIMER_T_ unsigned long
+typedef long __suseconds_t; /* microseconds (signed) */
#endif /* _SYS__TYPES_H */
diff --git a/newlib/libc/include/sys/config.h b/newlib/libc/include/sys/config.h
index c536698..555239f 100644
--- a/newlib/libc/include/sys/config.h
+++ b/newlib/libc/include/sys/config.h
@@ -92,7 +92,6 @@
/* we want the reentrancy structure to be returned by a function */
#define __DYNAMIC_REENT__
#define HAVE_GETDATE
-#define _HAVE_SYSTYPES
#define _READ_WRITE_RETURN_TYPE _ssize_t
#define __LARGE64_FILES 1
/* we use some glibc header files so turn on glibc large file feature */
diff --git a/newlib/libc/include/sys/timeb.h b/newlib/libc/include/sys/timeb.h
index 0a2c3de..2647830 100644
--- a/newlib/libc/include/sys/timeb.h
+++ b/newlib/libc/include/sys/timeb.h
@@ -15,7 +15,7 @@ extern "C" {
#define _SYS_TIMEB_H
#include <_ansi.h>
diff --git a/newlib/libc/include/sys/times.h b/newlib/libc/include/sys/times.h
index 927812c..dc072f4 100644
--- a/newlib/libc/include/sys/times.h
+++ b/newlib/libc/include/sys/times.h
@@ -5,7 +5,7 @@ extern "C" {
#define _SYS_TIMES_H
#include <_ansi.h>
#ifndef __clock_t_defined
typedef _CLOCK_T_ clock_t;
diff --git a/newlib/libc/include/sys/types.h b/newlib/libc/include/sys/types.h
index f880830..c0b5796 100644
--- a/newlib/libc/include/sys/types.h
+++ b/newlib/libc/include/sys/types.h
@@ -66,7 +66,6 @@ typedef quad_t * qaddr_t;
#endif
# include <stddef.h>
-# include <machine/types.h>
/* To ensure the stat struct's layout doesn't change when sizeof(int), etc.
changes, we assume sizeof short and long never change and have all types
@@ -175,10 +174,9 @@ typedef __uid_t uid_t;
typedef __gid_t gid_t;
#endif
-#if defined(__XMK__)
-typedef signed char pid_t;
-#else
-typedef int pid_t;
+#ifndef _PID_T_DECLARED
+typedef __pid_t pid_t; /* process id */
+#define _PID_T_DECLARED
#endif
diff --git a/newlib/libc/sys/linux/sys/_types.h b/newlib/libc/sys/linux/sys/_types.h
index 1ad429d..2fd1405 100644
--- a/newlib/libc/sys/linux/sys/_types.h
+++ b/newlib/libc/sys/linux/sys/_types.h
@@ -51,4 +51,11 @@ typedef struct
typedef struct { __flock_mutex_t mutex; } _flock_t;
diff --git a/newlib/libc/sys/linux/sys/types.h b/newlib/libc/sys/linux/sys/types.h
index 8e674ef..20dab2f 100644
--- a/newlib/libc/sys/linux/sys/types.h
+++ b/newlib/libc/sys/linux/sys/types.h
@@ -54,7 +54,6 @@
#include <stddef.h>
#include <sys/config.h>
#include <features.h>
#if !defined(__time_t_defined) && !defined(_TIME_T)
diff --git a/newlib/libc/sys/rtems/include/machine/_types.h b/newlib/libc/sys/rtems/include/machine/_types.h
index 1711c7a..e0d93f7 100644
--- a/newlib/libc/sys/rtems/include/machine/_types.h
+++ b/newlib/libc/sys/rtems/include/machine/_types.h
@@ -5,9 +5,6 @@
#ifndef _MACHINE__TYPES_H
#define _MACHINE__TYPES_H
-/* This disables some conflicting type definitions in <machine/types.h> */
#include <machine/_default_types.h>
typedef __int32_t blksize_t;
diff --git a/newlib/libc/sys/sparc64/sys/_timeval.h b/newlib/libc/sys/sparc64/sys/_timeval.h
index 84ee717..fbe9ce6 100644
--- a/newlib/libc/sys/sparc64/sys/_timeval.h
+++ b/newlib/libc/sys/sparc64/sys/_timeval.h
@@ -1,7 +1,7 @@
#ifndef _SYS_TIME_H
#define _SYS_TIME_H
diff --git a/winsup/cygwin/include/cygwin/types.h b/winsup/cygwin/include/cygwin/types.h
index 61a1bb6..bdf4085 100644
--- a/winsup/cygwin/include/cygwin/types.h
+++ b/winsup/cygwin/include/cygwin/types.h
@@ -34,12 +34,7 @@ typedef struct timespec timestruc_t;
#ifndef __off_t_defined
#define __off_t_defined
-/* Based on the newlib definitions. */
-#if __WORDSIZE == 64
-typedef _off_t off_t;
-#else
-typedef _off64_t off_t;
-#endif
+typedef __off_t off_t;
#endif /*__off_t_defined*/
typedef __loff_t loff_t;
1.8.4.5
