Build failure for realview_pbx_a9_qemu_smp BSP
Thu Apr 14 08:21:46 UTC 2016
On 14/04/16 10:15, Darshit Shah wrote:
> On 04/14, Sebastian Huber wrote:
>> On 13/04/16 00:29, Darshit Shah wrote:
>>> make[6]: Entering directory
>>> '/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/testsuites/samples/hello'
>> Looks you build the atsamv BSP with --enable-smp. What is your
>> configure command line?
> Yes. I am building it with --enable-smp. My configure line is:
> ./configure \
>     --target=arm-rtems4.12     \
>     --prefix="$HOME/Programming/rtems/4.12" \
>     --enable-maintainer-mode \
>     --enable-tests \
>     --enable-smp
This builds all ARM BSPs. Add
"--enable-rtemsbsp=realview_pbx_a9_qemu_smp" to build only the
realview_pbx_a9_qemu_smp BSP. This will save you a lot of time and disk
space.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
