Build failure for realview_pbx_a9_qemu_smp BSP
Darshit Shah darnir at gmail.com
Thu Apr 14 08:15:10 UTC 2016
On 04/14, Sebastian Huber wrote:
>On 13/04/16 00:29, Darshit Shah wrote:
>>make[6]: Entering directory '/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/testsuites/samples/hello'
>Looks you build the atsamv BSP with --enable-smp. What is your
>configure command line?
Yes. I am building it with --enable-smp. My configure line is:
./configure \
	--target=arm-rtems4.12     \
	--prefix="$HOME/Programming/rtems/4.12" \
	--enable-maintainer-mode \
	--enable-tests \
	--enable-smp
>The realview_pbx_a9_qemu_smp is currently broken due to a problem of
>the clock driver initialization on Qemu.
Aah. Though I wonder why only the tests fail to compile.
>Sebastian Huber, embedded brains GmbH
>Address : Dornierstr. 4, D-82178 Puchheim, Germany
>Phone   : +49 89 189 47 41-16
>Fax     : +49 89 189 47 41-09
>E-Mail  : sebastian.huber at embedded-brains.de
>PGP     : Public key available on request.
>Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Thanking You,
Darshit Shah
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160414/38beaa12/attachment-0001.bin>
