[PATCH 03/18] Add BSD guard for ino_t in <sys/types.h>
Thu Apr 14 11:54:32 UTC 2016
Introduce internal type __ino_t.
Signed-off-by: Sebastian Huber <sebastian.huber at embedded-brains.de>
 newlib/libc/include/sys/_types.h               |  9 +++++++++
 newlib/libc/include/sys/types.h                | 10 +++-------
 newlib/libc/sys/rtems/include/machine/_types.h |  3 +++
 winsup/cygwin/include/cygwin/types.h           |  8 --------
 winsup/cygwin/include/machine/_types.h         |  4 ++++
 5 files changed, 19 insertions(+), 15 deletions(-)
diff --git a/newlib/libc/include/sys/_types.h b/newlib/libc/include/sys/_types.h
index ebd4943..ad322b1 100644
--- a/newlib/libc/include/sys/_types.h
+++ b/newlib/libc/include/sys/_types.h
@@ -47,6 +47,15 @@ typedef unsigned short __gid_t;
 typedef __pid_t __id_t;
 #endif
+#ifndef __machine_ino_t_defined
+#if (defined(__i386__) && (defined(GO32) || defined(__MSDOS__))) || \
+    defined(__sparc__) || defined(__SPU__)
+typedef unsigned long __ino_t;
+#else
+typedef unsigned short __ino_t;
+#endif
+#endif
 #ifndef __machine_off64_t_defined
 __extension__ typedef long long _off64_t;
 #endif
diff --git a/newlib/libc/include/sys/types.h b/newlib/libc/include/sys/types.h
index d093578..2bf9eb5 100644
--- a/newlib/libc/include/sys/types.h
+++ b/newlib/libc/include/sys/types.h
@@ -139,14 +139,10 @@ typedef	__id_t		id_t;		/* can hold a uid_t or pid_t */
 #define	_ID_T_DECLARED
 #endif
-#ifndef __CYGWIN__
-#if defined(__MS_types__) || defined(__rtems__) || \
-    defined(__sparc__) || defined(__SPU__)
-typedef	unsigned long	ino_t;
-#else
-typedef	unsigned short	ino_t;
+#ifndef _INO_T_DECLARED
+typedef	__ino_t		ino_t;		/* inode number */
+#define	_INO_T_DECLARED
 #endif
-#endif /*__CYGWIN__*/
 #ifdef __MS_types__
 typedef unsigned long vm_offset_t;
diff --git a/newlib/libc/sys/rtems/include/machine/_types.h b/newlib/libc/sys/rtems/include/machine/_types.h
index f17d281..76a6841 100644
--- a/newlib/libc/sys/rtems/include/machine/_types.h
+++ b/newlib/libc/sys/rtems/include/machine/_types.h
@@ -19,6 +19,9 @@ typedef	__int32_t	_off_t;
 typedef	_off_t		_fpos_t;
 #define	__machine_fpos_t_defined
+#define	__machine_ino_t_defined
 typedef	__uint32_t	_mode_t;
 #define	__machine_mode_t_defined
diff --git a/winsup/cygwin/include/cygwin/types.h b/winsup/cygwin/include/cygwin/types.h
index bfffc5d..c785fb2 100644
--- a/winsup/cygwin/include/cygwin/types.h
+++ b/winsup/cygwin/include/cygwin/types.h
@@ -57,14 +57,6 @@ typedef unsigned long fsblkcnt_t;
 typedef unsigned long fsfilcnt_t;
 #endif /* __fsfilcnt_t_defined */
-#ifndef __ino_t_defined
-#define __ino_t_defined
-#ifndef __x86_64__
-typedef __uint32_t __ino32_t;
-#endif
-typedef __uint64_t ino_t;
-#endif /*__ino_t_defined*/
 #if defined (__INSIDE_CYGWIN__) && !defined (__x86_64__)
 struct __flock32 {
 	short	 l_type;	/* F_RDLCK, F_WRLCK, or F_UNLCK */
diff --git a/winsup/cygwin/include/machine/_types.h b/winsup/cygwin/include/machine/_types.h
index 1dfe442..861a0fb 100644
--- a/winsup/cygwin/include/machine/_types.h
+++ b/winsup/cygwin/include/machine/_types.h
@@ -9,6 +9,7 @@
 typedef __int16_t  __dev16_t;
 typedef __uint16_t __uid16_t;
 typedef __uint16_t __gid16_t;
+typedef __uint32_t __ino32_t;
 #endif
 #define __machine_dev_t_defined
@@ -23,6 +24,9 @@ typedef __uint32_t __gid_t;
 #define __machine_id_t_defined
 typedef __uint32_t __id_t;
+typedef __uint64_t __ino_t;
 #define __machine_key_t_defined
 typedef long long __key_t;
1.8.4.5
