libbsd errors with the latest tools ...
Chris Johns
chrisj at rtems.org
Fri Apr 15 07:53:08 UTC 2016
Hi,
The following is just a small sample of the errors I am seeing with the
latest tools building libbsd. Anyone else seeing these?
$ waf
Waf: Entering directory
`/opt/work/chris/rtems/libbsd/rtems-libbsd.master/build/i386-rtems4.12-pc686'
[ 2/842] Compiling rtemsbsd/rtems/generate_kvm_symbols
[ 3/842] Compiling
build/i386-rtems4.12-pc686/rtemsbsd/rtems/rtems-kvm-symbols.c
In file included from
/opt/work/chris/rtems/libbsd/rtems-libbsd.master/rtemsbsd/include/rtems/bsd/sys/time.h:34:0,
from
/opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:97,
from
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/types.h:85,
from
/opt/work/rtems/4.12/i386-rtems4.12/include/stdio.h:48,
from rtemsbsd/rtems/rtems-kvm-symbols.c:8:
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:104:34: error:
unknown type name 'u_int'
bintime_mul(struct bintime *_bt, u_int _x)
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:145:17: error:
unknown type name 'sbintime_t'
sbintime_getsec(sbintime_t _sbt)
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:151:17: error:
static __inline sbintime_t
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h: In function
'bttosbt':
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:155:12: error:
'sbintime_t' undeclared (first use in this function)
return (((sbintime_t)_bt.sec << 32) + (_bt.frac >> 32));
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:155:12: note:
each undeclared identifier is reported only once for each function it
appears in
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:155:23: error:
expected ')' before '_bt'
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h: At top level:
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:159:9: error:
sbttobt(sbintime_t _sbt)
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:218:9: error:
sbttots(sbintime_t _sbt)
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:227:17: error:
'tstosbt':
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:231:12: error:
return (((sbintime_t)_ts.tv_sec << 32) +
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:231:23: error:
expected ')' before '_ts'
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:236:9: error:
sbttotv(sbintime_t _sbt)
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:245:17: error:
'tvtosbt':
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:249:12: error:
return (((sbintime_t)_tv.tv_sec << 32) +
/opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:249:23: error:
expected ')' before '_tv'
