libbsd errors with the latest tools ...
Fri Apr 15 09:13:23 UTC 2016
On 15/04/16 10:28, Chris Johns wrote:
> On 15/04/2016 18:22, Sebastian Huber wrote:
>> On 15/04/16 09:53, Chris Johns wrote:
>>> The following is just a small sample of the errors I am seeing with
>>> the latest tools building libbsd. Anyone else seeing these?
>> What are the latest tools for you in this case?
> tools/rtems-gcc-6-20160327-newlib-2.4.0-1
Ok, I didn't use this tool set up. I work currently with the latest
Newlib to sort out the <sys/types.h> incompatibilities.
I do a RSB build now and have a look at this next week.
> Reverting to tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1 get
> further not breaks with a different error ...
> In file included from
> /opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:47:0,
>                  from
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/rtemsbsd/include/rtems/bsd/sys/time.h:34,
>                  from
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/contrib/libpcap/pcap/pcap.h:47,
>                  from ../../freebsd/contrib/libpcap/pcap-int.h:39,
>                  from ../../freebsd/contrib/libpcap/scanner.l:51:
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:18:
> error: unknown type name 'fd_set'
>  int pselect(int, fd_set *__restrict, fd_set *__restrict, fd_set
> *__restrict,
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:38:
> *__restrict,
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:58:
> *__restrict,
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:17:
>  int select(int, fd_set *, fd_set *, fd_set *, struct timeval *);
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:27:
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:37:
> Chris
Yes, this is due to a bug in Newlib fixed with a later snapshot.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
