[PATCH 1/4] score: Add Chain_Iterator
Sebastian Huber
Fri Apr 15 09:16:05 UTC 2016
Add a chain iterator for safe iteration of chains with concurrent node
extraction.
cpukit/score/include/rtems/score/chainimpl.h | 186 +++++++++++++++++++++++++++
testsuites/sptests/spchain/init.c | 119 +++++++++++++++++
testsuites/sptests/spchain/spchain.doc | 6 +
testsuites/sptests/spchain/spchain.scn | 5 +-
4 files changed, 314 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/include/rtems/score/chainimpl.h b/cpukit/score/include/rtems/score/chainimpl.h
index ff66d46..6210ea5 100644
--- a/cpukit/score/include/rtems/score/chainimpl.h
+++ b/cpukit/score/include/rtems/score/chainimpl.h
@@ -800,6 +800,192 @@ RTEMS_INLINE_ROUTINE void _Chain_Insert_ordered_unprotected(
_Chain_Insert_unprotected( _Chain_Previous( next ), to_insert );
+ * @brief The chain iterator direction.
+typedef enum {
+ * @brief Iteration from head to tail.
+ CHAIN_ITERATOR_FORWARD,
+ * @brief Iteration from tail to head.
+ CHAIN_ITERATOR_BACKWARD
+} Chain_Iterator_direction;
+ * @brief A chain iterator which is updated during node extraction if it is
+ * properly registered.
+ * @see _Chain_Iterator_initialize().
+typedef struct {
+ * @brief Node for registration.
+ * Used during _Chain_Iterator_initialize() and _Chain_Iterator_destroy().
+ Chain_Node Registry_node;
+ * @brief The direction of this iterator.
+ * Immutable after initialization via _Chain_Iterator_initialize().
+ Chain_Iterator_direction direction;
+ * @brief The current position of this iterator.
+ * The position is initialized via _Chain_Iterator_initialize(). It must be
+ * explicitly set after one valid iteration step, e.g. in case a next node in
+ * the iterator direction existed. It is updated through the registration in
+ * case a node is extracted via _Chain_Iterator_registry_update().
+ Chain_Node *position;
+} Chain_Iterator;
+ * @brief A registry for chain iterators.
+ * Should be attached to a chain control to enable safe iteration through a
+ * chain in case of concurrent node extractions.
+typedef struct {
+ Chain_Control Iterators;
+} Chain_Iterator_registry;
+ * @brief Chain iterator registry initializer for static initialization.
+ * @param name The designator of the chain iterator registry.
+#define CHAIN_ITERATOR_REGISTRY_INITIALIZER( name ) \
+ { CHAIN_INITIALIZER_EMPTY( name.Iterators ) }
+ * @brief Initializes a chain iterator registry.
+RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_initialize(
+ Chain_Iterator_registry *the_registry
+ _Chain_Initialize_empty( &the_registry->Iterators );
+ * @brief Updates all iterators present in the chain iterator registry in case
+ * of a node extraction.
+ * Must be called before _Chain_Extract_unprotected().
+RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_update(
+ Chain_Iterator_registry *the_registry,
+ Chain_Node *the_node_to_extract
+ Chain_Node *iter_node;
+ Chain_Node *iter_tail;
+ iter_node = _Chain_Head( &the_registry->Iterators );
+ iter_tail = _Chain_Tail( &the_registry->Iterators );
+ while ( ( iter_node = _Chain_Next( iter_node ) ) != iter_tail ) {
+ Chain_Iterator *iter;
+ iter = (Chain_Iterator *) iter_node;
+ if ( iter->position == the_node_to_extract ) {
+ if ( iter->direction == CHAIN_ITERATOR_FORWARD ) {
+ iter->position = _Chain_Previous( the_node_to_extract );
+ } else {
+ iter->position = _Chain_Next( the_node_to_extract );
+ * @brief Initializes the chain iterator.
+ * @param the_chain The chain to iterate.
+ * @param the_registry The registry for the chain iterator.
+ * @param the_iterator The chain iterator to initialize.
+ * @param direction The iteration direction.
+ * @see _Chain_Iterator_next(), _Chain_Iterator_set_position() and
+ * Chain_Iterator_destroy().
+RTEMS_INLINE_ROUTINE void _Chain_Iterator_initialize(
+ Chain_Control *the_chain,
+ Chain_Iterator *the_iterator,
+ _Chain_Append_unprotected(
+ &the_registry->Iterators,
+ &the_iterator->Registry_node
+ the_iterator->direction = direction;
+ if ( direction == CHAIN_ITERATOR_FORWARD ) {
+ the_iterator->position = _Chain_Head( the_chain );
+ } else {
+ the_iterator->position = _Chain_Tail( the_chain );
+ * @brief Returns the next node in the iterator direction.
+ * In case a next node exits, then the iterator should be updated via
+ * _Chain_Iterator_set_position() to start the next iteration step.
+ * @param the_iterator The chain iterator.
+RTEMS_INLINE_ROUTINE Chain_Node *_Chain_Iterator_next(
+ if ( the_iterator->direction == CHAIN_ITERATOR_FORWARD ) {
+ return _Chain_Next( the_iterator->position );
+ } else {
+ return _Chain_Previous( the_iterator->position );
+ * @brief Sets the iterator position.
+ * @param the_node The new iterator position.
+RTEMS_INLINE_ROUTINE void _Chain_Iterator_set_position(
+ the_iterator->position = the_node;
+ * @brief Destroys the iterator.
+ * Removes the iterator from its registry.
+RTEMS_INLINE_ROUTINE void _Chain_Iterator_destroy(
+ _Chain_Extract_unprotected( &the_iterator->Registry_node );
#ifdef __cplusplus
diff --git a/testsuites/sptests/spchain/init.c b/testsuites/sptests/spchain/init.c
index 476629b..dd46d68 100644
--- a/testsuites/sptests/spchain/init.c
+++ b/testsuites/sptests/spchain/init.c
@@ -16,6 +16,124 @@
const char rtems_test_name[] = "SPCHAIN";
+static void update_registry_and_extract(
+ Chain_Iterator_registry *reg,
+ Chain_Node *n
+ _Chain_Iterator_registry_update( reg, n );
+ _Chain_Extract_unprotected( n );
+static Chain_Iterator_registry static_reg =
+ CHAIN_ITERATOR_REGISTRY_INITIALIZER( static_reg );
+static void test_chain_iterator( void )
+ Chain_Control chain;
+ Chain_Iterator_registry reg;
+ Chain_Iterator fit;
+ Chain_Iterator bit;
+ Chain_Node a;
+ Chain_Node b;
+ Chain_Node c;
+ puts( "INIT - Verify Chain_Iterator" );
+ rtems_test_assert( _Chain_Is_empty( &static_reg.Iterators ));
+ _Chain_Initialize_empty( &chain );
+ _Chain_Iterator_registry_initialize( ® );
+ _Chain_Iterator_initialize( &chain, ®, &fit, CHAIN_ITERATOR_FORWARD );
+ _Chain_Iterator_initialize( &chain, ®, &bit, CHAIN_ITERATOR_BACKWARD );
+ rtems_test_assert( _Chain_Iterator_next( &fit ) == _Chain_Tail( &chain ));
+ rtems_test_assert( _Chain_Iterator_next( &bit ) == _Chain_Head( &chain ));
+ _Chain_Iterator_set_position( &fit, _Chain_Head( &chain ) );
+ _Chain_Iterator_set_position( &bit, _Chain_Tail( &chain ) );
+ _Chain_Append_unprotected( &chain, &a );
+ rtems_test_assert( _Chain_Iterator_next( &fit ) == &a );
+ rtems_test_assert( _Chain_Iterator_next( &bit ) == &a );
+ _Chain_Append_unprotected( &chain, &b );
+ rtems_test_assert( _Chain_Iterator_next( &bit ) == &b );
+ _Chain_Append_unprotected( &chain, &c );
+ rtems_test_assert( _Chain_Iterator_next( &bit ) == &c );
+ update_registry_and_extract( ®, &b );
+ _Chain_Insert_unprotected( &a, &b );
+ update_registry_and_extract( ®, &c );
+ update_registry_and_extract( ®, &a );
+ rtems_test_assert( _Chain_Iterator_next( &fit ) == &b );
+ _Chain_Prepend_unprotected( &chain, &a );
+ rtems_test_assert( _Chain_Iterator_next( &fit ) == &c );
+ rtems_test_assert( !_Chain_Is_empty( ®.Iterators ));
+ _Chain_Iterator_destroy( &fit );
+ _Chain_Iterator_destroy( &bit );
+ rtems_test_assert( _Chain_Is_empty( ®.Iterators ));
/* forward declarations to avoid warnings */
rtems_task Init(rtems_task_argument argument);
@@ -341,6 +459,7 @@ rtems_task Init(
test_chain_control_initializer();
test_chain_node_count();
test_chain_insert_ordered();
+ test_chain_iterator();
TEST_END();
rtems_test_exit(0);
diff --git a/testsuites/sptests/spchain/spchain.doc b/testsuites/sptests/spchain/spchain.doc
index 511e0b5..4962426 100644
--- a/testsuites/sptests/spchain/spchain.doc
+++ b/testsuites/sptests/spchain/spchain.doc
@@ -25,6 +25,12 @@ directives:
rtems_chain_get_with_wait
rtems_chain_node_count_unprotected
+ _Chain_Iterator_next
concepts:
diff --git a/testsuites/sptests/spchain/spchain.scn b/testsuites/sptests/spchain/spchain.scn
index 39f3795..4aff306 100644
--- a/testsuites/sptests/spchain/spchain.scn
+++ b/testsuites/sptests/spchain/spchain.scn
@@ -1,4 +1,4 @@
-*** TEST OF RTEMS CHAIN API ***
+*** BEGIN OF TEST SPCHAIN ***
Init - Initialize chain empty
INIT - Verify rtems_chain_insert
INIT - Verify rtems_chain_is_first
@@ -14,4 +14,5 @@ INIT - Verify rtems_chain_control layout
INIT - Verify rtems_chain_control initializer
INIT - Verify rtems_chain_node_count_unprotected
INIT - Verify _Chain_Insert_ordered_unprotected
-*** END OF RTEMS CHAIN API TEST ***
+INIT - Verify Chain_Iterator
+*** END OF TEST SPCHAIN ***
1.8.4.5
