[PATCH 4/4] score: Use chain iterator for user extensions
Fri Apr 15 09:16:08 UTC 2016
Add a lock and use a chain iterator for safe iteration during concurrent
user extension addition and removal.
Ensure that dynamically added thread delete and fatal extensions are
called in reverse order.
Update #2555.
Update #2692.
 cpukit/score/include/rtems/score/thread.h          |   7 +
 cpukit/score/include/rtems/score/userextimpl.h     | 108 ++++-
 cpukit/score/src/threadrestart.c                   |   2 +
 cpukit/score/src/userextaddset.c                   |  14 +-
 cpukit/score/src/userextiterate.c                  |  84 +++-
 cpukit/score/src/userextremoveset.c                |   9 +-
 testsuites/sptests/Makefile.am                     |   1 +
 testsuites/sptests/configure.ac                    |   1 +
 testsuites/sptests/spextensions01/Makefile.am      |  19 +
 testsuites/sptests/spextensions01/init.c           | 447 +++++++++++++++++++++
 .../sptests/spextensions01/spextensions01.doc      |  12 +
 .../sptests/spextensions01/spextensions01.scn      |   2 +
 12 files changed, 666 insertions(+), 40 deletions(-)
 create mode 100644 testsuites/sptests/spextensions01/Makefile.am
 create mode 100644 testsuites/sptests/spextensions01/init.c
 create mode 100644 testsuites/sptests/spextensions01/spextensions01.doc
 create mode 100644 testsuites/sptests/spextensions01/spextensions01.scn
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index d9f1eb2..4da4a34 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -48,6 +48,8 @@ struct Scheduler_Control;
 struct Scheduler_Node;
+struct User_extensions_Iterator;
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -899,6 +901,11 @@ struct _Thread_Control {
   struct _pthread_cleanup_context *last_cleanup_context;
+   * @brief LIFO list of user extensions iterators.
+  struct User_extensions_Iterator *last_user_extensions_iterator;
    * @brief Variable length array of user extension pointers.
    * The length is defined by the application via <rtems/confdefs.h>.
diff --git a/cpukit/score/include/rtems/score/userextimpl.h b/cpukit/score/include/rtems/score/userextimpl.h
index 8c2a1fa..e175c9f 100644
--- a/cpukit/score/include/rtems/score/userextimpl.h
+++ b/cpukit/score/include/rtems/score/userextimpl.h
@@ -19,6 +19,7 @@
 #define _RTEMS_SCORE_USEREXTIMPL_H
 #include <rtems/score/userext.h>
+#include <rtems/score/isrlock.h>
@@ -36,9 +37,41 @@ extern "C" {
+ * @brief Chain iterator for dynamic user extensions.
+ * Since user extensions may delete or restart the executing thread, we must
+ * clean up registered iterators.
+ * @see _User_extensions_Iterate(), _User_extensions_Destroy_iterators() and
+ *   Thread_Control::last_user_extensions_iterator.
+typedef struct User_extensions_Iterator {
+  Chain_Iterator                   Iterator;
+  struct User_extensions_Iterator *previous;
+} User_extensions_Iterator;
+typedef struct {
+   * @brief Active dynamically added user extensions.
+  Chain_Control Active;
+   * @brief Chain iterator registration.
+  Chain_Iterator_registry Iterators;
+   * @brief Lock to protect User_extensions_List::Active and
+   * User_extensions_List::Iterators.
+  ISR_LOCK_MEMBER( Lock )
+} User_extensions_List;
  * @brief List of active extensions.
-extern Chain_Control _User_extensions_List;
+extern User_extensions_List _User_extensions_List;
  * @brief List of active task switch extensions.
@@ -153,11 +186,13 @@ void _User_extensions_Thread_terminate_visitor(
  * @brief Iterates through all user extensions and calls the visitor for each.
  * @param[in, out] arg The argument passed to the visitor.
- * @param[in] visitor is the visitor for each extension.
+ * @param[in] visitor The visitor for each extension.
+ * @param[in] direction The iteration direction for dynamic extensions.
 void _User_extensions_Iterate(
-  void                    *arg,
-  User_extensions_Visitor  visitor
+  void                     *arg,
+  User_extensions_Visitor   visitor,
+  Chain_Iterator_direction  direction
@@ -171,7 +206,11 @@ static inline bool _User_extensions_Thread_create( Thread_Control *created )
   User_extensions_Thread_create_context ctx = { created, true };
-  _User_extensions_Iterate( &ctx, _User_extensions_Thread_create_visitor );
+  _User_extensions_Iterate(
+    &ctx,
+    _User_extensions_Thread_create_visitor,
+    CHAIN_ITERATOR_FORWARD
   return ctx.ok;
@@ -180,7 +219,8 @@ static inline void _User_extensions_Thread_delete( Thread_Control *deleted )
     deleted,
-    _User_extensions_Thread_delete_visitor
+    _User_extensions_Thread_delete_visitor,
+    CHAIN_ITERATOR_BACKWARD
@@ -188,7 +228,8 @@ static inline void _User_extensions_Thread_start( Thread_Control *started )
     started,
-    _User_extensions_Thread_start_visitor
+    _User_extensions_Thread_start_visitor,
@@ -196,7 +237,8 @@ static inline void _User_extensions_Thread_restart( Thread_Control *restarted )
     restarted,
-    _User_extensions_Thread_restart_visitor
+    _User_extensions_Thread_restart_visitor,
@@ -204,7 +246,8 @@ static inline void _User_extensions_Thread_begin( Thread_Control *executing )
     executing,
-    _User_extensions_Thread_begin_visitor
+    _User_extensions_Thread_begin_visitor,
@@ -239,7 +282,8 @@ static inline void _User_extensions_Thread_exitted( Thread_Control *executing )
     executing,
-    _User_extensions_Thread_exitted_visitor
+    _User_extensions_Thread_exitted_visitor,
@@ -251,7 +295,11 @@ static inline void _User_extensions_Fatal(
   User_extensions_Fatal_context ctx = { source, is_internal, error };
-  _User_extensions_Iterate( &ctx, _User_extensions_Fatal_visitor );
+    &ctx,
+    _User_extensions_Fatal_visitor,
 static inline void _User_extensions_Thread_terminate(
@@ -260,10 +308,46 @@ static inline void _User_extensions_Thread_terminate(
     executing,
-    _User_extensions_Thread_terminate_visitor
+    _User_extensions_Thread_terminate_visitor,
+static inline void _User_extensions_Acquire( ISR_lock_Context *lock_context )
+  _ISR_lock_ISR_disable_and_acquire(
+    &_User_extensions_List.Lock,
+    lock_context
+static inline void _User_extensions_Release( ISR_lock_Context *lock_context )
+  _ISR_lock_Release_and_ISR_enable(
+    lock_context
+static inline void _User_extensions_Destroy_iterators(
+  Thread_Control *the_thread
+  ISR_lock_Context          lock_context;
+  User_extensions_Iterator *iter;
+  _User_extensions_Acquire( &lock_context );
+  iter = the_thread->last_user_extensions_iterator;
+  while ( iter != NULL ) {
+    _Chain_Iterator_destroy( &iter->Iterator );
+    iter = iter->previous;
+  _User_extensions_Release( &lock_context );
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 59754a8..13b4365 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -97,6 +97,7 @@ static void _Thread_Free( Thread_Control *the_thread )
     _Objects_Get_information_id( the_thread->Object.id );
   _User_extensions_Thread_delete( the_thread );
+  _User_extensions_Destroy_iterators( the_thread );
   _ISR_lock_Destroy( &the_thread->Keys.Lock );
   _Scheduler_Node_destroy( _Scheduler_Get( the_thread ), the_thread );
   _ISR_lock_Destroy( &the_thread->Timer.Lock );
@@ -255,6 +256,7 @@ void _Thread_Life_action_handler(
       executing->Life.state = THREAD_LIFE_NORMAL;
+      _User_extensions_Destroy_iterators( executing );
       _Thread_Load_environment( executing );
       _Thread_Restart_self( executing );
       RTEMS_UNREACHABLE();
diff --git a/cpukit/score/src/userextaddset.c b/cpukit/score/src/userextaddset.c
index f34ad00..19bbd36 100644
--- a/cpukit/score/src/userextaddset.c
+++ b/cpukit/score/src/userextaddset.c
@@ -20,20 +20,20 @@
 #endif
 #include <rtems/score/userextimpl.h>
-#include <rtems/score/objectimpl.h>
-#include <rtems/score/sysstate.h>
 void _User_extensions_Add_set(
   User_extensions_Control *the_extension
-  _Assert(
-    _Objects_Allocator_is_owner()
-      || _System_state_Is_before_multitasking( _System_state_Get() )
-  _Chain_Append_unprotected( &_User_extensions_List, &the_extension->Node );
+  _Chain_Append_unprotected(
+    &_User_extensions_List.Active,
+    &the_extension->Node
    * If a switch handler is present, append it to the switch chain.
diff --git a/cpukit/score/src/userextiterate.c b/cpukit/score/src/userextiterate.c
index beeee95..6cb8774 100644
--- a/cpukit/score/src/userextiterate.c
+++ b/cpukit/score/src/userextiterate.c
@@ -7,10 +7,10 @@
- * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2012, 2016 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
- *  Obere Lagerstr. 30
+ *  Dornierstr. 4
  *  82178 Puchheim
  *  Germany
  *  <rtems at embedded-brains.de>
@@ -27,7 +27,16 @@
 #include <rtems/config.h>
-CHAIN_DEFINE_EMPTY( _User_extensions_List );
+#include <pthread.h>
+User_extensions_List _User_extensions_List = {
+  CHAIN_INITIALIZER_EMPTY( _User_extensions_List.Active ),
+  CHAIN_ITERATOR_REGISTRY_INITIALIZER( _User_extensions_List.Iterators )
+#if defined(RTEMS_SMP)
+  ISR_LOCK_INITIALIZER( "User Extensions List" )
+#endif
 void _User_extensions_Thread_create_visitor(
   Thread_Control              *executing,
@@ -139,17 +148,24 @@ void _User_extensions_Thread_terminate_visitor(
-  void                    *arg,
+  void                     *arg,
-  Thread_Control *executing = _Thread_Get_executing();
-  const User_extensions_Table *callouts_current =
-    rtems_configuration_get_user_extension_table();
-  const User_extensions_Table *callouts_end =
-    callouts_current + rtems_configuration_get_number_of_initial_extensions();
-  const Chain_Node *node;
-  const Chain_Node *tail;
+  Thread_Control              *executing;
+  const User_extensions_Table *callouts_current;
+  const User_extensions_Table *callouts_end;
+  const Chain_Node            *end;
+  Chain_Node                  *node;
+  User_extensions_Iterator     iter;
+  executing = _Thread_Get_executing();
+  callouts_current = rtems_configuration_get_user_extension_table();
+  callouts_end = callouts_current
+    + rtems_configuration_get_number_of_initial_extensions();
   while ( callouts_current != callouts_end ) {
     (*visitor)( executing, arg, callouts_current );
@@ -157,14 +173,44 @@ void _User_extensions_Iterate(
     ++callouts_current;
-  node = _Chain_Immutable_first( &_User_extensions_List );
-  tail = _Chain_Immutable_tail( &_User_extensions_List );
-  while ( node != tail ) {
-    const User_extensions_Control *extension =
-      (const User_extensions_Control *) node;
+  if ( direction == CHAIN_ITERATOR_FORWARD ) {
+    end = _Chain_Immutable_tail( &_User_extensions_List.Active );
+  } else {
+    end = _Chain_Immutable_head( &_User_extensions_List.Active );
+  _Chain_Iterator_initialize(
+    &_User_extensions_List.Iterators,
+    &iter.Iterator,
+    direction
+  if ( executing != NULL ) {
+    iter.previous = executing->last_user_extensions_iterator;
+    executing->last_user_extensions_iterator = &iter;
+  while ( ( node = _Chain_Iterator_next( &iter.Iterator ) ) != end ) {
+    const User_extensions_Control *extension;
+    _Chain_Iterator_set_position( &iter.Iterator, node );
-    (*visitor)( executing, arg, &extension->Callouts );
+    extension = (const User_extensions_Control *) node;
+    ( *visitor )( executing, arg, &extension->Callouts );
-    node = _Chain_Immutable_next( node );
+    executing->last_user_extensions_iterator = iter.previous;
+  _Chain_Iterator_destroy( &iter.Iterator );
diff --git a/cpukit/score/src/userextremoveset.c b/cpukit/score/src/userextremoveset.c
index 5b3fdd1..b25cc34 100644
--- a/cpukit/score/src/userextremoveset.c
+++ b/cpukit/score/src/userextremoveset.c
@@ -20,16 +20,21 @@
 #endif
 void _User_extensions_Remove_set (
-  _Assert( _Objects_Allocator_is_owner() );
+  _Chain_Iterator_registry_update(
   _Chain_Extract_unprotected( &the_extension->Node );
    * If a switch handler is present, remove it.
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 43f3d82..77acaba 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -33,6 +33,7 @@ _SUBDIRS = \
     spsignal_err01 spport_err01 spmsgq_err01 spmsgq_err02 spsem_err01 \
     spsem_err02 sptask_err01 spevent_err03 sptask_err03 sptask_err02 \
     sptask_err04 spclock_err01
+_SUBDIRS += spextensions01
 _SUBDIRS += spsysinit01
 if HAS_SMP
 else
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index eeebc91..66f6860 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -46,6 +46,7 @@ AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+spextensions01/Makefile
 sptimerserver01/Makefile
 spsysinit01/Makefile
 splinkersets01/Makefile
diff --git a/testsuites/sptests/spextensions01/Makefile.am b/testsuites/sptests/spextensions01/Makefile.am
new file mode 100644
index 0000000..610c2b5
--- /dev/null
+++ b/testsuites/sptests/spextensions01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spextensions01
+spextensions01_SOURCES = init.c
+dist_rtems_tests_DATA = spextensions01.scn spextensions01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spextensions01_OBJECTS)
+LINK_LIBS = $(spextensions01_LDLIBS)
+spextensions01$(EXEEXT): $(spextensions01_OBJECTS) $(spextensions01_DEPENDENCIES)
+	@rm -f spextensions01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spextensions01/init.c b/testsuites/sptests/spextensions01/init.c
index 0000000..d8593b9
--- /dev/null
+++ b/testsuites/sptests/spextensions01/init.c
@@ -0,0 +1,447 @@
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <assert.h>
+#include <limits.h>
+#include <stdlib.h>
+#include <rtems/test.h>
+#include <bsp.h>
+const char rtems_test_name[] = "SPEXTENSIONS 1";
+static int counter;
+static int active_extensions = 2;
+static rtems_id master_task;
+static void assert_static_order(int index)
+  assert((counter % active_extensions) == index);
+  ++counter;
+static void assert_forward_order(int index)
+  ++counter;
+static void assert_reverse_order(int index)
+  assert((counter % active_extensions) == (5 - index));
+  ++counter;
+static bool zero_thread_create(rtems_tcb *a, rtems_tcb *b)
+  assert_static_order(0);
+  return true;
+static void zero_thread_start(rtems_tcb *a, rtems_tcb *b)
+static void zero_thread_restart(rtems_tcb *a, rtems_tcb *b)
+static void zero_thread_delete(rtems_tcb *a, rtems_tcb *b)
+static void zero_thread_switch(rtems_tcb *a, rtems_tcb *b)
+static void zero_thread_begin(rtems_tcb *a)
+static void zero_thread_exitted(rtems_tcb *a)
+static void zero_fatal(
+  rtems_fatal_source source,
+  bool is_internal,
+  rtems_fatal_code code
+  if (source == RTEMS_FATAL_SOURCE_EXIT) {
+static void zero_thread_terminate(rtems_tcb *a)
+static bool one_thread_create(rtems_tcb *a, rtems_tcb *b)
+  assert_static_order(1);
+  return true;
+static void one_thread_start(rtems_tcb *a, rtems_tcb *b)
+static void one_thread_restart(rtems_tcb *a, rtems_tcb *b)
+static void one_thread_delete(rtems_tcb *a, rtems_tcb *b)
+static void one_thread_switch(rtems_tcb *a, rtems_tcb *b)
+static void one_thread_begin(rtems_tcb *a)
+static void one_thread_exitted(rtems_tcb *a)
+static void one_fatal(
+  bool is_internal,
+static void one_thread_terminate(rtems_tcb *a)
+static bool two_thread_create(rtems_tcb *a, rtems_tcb *b)
+  assert_forward_order(2);
+  return true;
+static void two_thread_start(rtems_tcb *a, rtems_tcb *b)
+static void two_thread_restart(rtems_tcb *a, rtems_tcb *b)
+  assert_static_order(2);
+static void two_thread_delete(rtems_tcb *a, rtems_tcb *b)
+  assert_reverse_order(2);
+static void two_thread_switch(rtems_tcb *a, rtems_tcb *b)
+static void two_thread_begin(rtems_tcb *a)
+static void two_thread_exitted(rtems_tcb *a)
+static void two_fatal(
+  bool is_internal,
+    assert(counter == 72);
+    rtems_test_endk();
+static void two_thread_terminate(rtems_tcb *a)
+static bool three_thread_create(rtems_tcb *a, rtems_tcb *b)
+  assert_forward_order(3);
+  return true;
+static void three_thread_start(rtems_tcb *a, rtems_tcb *b)
+static void three_thread_restart(rtems_tcb *a, rtems_tcb *b)
+  assert_static_order(3);
+static void three_thread_delete(rtems_tcb *a, rtems_tcb *b)
+  assert_reverse_order(3);
+static void three_thread_switch(rtems_tcb *a, rtems_tcb *b)
+static void three_thread_begin(rtems_tcb *a)
+static void three_thread_exitted(rtems_tcb *a)
+static void three_fatal(
+  bool is_internal,
+static void three_thread_terminate(rtems_tcb *a)
+#define ZERO \
+    .thread_create = zero_thread_create, \
+    .thread_start = zero_thread_start, \
+    .thread_restart = zero_thread_restart, \
+    .thread_delete = zero_thread_delete, \
+    .thread_switch = zero_thread_switch, \
+    .thread_begin = zero_thread_begin, \
+    .thread_exitted = zero_thread_exitted, \
+    .fatal = zero_fatal, \
+    .thread_terminate = zero_thread_terminate \
+#define ONE \
+    .thread_create = one_thread_create, \
+    .thread_start = one_thread_start, \
+    .thread_restart = one_thread_restart, \
+    .thread_delete = one_thread_delete, \
+    .thread_switch = one_thread_switch, \
+    .thread_begin = one_thread_begin, \
+    .thread_exitted = one_thread_exitted, \
+    .fatal = one_fatal, \
+    .thread_terminate = one_thread_terminate \
+static const rtems_extensions_table two = {
+  .thread_create = two_thread_create,
+  .thread_start = two_thread_start,
+  .thread_restart = two_thread_restart,
+  .thread_delete = two_thread_delete,
+  .thread_switch = two_thread_switch,
+  .thread_begin = two_thread_begin,
+  .thread_exitted = two_thread_exitted,
+  .fatal = two_fatal,
+  .thread_terminate = two_thread_terminate
+static const rtems_extensions_table three = {
+  .thread_create = three_thread_create,
+  .thread_start = three_thread_start,
+  .thread_restart = three_thread_restart,
+  .thread_delete = three_thread_delete,
+  .thread_switch = three_thread_switch,
+  .thread_begin = three_thread_begin,
+  .thread_exitted = three_thread_exitted,
+  .fatal = three_fatal,
+  .thread_terminate = three_thread_terminate
+static const rtems_extensions_table initial_test =
+  RTEMS_TEST_INITIAL_EXTENSION;
+#ifdef BSP_INITIAL_EXTENSION
+static const rtems_extensions_table initial_bsp =
+  BSP_INITIAL_EXTENSION;
+#endif
+static void wake_up_master(void)
+  rtems_status_code sc;
+  sc = rtems_event_transient_send(master_task);
+  assert(sc == RTEMS_SUCCESSFUL);
+static void wait_for_worker(void)
+  sc = rtems_event_transient_receive(
+    RTEMS_WAIT,
+    RTEMS_NO_TIMEOUT
+static void worker(rtems_task_argument arg)
+  wake_up_master();
+  (void) rtems_task_suspend(RTEMS_SELF);
+  assert(false);
+static void test(void)
+  rtems_id id;
+  master_task = rtems_task_self();
+  sc = rtems_extension_create(
+    rtems_build_name(' ', 'B', 'S', 'P'),
+    &initial_bsp,
+    &id
+#undef BSP_INITIAL_EXTENSION
+#endif
+    rtems_build_name('T', 'E', 'S', 'T'),
+    &initial_test,
+    &id
+    rtems_build_name('2', ' ', ' ', ' '),
+    &two,
+    &id
+    rtems_build_name('3', ' ', ' ', ' '),
+    &three,
+    &id
+  active_extensions = 4;
+  assert(counter == 14);
+  counter = 16;
+  sc = rtems_task_create(
+    rtems_build_name('W', 'O', 'R', 'K'),
+    2,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &id
+  sc = rtems_task_start(id, worker, 0);
+  wait_for_worker();
+  sc = rtems_task_restart(id, 0);
+  sc = rtems_task_delete(id);
+  /* Process zombies to trigger delete extensions */
+    rtems_build_name('N', 'U', 'L', 'L'),
+    2,
+    SIZE_MAX,
+    &id
+  assert(sc == RTEMS_UNSATISFIED);
+static void Init(rtems_task_argument arg)
+  rtems_test_begink();
+  test();
+  exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 4
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_INITIAL_EXTENSIONS ZERO, ONE
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spextensions01/spextensions01.doc b/testsuites/sptests/spextensions01/spextensions01.doc
index 0000000..5e91e84
--- /dev/null
+++ b/testsuites/sptests/spextensions01/spextensions01.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spextensions01
+directives:
+  - rtems_extension_create()
+  - _User_extensions_Iterate()
+concepts:
+  - Ensure that the user extensions are called in the right order.
diff --git a/testsuites/sptests/spextensions01/spextensions01.scn b/testsuites/sptests/spextensions01/spextensions01.scn
index 0000000..7a51b94
--- /dev/null
+++ b/testsuites/sptests/spextensions01/spextensions01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SPEXTENSIONS 1 ***
+*** END OF TEST SPEXTENSIONS 1 ***
1.8.4.5
