libbsd errors with the latest tools ...
Fri Apr 15 09:18:20 UTC 2016
> On 15 Apr 2016, at 7:13 PM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 15/04/16 10:28, Chris Johns wrote:
>>> On 15/04/2016 18:22, Sebastian Huber wrote:
>>>> On 15/04/16 09:53, Chris Johns wrote:
>>>> The following is just a small sample of the errors I am seeing with
>>>> the latest tools building libbsd. Anyone else seeing these?
>>> What are the latest tools for you in this case?
>> tools/rtems-gcc-6-20160327-newlib-2.4.0-1
> Ok, I didn't use this tool set up. I work currently with the latest Newlib to sort out the <sys/types.h> incompatibilities.
> I do a RSB build now and have a look at this next week.
Thanks. Joel will be about sometime soon. I am off and out for the weekend ... my week does start before yours. :)
>> Reverting to tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1 get further not breaks with a different error ...
>> In file included from /opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:47:0,
>>                 from /opt/work/chris/rtems/libbsd/rtems-libbsd.master/rtemsbsd/include/rtems/bsd/sys/time.h:34,
>>                 from /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/contrib/libpcap/pcap/pcap.h:47,
>>                 from ../../freebsd/contrib/libpcap/pcap-int.h:39,
>>                 from ../../freebsd/contrib/libpcap/scanner.l:51:
>> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:18: error: unknown type name 'fd_set'
>> int pselect(int, fd_set *__restrict, fd_set *__restrict, fd_set *__restrict,
>> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:38: error: unknown type name 'fd_set'
>> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:58: error: unknown type name 'fd_set'
>> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:17: error: unknown type name 'fd_set'
>> int select(int, fd_set *, fd_set *, fd_set *, struct timeval *);
>> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:27: error: unknown type name 'fd_set'
>> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:37: error: unknown type name 'fd_set'
>> Chris
> Yes, this is due to a bug in Newlib fixed with a later snapshot.
