[PATCH v2 17/18] Provide __size_t via <sys/_types.h>
Fri Apr 15 11:44:28 UTC 2016
Various FreeBSD source and header files need a typedef __size_t via
<sys/_types.h>.  Unfortunately the GCC provided <stddef.h> uses
	#if (defined (__FreeBSD__) && (__FreeBSD__ >= 5)) \
	  || defined(__DragonFly__) \
	  || defined(__FreeBSD_kernel__)
	/* __size_t is a typedef on FreeBSD 5, must not trash it. */
	#elif defined (__VMS__)
	/* __size_t is also a typedef on VMS.  */
	#else
	#define __size_t
	#endif
and therefore defines __size_t on Newlib targets which would trash a
__size_t typedef.  Include <stddef.h> before <sys/_types.h> in
<sys/types.h> and undefine __size_t in <sys/_types.h> as a workaround.
Signed-off-by: Sebastian Huber <sebastian.huber at embedded-brains.de>
 newlib/libc/include/sys/_types.h | 15 +++++++++++++++
 newlib/libc/include/sys/types.h  |  4 ++--
 2 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/newlib/libc/include/sys/_types.h b/newlib/libc/include/sys/_types.h
index 6a2c94d..06ddd83 100644
--- a/newlib/libc/include/sys/_types.h
+++ b/newlib/libc/include/sys/_types.h
@@ -119,6 +119,21 @@ typedef _off64_t _fpos64_t;
 #endif
 #endif
+/* Defined by GCC provided <stddef.h> */
+#undef __size_t
+#ifndef __machine_size_t_defined
+#ifdef __SIZE_TYPE__
+typedef __SIZE_TYPE__ __size_t;
+#else
+#if defined(__INT_MAX__) && __INT_MAX__ == 2147483647
+typedef int __size_t;
+#else
+typedef long __size_t;
+#endif
+#endif
+#endif
 #ifndef __machine_ssize_t_defined
 /* If __SIZE_TYPE__ is defined (gcc) we define ssize_t based on size_t.
diff --git a/newlib/libc/include/sys/types.h b/newlib/libc/include/sys/types.h
index 57b74ef..31f765e 100644
--- a/newlib/libc/include/sys/types.h
+++ b/newlib/libc/include/sys/types.h
@@ -56,11 +56,11 @@ typedef	quad_t *	qaddr_t;
 #ifndef __need_inttypes
 #define _SYS_TYPES_H
+/* <stddef.h> must be before <sys/_types.h> for __size_t considerations */
+#include <stddef.h>
 #include <sys/_types.h>
 #include <sys/_stdint.h>
-# include <stddef.h>
 #if __BSD_VISIBLE
 #include <machine/endian.h>
 #include <sys/select.h>
1.8.4.5
