[PATCH v2 10/18] Provide POSIX defined blksize_t in <sys/types.h>
Fri Apr 15 11:44:21 UTC 2016
Signed-off-by: Sebastian Huber <sebastian.huber at embedded-brains.de>
 newlib/libc/include/sys/_types.h               | 4 ++++
 newlib/libc/include/sys/stat.h                 | 2 +-
 newlib/libc/include/sys/types.h                | 5 +++++
 newlib/libc/sys/rtems/include/machine/_types.h | 5 +++--
 winsup/cygwin/include/cygwin/types.h           | 5 -----
 winsup/cygwin/include/machine/_types.h         | 3 +++
 6 files changed, 16 insertions(+), 8 deletions(-)
diff --git a/newlib/libc/include/sys/_types.h b/newlib/libc/include/sys/_types.h
index 13362ad..0d48f04 100644
--- a/newlib/libc/include/sys/_types.h
+++ b/newlib/libc/include/sys/_types.h
@@ -26,6 +26,10 @@
 typedef long __blkcnt_t;
 #endif
+#ifndef __machine_blksize_t_defined
+typedef long __blksize_t;
+#endif
 #ifndef __machine_off_t_defined
 typedef long _off_t;
 #endif
diff --git a/newlib/libc/include/sys/stat.h b/newlib/libc/include/sys/stat.h
index a75c1c2..94a90c0 100644
--- a/newlib/libc/include/sys/stat.h
+++ b/newlib/libc/include/sys/stat.h
@@ -53,7 +53,7 @@ struct	stat
   long		st_spare2;
   time_t	st_ctime;
   long		st_spare3;
-  long		st_blksize;
+  blksize_t	st_blksize;
   blkcnt_t	st_blocks;
   long	st_spare4[2];
 #endif
diff --git a/newlib/libc/include/sys/types.h b/newlib/libc/include/sys/types.h
index ac8252e..24d90cd 100644
--- a/newlib/libc/include/sys/types.h
+++ b/newlib/libc/include/sys/types.h
@@ -101,6 +101,11 @@ typedef	__blkcnt_t	blkcnt_t;
 #define	_BLKCNT_T_DECLARED
 #endif
+#ifndef _BLKSIZE_T_DECLARED
+typedef	__blksize_t	blksize_t;
+#define	_BLKSIZE_T_DECLARED
+#endif
 #if !defined(__clock_t_defined) && !defined(_CLOCK_T_DECLARED)
 typedef	_CLOCK_T_	clock_t;
 #define	__clock_t_defined
diff --git a/newlib/libc/sys/rtems/include/machine/_types.h b/newlib/libc/sys/rtems/include/machine/_types.h
index 3dbcb3d..ed09206 100644
--- a/newlib/libc/sys/rtems/include/machine/_types.h
+++ b/newlib/libc/sys/rtems/include/machine/_types.h
@@ -3,11 +3,12 @@
 #include <machine/_default_types.h>
-typedef	__int32_t	blksize_t;
 typedef	__int32_t	__blkcnt_t;
 #define	__machine_blkcnt_t_defined
+typedef	__int32_t	__blksize_t;
+#define	__machine_blksize_t_defined
 typedef	__uint64_t	__dev_t;
 #define	__machine_dev_t_defined
diff --git a/winsup/cygwin/include/cygwin/types.h b/winsup/cygwin/include/cygwin/types.h
index b7c3e23..9e13d04 100644
--- a/winsup/cygwin/include/cygwin/types.h
+++ b/winsup/cygwin/include/cygwin/types.h
@@ -34,11 +34,6 @@ typedef struct timespec timestruc_t;
 typedef __loff_t loff_t;
-#ifndef __blksize_t_defined
-#define __blksize_t_defined
-#endif /*__blksize_t_defined*/
 #ifndef __fsblkcnt_t_defined
 #define __fsblkcnt_t_defined
 /* Keep as is.  32 bit on i386, 64 bit on x86_64. */
diff --git a/winsup/cygwin/include/machine/_types.h b/winsup/cygwin/include/machine/_types.h
index f014cdc..f09f1ef 100644
--- a/winsup/cygwin/include/machine/_types.h
+++ b/winsup/cygwin/include/machine/_types.h
@@ -16,6 +16,9 @@ typedef __uint32_t __ino32_t;
 typedef __uint64_t __blkcnt_t;
 typedef __uint32_t __dev_t;
1.8.4.5
