libbsd errors with the latest tools ...
Joel Sherrill
joel at rtems.org
Fri Apr 15 12:50:30 UTC 2016
On Fri, Apr 15, 2016 at 4:18 AM, Chris Johns <chrisj at rtems.org> wrote:
> > On 15 Apr 2016, at 7:13 PM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> >> On 15/04/16 10:28, Chris Johns wrote:
> >>> On 15/04/2016 18:22, Sebastian Huber wrote:
> >>>> On 15/04/16 09:53, Chris Johns wrote:
> >>>> The following is just a small sample of the errors I am seeing with
> >>>> the latest tools building libbsd. Anyone else seeing these?
> >>> What are the latest tools for you in this case?
> >> tools/rtems-gcc-6-20160327-newlib-2.4.0-1
> > Ok, I didn't use this tool set up. I work currently with the latest
> Newlib to sort out the <sys/types.h> incompatibilities.
> > I do a RSB build now and have a look at this next week.
> Thanks. Joel will be about sometime soon. I am off and out for the weekend
> ... my week does start before yours. :)
> >> Reverting to tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1 get
> further not breaks with a different error ...
> >> In file included from
> /opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:47:0,
> >> from
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/rtemsbsd/include/rtems/bsd/sys/time.h:34,
> >> from
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/contrib/libpcap/pcap/pcap.h:47,
> >> from ../../freebsd/contrib/libpcap/pcap-int.h:39,
> >> from ../../freebsd/contrib/libpcap/scanner.l:51:
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:18:
> error: unknown type name 'fd_set'
> >> int pselect(int, fd_set *__restrict, fd_set *__restrict, fd_set
> *__restrict,
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:38:
> *__restrict,
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:58:
> *__restrict,
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:17:
> >> int select(int, fd_set *, fd_set *, fd_set *, struct timeval *);
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:27:
> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:37:
> >> Chris
> > Yes, this is due to a bug in Newlib fixed with a later snapshot.
Jeff and I both have built rtems-libbsd with the latest RSB tools for i386
and
didn't see any issues. Chris.. you got me through a waf submodule update
yesterday and it built fine after that.
All I can say that I expected issues due to the feature guard changes and
as soon as Sebastian's patch set is in and there is a newlib snapshot, we
need to bump the tools again.
In the mean time, do we want the RSB to apply that patch? We also have
the crt0.c one.
--joel
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone : +49 89 189 47 41-16
> > Fax : +49 89 189 47 41-09
> > E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160415/5baed452/attachment.html>
