libbsd errors with the latest tools ...
Fri Apr 15 14:28:23 UTC 2016
On Fri, Apr 15, 2016 at 8:50 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Apr 15, 2016 at 4:18 AM, Chris Johns <chrisj at rtems.org> wrote:
>> > On 15 Apr 2016, at 7:13 PM, Sebastian Huber
>> > <sebastian.huber at embedded-brains.de> wrote:
>> >> On 15/04/16 10:28, Chris Johns wrote:
>> >>> On 15/04/2016 18:22, Sebastian Huber wrote:
>> >>>> On 15/04/16 09:53, Chris Johns wrote:
>> >>>> The following is just a small sample of the errors I am seeing with
>> >>>> the latest tools building libbsd. Anyone else seeing these?
>> >>> What are the latest tools for you in this case?
>> >> tools/rtems-gcc-6-20160327-newlib-2.4.0-1
>> > Ok, I didn't use this tool set up. I work currently with the latest
>> > Newlib to sort out the <sys/types.h> incompatibilities.
>> > I do a RSB build now and have a look at this next week.
>> Thanks. Joel will be about sometime soon. I am off and out for the weekend
>> ... my week does start before yours. :)
>> >> Reverting to tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1 get
>> >> further not breaks with a different error ...
>> >> In file included from
>> >> /opt/work/rtems/4.12/i386-rtems4.12/include/sys/time.h:47:0,
>> >>                 from
>> >> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/rtemsbsd/include/rtems/bsd/sys/time.h:34,
>> >>                 from
>> >> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/contrib/libpcap/pcap/pcap.h:47,
>> >>                 from ../../freebsd/contrib/libpcap/pcap-int.h:39,
>> >>                 from ../../freebsd/contrib/libpcap/scanner.l:51:
>> >> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:18:
>> >> error: unknown type name 'fd_set'
>> >> int pselect(int, fd_set *__restrict, fd_set *__restrict, fd_set
>> >> *__restrict,
>> >> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:38:
>> >> *__restrict,
>> >> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:104:58:
>> >> *__restrict,
>> >> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:17:
>> >> int select(int, fd_set *, fd_set *, fd_set *, struct timeval *);
>> >> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:27:
>> >> /opt/work/chris/rtems/libbsd/rtems-libbsd.master/freebsd/sys/sys/select.h:109:37:
>> >> Chris
>> > Yes, this is due to a bug in Newlib fixed with a later snapshot.
> Jeff and I both have built rtems-libbsd with the latest RSB tools for i386
> and
> didn't see any issues.  Chris.. you got me through a waf submodule update
> yesterday and it built fine after that.
<hijack>
I've been looking for a suitable set of instructions for running
libbsd networking tests. Do any such notes exist, especially for a
qemu target?
</hijack>
> All I can say that I expected issues due to the feature guard changes and
> as soon as Sebastian's patch set is in and there is a newlib snapshot, we
> need to bump the tools again.
> In the mean time, do we want the RSB to apply that patch? We also have
> the crt0.c one.
> --joel
>> > Sebastian Huber, embedded brains GmbH
>> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> > Phone   : +49 89 189 47 41-16
>> > Fax     : +49 89 189 47 41-09
>> > E-Mail  : sebastian.huber at embedded-brains.de
>> > PGP     : Public key available on request.
>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
