RTEMS Bootstrap Error
Olufowobi, Habeeb
habeeb.olufowobi at bison.howard.edu
Sun Apr 17 04:13:35 UTC 2016
Hi,
I am trying to build RTEMS for ARM with the recent toolchain but I have
been receiving the below error when I run ./bootstrap. I think there is
some error in the bootstrap file.
I have tried running the ./bootstrap script located in rtems, instead of
using sb-bootstrap but doesn't help. Any ideas on how I can fix this?
RTEMS Source Builder - RTEMS Bootstrap, 4.12 (6843e47ce339)
1/139: autoreconf: configure.ac
2/139: autoreconf: cpukit/configure.ac
Traceback (most recent call last):
File "/home/dipupo/development/rtems/rsb/source-builder/sb-bootstrap",
line 28, in <module>
bootstrap.run(sys.argv)
File "/home/dipupo/development/rtems/rsb/source-builder/sb/bootstrap.py",
line 279, in run
generate(topdir, opts.jobs(opts.defaults['_ncpus']))
line 188, in generate
ac.post_process()
line 158, in post_process
self.command.reraise()
line 119, in reraise
raise self.result[0](self.result[1]).with_traceback(self.result[2])
File "/home/dipupo/development/rtems/rsb/source-builder/sb/error.py",
line 36, in __init__
self.set_output('error: ' + what)
TypeError: cannot concatenate 'str' and 'general' objects
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160417/40799888/attachment.html>
