RTEMS Bootstrap Error
Sun Apr 17 22:19:22 UTC 2016
On 17/04/2016 14:13, Olufowobi, Habeeb wrote:
> I am trying to build RTEMS for ARM with the recent toolchain but I have
> been receiving the below error when I run ./bootstrap. I think there is
> some error in the bootstrap file.
> I have tried running the ./bootstrap script located in rtems, instead of
> using sb-bootstrap but doesn't help.
What did ./bootstrap give as an error?
> Any ideas on how I can fix this?
> RTEMS Source Builder - RTEMS Bootstrap, 4.12 (6843e47ce339)
>    1/139: autoreconf: configure.ac <http://configure.ac>
>    2/139: autoreconf: cpukit/configure.ac <http://configure.ac>
> Traceback (most recent call last):
>    File
> "/home/dipupo/development/rtems/rsb/source-builder/sb-bootstrap", line
> 28, in <module>
>      bootstrap.run(sys.argv)
>    File
> "/home/dipupo/development/rtems/rsb/source-builder/sb/bootstrap.py",
> line 279, in run
>      generate(topdir, opts.jobs <http://opts.jobs>(opts.defaults['_ncpus']))
>    File
> line 188, in generate
>      ac.post_process()
>    File
> line 158, in post_process
>      self.command.reraise()
>    File
> line 119, in reraise
>      raise self.result[0](self.result[1]).with_traceback(self.result[2])
>    File "/home/dipupo/development/rtems/rsb/source-builder/sb/error.py",
> line 36, in __init__
>      self.set_output('error: ' + what)
Can you try:
       self.set_output('error: ' + str(what))
and if that does not work:
  self.set_output('error: ' + type(what))
And let me know what the output it.
Thanks
