[PATCH v2] score: Add Chain_Iterator
Mon Apr 18 16:39:16 UTC 2016
OK thanks for the updates.
On Mon, Apr 18, 2016 at 9:37 AM, Sebastian Huber
> Add a chain iterator for safe iteration of chains with concurrent node
> extraction.
>  cpukit/score/include/rtems/score/chainimpl.h | 239 +++++++++++++++++++++++++++
>  testsuites/sptests/spchain/init.c            | 119 +++++++++++++
>  testsuites/sptests/spchain/spchain.doc       |   6 +
>  testsuites/sptests/spchain/spchain.scn       |   5 +-
>  4 files changed, 367 insertions(+), 2 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/chainimpl.h b/cpukit/score/include/rtems/score/chainimpl.h
> index ff66d46..f78f2d6 100644
> --- a/cpukit/score/include/rtems/score/chainimpl.h
> +++ b/cpukit/score/include/rtems/score/chainimpl.h
> @@ -800,6 +800,245 @@ RTEMS_INLINE_ROUTINE void _Chain_Insert_ordered_unprotected(
>    _Chain_Insert_unprotected( _Chain_Previous( next ), to_insert );
> + * @brief The chain iterator direction.
> +typedef enum {
> +   * @brief Iteration from head to tail.
> +  CHAIN_ITERATOR_FORWARD,
> +   * @brief Iteration from tail to head.
> +  CHAIN_ITERATOR_BACKWARD
> +} Chain_Iterator_direction;
> + * @brief A chain iterator which is updated during node extraction if it is
> + * properly registered.
> + * @see _Chain_Iterator_initialize().
> +typedef struct {
> +   * @brief Node for registration.
> +   * Used during _Chain_Iterator_initialize() and _Chain_Iterator_destroy().
> +  Chain_Node Registry_node;
> +   * @brief The direction of this iterator.
> +   * Immutable after initialization via _Chain_Iterator_initialize().
> +  Chain_Iterator_direction  direction;
> +   * @brief The current position of this iterator.
> +   * The position is initialized via _Chain_Iterator_initialize().  It must be
> +   * explicitly set after one valid iteration step, e.g. in case a next node in
> +   * the iterator direction existed.  It is updated through the registration in
> +   * case a node is extracted via _Chain_Iterator_registry_update().
> +  Chain_Node *position;
> +} Chain_Iterator;
> + * @brief A registry for chain iterators.
> + * Should be attached to a chain control to enable safe iteration through a
> + * chain in case of concurrent node extractions.
> +typedef struct {
> +  Chain_Control Iterators;
> +} Chain_Iterator_registry;
> + * @brief Chain iterator registry initializer for static initialization.
> + * @param name The designator of the chain iterator registry.
> +#define CHAIN_ITERATOR_REGISTRY_INITIALIZER( name ) \
> +  { CHAIN_INITIALIZER_EMPTY( name.Iterators ) }
> + * @brief Initializes a chain iterator registry.
> +RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_initialize(
> +  Chain_Iterator_registry *the_registry
> +  _Chain_Initialize_empty( &the_registry->Iterators );
> + * @brief Updates all iterators present in the chain iterator registry in case
> + * of a node extraction.
> + * Must be called before _Chain_Extract_unprotected().
> + * @warning This function will look at all registered chain iterators to
> + *   determine if an update is necessary.
> +RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_update(
> +  Chain_Iterator_registry *the_registry,
> +  Chain_Node              *the_node_to_extract
> +  Chain_Node *iter_node;
> +  Chain_Node *iter_tail;
> +  iter_node = _Chain_Head( &the_registry->Iterators );
> +  iter_tail = _Chain_Tail( &the_registry->Iterators );
> +  while ( ( iter_node = _Chain_Next( iter_node ) ) != iter_tail ) {
> +    Chain_Iterator *iter;
> +    iter = (Chain_Iterator *) iter_node;
> +    if ( iter->position == the_node_to_extract ) {
> +      if ( iter->direction == CHAIN_ITERATOR_FORWARD ) {
> +        iter->position = _Chain_Previous( the_node_to_extract );
> +      } else {
> +        iter->position = _Chain_Next( the_node_to_extract );
> + * @brief Initializes the chain iterator.
> + * In the following example nodes inserted during the iteration are visited in
> + * case they are inserted after the current position in iteration order.
> + * @code
> + * #include <rtems/score/chainimpl.h>
> + * #include <rtems/score/isrlock.h>
> + * typedef struct {
> + *   Chain_Control           Chain;
> + *   Chain_Iterator_registry Iterators;
> + *   ISR_LOCK_MEMBER(        Lock )
> + * } Some_Control;
> + * void iterate(
> + *   Some_Control   *the_some,
> + *   void         ( *visitor )( Chain_Node * )
> + *   ISR_lock_Context  lock_context;
> + *   Chain_Iterator    iter;
> + *   Chain_Node       *node;
> + *   const Chain_Node *end;
> + *   end = _Chain_Immutable_tail( &the_some->Chain );
> + *   _ISR_lock_ISR_disable_and_acquire( &the_some->Lock, &lock_context );
> + *   _Chain_Iterator_initialize(
> + *     &the_some->Chain,
> + *     &the_some->Iterators,
> + *     &iter,
> + *     CHAIN_ITERATOR_FORWARD
> + *   while ( ( node = _Chain_Iterator_next( &iter ) ) != end ) {
> + *     _Chain_Iterator_set_position( &iter, node );
> + *     _ISR_lock_Release_and_ISR_enable( &the_some->Lock, &lock_context );
> + *     ( *visitor )( node );
> + *   _Chain_Iterator_destroy( &iter );
> + * @endcode
> + * @param the_chain The chain to iterate.
> + * @param the_registry The registry for the chain iterator.
> + * @param the_iterator The chain iterator to initialize.
> + * @param direction The iteration direction.
> + * @see _Chain_Iterator_next(), _Chain_Iterator_set_position() and
> + * Chain_Iterator_destroy().
> + * @warning Think twice before you use a chain iterator.  Its current
> + *   implementation is unfit for use in performance relevant components, due to
> + *   the linear time complexity in _Chain_Iterator_registry_update().
> +RTEMS_INLINE_ROUTINE void _Chain_Iterator_initialize(
> +  Chain_Control            *the_chain,
> +  Chain_Iterator           *the_iterator,
> +  _Chain_Append_unprotected(
> +    &the_registry->Iterators,
> +    &the_iterator->Registry_node
> +  the_iterator->direction = direction;
> +  if ( direction == CHAIN_ITERATOR_FORWARD ) {
> +    the_iterator->position = _Chain_Head( the_chain );
> +  } else {
> +    the_iterator->position = _Chain_Tail( the_chain );
> + * @brief Returns the next node in the iterator direction.
> + * In case a next node exists, then the iterator should be updated via
> + * _Chain_Iterator_set_position() to continue with the next iteration step.
> + * @param the_iterator The chain iterator.
> +RTEMS_INLINE_ROUTINE Chain_Node *_Chain_Iterator_next(
> +  const Chain_Iterator *the_iterator
> +  if ( the_iterator->direction == CHAIN_ITERATOR_FORWARD ) {
> +    return _Chain_Next( the_iterator->position );
> +  } else {
> +    return _Chain_Previous( the_iterator->position );
> + * @brief Sets the iterator position.
> + * @param the_node The new iterator position.
> +RTEMS_INLINE_ROUTINE void _Chain_Iterator_set_position(
> +  the_iterator->position = the_node;
> + * @brief Destroys the iterator.
> + * Removes the iterator from its registry.
> +RTEMS_INLINE_ROUTINE void _Chain_Iterator_destroy(
> +  _Chain_Extract_unprotected( &the_iterator->Registry_node );
>  #ifdef __cplusplus
> diff --git a/testsuites/sptests/spchain/init.c b/testsuites/sptests/spchain/init.c
> index 476629b..dd46d68 100644
> --- a/testsuites/sptests/spchain/init.c
> +++ b/testsuites/sptests/spchain/init.c
> @@ -16,6 +16,124 @@
>  const char rtems_test_name[] = "SPCHAIN";
> +static void update_registry_and_extract(
> +  Chain_Iterator_registry *reg,
> +  Chain_Node *n
> +  _Chain_Iterator_registry_update( reg, n );
> +  _Chain_Extract_unprotected( n );
> +static Chain_Iterator_registry static_reg =
> +  CHAIN_ITERATOR_REGISTRY_INITIALIZER( static_reg );
> +static void test_chain_iterator( void )
> +  Chain_Control chain;
> +  Chain_Iterator_registry reg;
> +  Chain_Iterator fit;
> +  Chain_Iterator bit;
> +  Chain_Node a;
> +  Chain_Node b;
> +  Chain_Node c;
> +  puts( "INIT - Verify Chain_Iterator" );
> +  rtems_test_assert( _Chain_Is_empty( &static_reg.Iterators ));
> +  _Chain_Initialize_empty( &chain );
> +  _Chain_Iterator_registry_initialize( &reg );
> +  _Chain_Iterator_initialize( &chain, &reg, &fit, CHAIN_ITERATOR_FORWARD );
> +  _Chain_Iterator_initialize( &chain, &reg, &bit, CHAIN_ITERATOR_BACKWARD );
> +  rtems_test_assert( _Chain_Iterator_next( &fit ) == _Chain_Tail( &chain ));
> +  rtems_test_assert( _Chain_Iterator_next( &bit ) == _Chain_Head( &chain ));
> +  _Chain_Iterator_set_position( &fit, _Chain_Head( &chain ) );
> +  _Chain_Iterator_set_position( &bit, _Chain_Tail( &chain ) );
> +  _Chain_Append_unprotected( &chain, &a );
> +  rtems_test_assert( _Chain_Iterator_next( &fit ) == &a );
> +  rtems_test_assert( _Chain_Iterator_next( &bit ) == &a );
> +  _Chain_Append_unprotected( &chain, &b );
> +  rtems_test_assert( _Chain_Iterator_next( &bit ) == &b );
> +  _Chain_Append_unprotected( &chain, &c );
> +  rtems_test_assert( _Chain_Iterator_next( &bit ) == &c );
> +  update_registry_and_extract( &reg, &b );
> +  _Chain_Insert_unprotected( &a, &b );
> +  update_registry_and_extract( &reg, &c );
> +  update_registry_and_extract( &reg, &a );
> +  rtems_test_assert( _Chain_Iterator_next( &fit ) == &b );
> +  _Chain_Prepend_unprotected( &chain, &a );
> +  rtems_test_assert( _Chain_Iterator_next( &fit ) == &c );
> +  rtems_test_assert( !_Chain_Is_empty( &reg.Iterators ));
> +  _Chain_Iterator_destroy( &fit );
> +  _Chain_Iterator_destroy( &bit );
> +  rtems_test_assert( _Chain_Is_empty( &reg.Iterators ));
>  /* forward declarations to avoid warnings */
>  rtems_task Init(rtems_task_argument argument);
> @@ -341,6 +459,7 @@ rtems_task Init(
>    test_chain_control_initializer();
>    test_chain_node_count();
>    test_chain_insert_ordered();
> +  test_chain_iterator();
>    TEST_END();
>    rtems_test_exit(0);
> diff --git a/testsuites/sptests/spchain/spchain.doc b/testsuites/sptests/spchain/spchain.doc
> index 511e0b5..4962426 100644
> --- a/testsuites/sptests/spchain/spchain.doc
> +++ b/testsuites/sptests/spchain/spchain.doc
> @@ -25,6 +25,12 @@ directives:
>    rtems_chain_get_with_wait
>    rtems_chain_node_count_unprotected
> +  _Chain_Iterator_next
>  concepts:
> diff --git a/testsuites/sptests/spchain/spchain.scn b/testsuites/sptests/spchain/spchain.scn
> index 39f3795..4aff306 100644
> --- a/testsuites/sptests/spchain/spchain.scn
> +++ b/testsuites/sptests/spchain/spchain.scn
> @@ -1,4 +1,4 @@
> -*** TEST OF RTEMS CHAIN API ***
> +*** BEGIN OF TEST SPCHAIN ***
>  Init - Initialize chain empty
>  INIT - Verify rtems_chain_insert
>  INIT - Verify rtems_chain_is_first
> @@ -14,4 +14,5 @@ INIT - Verify rtems_chain_control layout
>  INIT - Verify rtems_chain_control initializer
>  INIT - Verify rtems_chain_node_count_unprotected
>  INIT - Verify _Chain_Insert_ordered_unprotected
> -*** END OF RTEMS CHAIN API TEST ***
> +INIT - Verify Chain_Iterator
> +*** END OF TEST SPCHAIN ***
> 1.8.4.5
> devel mailing list
> devel at rtems.org
