[PATCH 01/20] score: Delete unused CORE_RWLock_Attributes
Sebastian Huber
Tue Apr 19 13:12:29 UTC 2016
cpukit/posix/src/prwlockinit.c | 10 +---------
cpukit/score/include/rtems/score/corerwlock.h | 14 --------------
cpukit/score/include/rtems/score/corerwlockimpl.h | 16 +---------------
cpukit/score/src/corerwlock.c | 8 +-------
4 files changed, 3 insertions(+), 45 deletions(-)
diff --git a/cpukit/posix/src/prwlockinit.c b/cpukit/posix/src/prwlockinit.c
index 7cf781f..afb7056 100644
--- a/cpukit/posix/src/prwlockinit.c
+++ b/cpukit/posix/src/prwlockinit.c
@@ -97,7 +97,6 @@ int pthread_rwlock_init(
POSIX_RWLock_Control *the_rwlock;
- CORE_RWLock_Attributes the_attributes;
pthread_rwlockattr_t default_attr;
const pthread_rwlockattr_t *the_attr;
@@ -131,13 +130,6 @@ int pthread_rwlock_init(
return EINVAL;
- * Convert from POSIX attributes to Core RWLock attributes
- * NOTE: Currently there are no core rwlock attributes
- _CORE_RWLock_Initialize_attributes( &the_attributes );
the_rwlock = _POSIX_RWLock_Allocate();
if ( !the_rwlock ) {
@@ -145,7 +137,7 @@ int pthread_rwlock_init(
return EAGAIN;
- _CORE_RWLock_Initialize( &the_rwlock->RWLock, &the_attributes );
+ _CORE_RWLock_Initialize( &the_rwlock->RWLock );
_Objects_Open_u32(
&_POSIX_RWLock_Information,
diff --git a/cpukit/score/include/rtems/score/corerwlock.h b/cpukit/score/include/rtems/score/corerwlock.h
index f211339..89c18c6 100644
--- a/cpukit/score/include/rtems/score/corerwlock.h
+++ b/cpukit/score/include/rtems/score/corerwlock.h
@@ -51,16 +51,6 @@ typedef enum {
} CORE_RWLock_States;
- * The following defines the control block used to manage the
- * attributes of each RWLock.
-typedef struct {
- /** This field indicates XXX.
- int XXX;
-} CORE_RWLock_Attributes;
* The following defines the control block used to manage each
* RWLock.
@@ -69,10 +59,6 @@ typedef struct {
* which are blocked waiting for the RWLock to be released.
Thread_queue_Control Wait_queue;
- /** This element is the set of attributes which define this instance's
- * behavior.
- CORE_RWLock_Attributes Attributes;
/** This element is the current state of the RWLock.
CORE_RWLock_States current_state;
diff --git a/cpukit/score/include/rtems/score/corerwlockimpl.h b/cpukit/score/include/rtems/score/corerwlockimpl.h
index b9803c4..a8e890f 100644
--- a/cpukit/score/include/rtems/score/corerwlockimpl.h
+++ b/cpukit/score/include/rtems/score/corerwlockimpl.h
@@ -74,11 +74,9 @@ typedef enum {
* This routine initializes the RWLock based on the parameters passed.
* @param[in] the_rwlock is the RWLock to initialize
- * @param[in] the_rwlock_attributes define the behavior of this instance
void _CORE_RWLock_Initialize(
- CORE_RWLock_Control *the_rwlock,
- CORE_RWLock_Attributes *the_rwlock_attributes
+ CORE_RWLock_Control *the_rwlock
RTEMS_INLINE_ROUTINE void _CORE_RWLock_Destroy(
@@ -142,18 +140,6 @@ CORE_RWLock_Status _CORE_RWLock_Release(
Thread_Control *executing
- * This method is used to initialize core rwlock attributes.
- * @param[in] the_attributes pointer to the attributes to initialize.
-RTEMS_INLINE_ROUTINE void _CORE_RWLock_Initialize_attributes(
- CORE_RWLock_Attributes *the_attributes
- the_attributes->XXX = 0;
#ifdef __cplusplus
diff --git a/cpukit/score/src/corerwlock.c b/cpukit/score/src/corerwlock.c
index 23bb5e2..eae6258 100644
--- a/cpukit/score/src/corerwlock.c
+++ b/cpukit/score/src/corerwlock.c
@@ -22,15 +22,9 @@
- the_rwlock->Attributes = *the_rwlock_attributes;
- the_rwlock->number_of_waiting_threads = 0;
the_rwlock->number_of_readers = 0;
the_rwlock->current_state = CORE_RWLOCK_UNLOCKED;
1.8.4.5
