[PATCH 08/20] score: Remove id parameter _CORE_mutex_Seize()
Tue Apr 19 13:12:36 UTC 2016
Parameter was unused.
 cpukit/libnetworking/rtems/rtems_glue.c          | 1 -
 cpukit/posix/src/mutexlocksupp.c                 | 1 -
 cpukit/rtems/src/semobtain.c                     | 1 -
 cpukit/score/include/rtems/score/coremuteximpl.h | 8 ++------
 cpukit/score/src/apimutexlock.c                  | 1 -
 cpukit/score/src/coremutexseize.c                | 2 --
 6 files changed, 2 insertions(+), 12 deletions(-)
diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
index 17df156..38c7fd5 100644
--- a/cpukit/libnetworking/rtems/rtems_glue.c
+++ b/cpukit/libnetworking/rtems/rtems_glue.c
@@ -394,7 +394,6 @@ rtems_bsdnet_semaphore_obtain (void)
 	_CORE_mutex_Seize (
 		&the_networkSemaphore->Core_control.mutex,
 		executing,
-		networkSemaphore,
 		1,		/* wait */
 		0,		/* forever */
 		&lock_context
diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
index 0ec9b85..9e78c9e 100644
--- a/cpukit/posix/src/mutexlocksupp.c
+++ b/cpukit/posix/src/mutexlocksupp.c
@@ -60,7 +60,6 @@ int _POSIX_Mutex_Lock_support(
       _CORE_mutex_Seize(
         &the_mutex->Mutex,
         executing,
-        the_mutex->Object.id,
         blocking,
         timeout,
         &lock_context
diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
index 0b43af4..556738f 100644
--- a/cpukit/rtems/src/semobtain.c
+++ b/cpukit/rtems/src/semobtain.c
@@ -83,7 +83,6 @@ rtems_status_code rtems_semaphore_obtain(
         _CORE_mutex_Seize(
           &the_semaphore->Core_control.mutex,
           executing,
-          id,
           wait,
           timeout,
           &lock_context
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index 7facabb..e423d84 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -212,7 +212,6 @@ void _CORE_mutex_Seize_interrupt_blocking(
  *  support routine @a _Core_mutex_Seize_interrupt_blocking.
  *  @param[in] the_mutex is the mutex to attempt to lock
- *  @param[in] id is the Id of the owning API level Semaphore object
  *  @param[in] wait is true if the thread is willing to wait
  *  @param[in] timeout is the maximum number of ticks to block
  *  @param[in] lock_context is a temporary variable used to contain the ISR
@@ -234,7 +233,6 @@ void _CORE_mutex_Seize_interrupt_blocking(
 RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize_body(
   CORE_mutex_Control  *the_mutex,
   Thread_Control      *executing,
-  Objects_Id           id,
   bool                 wait,
   Watchdog_Interval    timeout,
   ISR_lock_Context    *lock_context
@@ -269,7 +267,6 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize_body(
  *  @param[in] _the_mutex is the mutex to attempt to lock
  *  @param[in] _executing The currently executing thread.
- *  @param[in] _id is the Id of the owning API level Semaphore object
  *  @param[in] _wait is true if the thread is willing to wait
  *  @param[in] _timeout is the maximum number of ticks to block
  *  @param[in] _lock_context is a temporary variable used to contain the ISR
@@ -279,16 +276,15 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize_body(
   void _CORE_mutex_Seize(
     CORE_mutex_Control  *_the_mutex,
     Thread_Control      *_executing,
-    Objects_Id           _id,
     bool                 _wait,
     Watchdog_Interval    _timeout,
     ISR_lock_Context    *_lock_context
 #else
   #define _CORE_mutex_Seize( \
-      _the_mutex, _executing, _id, _wait, _timeout, _lock_context ) \
+      _the_mutex, _executing, _wait, _timeout, _lock_context ) \
        _CORE_mutex_Seize_body( \
 #endif
 CORE_mutex_Status _CORE_mutex_Do_surrender(
diff --git a/cpukit/score/src/apimutexlock.c b/cpukit/score/src/apimutexlock.c
index bcac71a..2e36518 100644
--- a/cpukit/score/src/apimutexlock.c
+++ b/cpukit/score/src/apimutexlock.c
@@ -35,7 +35,6 @@ void _API_Mutex_Lock( API_Mutex_Control *the_mutex )
   _CORE_mutex_Seize(
     &the_mutex->Mutex,
     _Thread_Executing,
     true,
     0,
     &lock_context
diff --git a/cpukit/score/src/coremutexseize.c b/cpukit/score/src/coremutexseize.c
index fa45151..d76c977 100644
--- a/cpukit/score/src/coremutexseize.c
+++ b/cpukit/score/src/coremutexseize.c
@@ -28,7 +28,6 @@
-  Objects_Id           _id,
   bool                 _wait,
   ISR_Level            _level
@@ -37,7 +36,6 @@ void _CORE_mutex_Seize(
     _the_mutex,
     _executing,
-    _id,
     _wait,
     _timeout,
     _level
1.8.4.5
