[PATCH 10/20] posix: Simplify _POSIX_Mutex_Get_interrupt_disable
Tue Apr 19 13:12:38 UTC 2016
Remove superfluous location parameter.
 cpukit/posix/include/rtems/posix/muteximpl.h | 14 +++---
 cpukit/posix/src/mutexget.c                  | 13 +++---
 cpukit/posix/src/mutexlocksupp.c             | 67 +++++++++-------------------
 cpukit/posix/src/mutexsetprioceiling.c       | 55 ++++++++---------------
 cpukit/posix/src/mutexunlock.c               | 45 ++++++-------------
 5 files changed, 65 insertions(+), 129 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/muteximpl.h b/cpukit/posix/include/rtems/posix/muteximpl.h
index c1fab0c..1bd74cc 100644
--- a/cpukit/posix/include/rtems/posix/muteximpl.h
+++ b/cpukit/posix/include/rtems/posix/muteximpl.h
@@ -15,13 +15,14 @@
  *  http://www.rtems.org/license/LICENSE.
+#ifndef _RTEMS_POSIX_MUTEXIMPL_H
+#define _RTEMS_POSIX_MUTEXIMPL_H
 #include <rtems/posix/mutex.h>
-#ifndef _RTEMS_POSIX_MUTEXIMPL_H
-#define _RTEMS_POSIX_MUTEXIMPL_H
+#include <pthread.h>
 #ifdef __cplusplus
 extern "C" {
@@ -139,10 +140,9 @@ POSIX_Mutex_Control *_POSIX_Mutex_Get (
  *  @note: This version of the method uses an interrupt critical section.
-POSIX_Mutex_Control *_POSIX_Mutex_Get_interrupt_disable (
-  pthread_mutex_t   *mutex,
-  Objects_Locations *location,
-  ISR_lock_Context  *lock_context
+POSIX_Mutex_Control *_POSIX_Mutex_Get_interrupt_disable(
+  pthread_mutex_t  *mutex,
+  ISR_lock_Context *lock_context
 #ifdef __cplusplus
diff --git a/cpukit/posix/src/mutexget.c b/cpukit/posix/src/mutexget.c
index 5c0cc42..9ad226a 100644
--- a/cpukit/posix/src/mutexget.c
+++ b/cpukit/posix/src/mutexget.c
@@ -68,20 +68,21 @@ POSIX_Mutex_Control *_POSIX_Mutex_Get (
     _Objects_Get( &_POSIX_Mutex_Information, (Objects_Id) *mutex, location );
-  if ( !_POSIX_Mutex_Check_id_and_auto_init( mutex, location ) ) {
+  Objects_Locations location;
+  if ( !_POSIX_Mutex_Check_id_and_auto_init( mutex, &location ) ) {
     return NULL;
   return (POSIX_Mutex_Control *) _Objects_Get_isr_disable(
-    location,
+    &location,
     lock_context
diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
index 9e78c9e..3c4e26e 100644
--- a/cpukit/posix/src/mutexlocksupp.c
+++ b/cpukit/posix/src/mutexlocksupp.c
@@ -18,62 +18,35 @@
 #include "config.h"
 #endif
-#include <errno.h>
-#include <pthread.h>
-#include <rtems/system.h>
-#include <rtems/score/coremuteximpl.h>
-#include <rtems/score/watchdog.h>
-#include <rtems/score/threadimpl.h>
-#include <rtems/posix/priorityimpl.h>
 THREAD_WAIT_QUEUE_OBJECT_ASSERT( POSIX_Mutex_Control, Mutex.Wait_queue );
- *  _POSIX_Mutex_Lock_support
- *  A support routine which implements guts of the blocking, non-blocking, and
- *  timed wait version of mutex lock.
 int _POSIX_Mutex_Lock_support(
-  bool                       blocking,
-  Watchdog_Interval          timeout
+  bool               blocking,
+  Watchdog_Interval  timeout
-  POSIX_Mutex_Control          *the_mutex;
-  Objects_Locations             location;
-  ISR_lock_Context              lock_context;
-  Thread_Control               *executing;
-  the_mutex = _POSIX_Mutex_Get_interrupt_disable(
-    mutex,
-    &location,
-    &lock_context
-  switch ( location ) {
+  POSIX_Mutex_Control *the_mutex;
+  ISR_lock_Context     lock_context;
+  Thread_Control      *executing;
-    case OBJECTS_LOCAL:
-      executing = _Thread_Executing;
-      _CORE_mutex_Seize(
-        &the_mutex->Mutex,
-        executing,
-        blocking,
-        timeout,
-        &lock_context
-      return _POSIX_Mutex_Translate_core_mutex_return_code(
-        (CORE_mutex_Status) executing->Wait.return_code
+  the_mutex = _POSIX_Mutex_Get_interrupt_disable( mutex, &lock_context );
-#if defined(RTEMS_MULTIPROCESSING)
-    case OBJECTS_REMOTE:
-#endif
-    case OBJECTS_ERROR:
-      break;
+  if ( the_mutex == NULL ) {
+    return EINVAL;
-  return EINVAL;
+  executing = _Thread_Executing;
+  _CORE_mutex_Seize(
+    &the_mutex->Mutex,
+    executing,
+    blocking,
+    timeout,
+    &lock_context
+  return _POSIX_Mutex_Translate_core_mutex_return_code(
+    (CORE_mutex_Status) executing->Wait.return_code
diff --git a/cpukit/posix/src/mutexsetprioceiling.c b/cpukit/posix/src/mutexsetprioceiling.c
index 718bfc4..1f9f516 100644
--- a/cpukit/posix/src/mutexsetprioceiling.c
+++ b/cpukit/posix/src/mutexsetprioceiling.c
@@ -18,14 +18,7 @@
 #include "config.h"
 #endif
-#include <errno.h>
  *  13.6.2 Change the Priority Ceiling of a Mutex, P1003.1c/Draft 10, p. 131
@@ -38,7 +31,6 @@ int pthread_mutex_setprioceiling(
   register POSIX_Mutex_Control *the_mutex;
   Priority_Control              the_priority;
@@ -64,36 +56,25 @@ int pthread_mutex_setprioceiling(
    *  NOTE: This makes it easier to get 100% binary coverage since the
    *        bad Id case is handled by the switch.
-    mutex,
-    &location,
-    &lock_context
-      *old_ceiling = _POSIX_Priority_From_core(
-        the_mutex->Mutex.Attributes.priority_ceiling
-      the_mutex->Mutex.Attributes.priority_ceiling = the_priority;
-       *  We are required to unlock the mutex before we return.
-      _CORE_mutex_Surrender(
-        NULL,
-        0,
-        &lock_context
-      return 0;
-    case OBJECTS_REMOTE:  /* impossible to get here */
-#endif
-      break;
+    return EINVAL;
-  return EINVAL;
+  *old_ceiling = _POSIX_Priority_From_core(
+    the_mutex->Mutex.Attributes.priority_ceiling
+  the_mutex->Mutex.Attributes.priority_ceiling = the_priority;
+   *  We are required to unlock the mutex before we return.
+  _CORE_mutex_Surrender(
+    NULL,
+    0,
+    &lock_context
+  return 0;
diff --git a/cpukit/posix/src/mutexunlock.c b/cpukit/posix/src/mutexunlock.c
index 1a83a0a..4de1917 100644
--- a/cpukit/posix/src/mutexunlock.c
+++ b/cpukit/posix/src/mutexunlock.c
@@ -18,14 +18,7 @@
 #include "config.h"
 #endif
-#include <errno.h>
  *  11.3.3 Locking and Unlocking a Mutex, P1003.1c/Draft 10, p. 93
@@ -37,33 +30,21 @@ int pthread_mutex_unlock(
-  register POSIX_Mutex_Control *the_mutex;
-  CORE_mutex_Status             status;
-    mutex,
-    &location,
-    &lock_context
+  CORE_mutex_Status    status;
-      status = _CORE_mutex_Surrender(
-        NULL,
-        0,
-        &lock_context
-      return _POSIX_Mutex_Translate_core_mutex_return_code( status );
-#endif
-      break;
+    return EINVAL;
-  return EINVAL;
+  status = _CORE_mutex_Surrender(
+    NULL,
+    0,
+    &lock_context
+  return _POSIX_Mutex_Translate_core_mutex_return_code( status );
1.8.4.5
