[PATCH 14/20] score: Simplify _Objects_Initialize_information()
Tue Apr 19 13:12:42 UTC 2016
Remove unused supports_global parameter.  Convert
_Objects_Initialize_information() to a macro to avoid use of
RTEMS_MULTIPROCESSING define for each caller.
 cpukit/posix/src/cond.c                        |  6 +--
 cpukit/posix/src/key.c                         |  6 +--
 cpukit/posix/src/mqueue.c                      | 12 +----
 cpukit/posix/src/mutex.c                       |  6 +--
 cpukit/posix/src/pbarrier.c                    |  8 +--
 cpukit/posix/src/prwlock.c                     |  8 +--
 cpukit/posix/src/pspin.c                       |  6 +--
 cpukit/posix/src/pthread.c                     |  4 --
 cpukit/posix/src/ptimer.c                      |  6 +--
 cpukit/posix/src/semaphore.c                   |  6 +--
 cpukit/rtems/src/barrier.c                     |  6 +--
 cpukit/rtems/src/dpmem.c                       |  6 +--
 cpukit/rtems/src/msg.c                         |  6 +--
 cpukit/rtems/src/part.c                        |  6 +--
 cpukit/rtems/src/ratemon.c                     |  6 +--
 cpukit/rtems/src/region.c                      |  6 +--
 cpukit/rtems/src/rtemstimer.c                  |  6 +--
 cpukit/rtems/src/sem.c                         |  6 +--
 cpukit/rtems/src/tasks.c                       |  4 --
 cpukit/sapi/src/extension.c                    |  6 +--
 cpukit/score/include/rtems/score/objectimpl.h  | 68 +++++++++++++++++++++-----
 cpukit/score/include/rtems/score/threadimpl.h  |  4 --
 cpukit/score/src/apimutex.c                    |  6 +--
 cpukit/score/src/objectinitializeinformation.c |  3 +-
 cpukit/score/src/thread.c                      | 16 +-----
 testsuites/psxtests/psxobj01/init.c            |  8 +--
 26 files changed, 83 insertions(+), 148 deletions(-)
diff --git a/cpukit/posix/src/cond.c b/cpukit/posix/src/cond.c
index d0ce8a6..8ee57d8 100644
--- a/cpukit/posix/src/cond.c
+++ b/cpukit/posix/src/cond.c
@@ -53,12 +53,8 @@ static void _POSIX_Condition_variables_Manager_initialization(void)
     sizeof( POSIX_Condition_variables_Control ),
                                 /* size of this object's control block */
     true,                       /* true if names for this object are strings */
-    _POSIX_PATH_MAX             /* maximum length of each object's name */
-#if defined(RTEMS_MULTIPROCESSING)
-    false,                      /* true if this is a global object class */
+    _POSIX_PATH_MAX,            /* maximum length of each object's name */
     NULL                        /* Proxy extraction support callout */
-#endif
diff --git a/cpukit/posix/src/key.c b/cpukit/posix/src/key.c
index 0bc88ae..6b2dc3d 100644
--- a/cpukit/posix/src/key.c
+++ b/cpukit/posix/src/key.c
@@ -141,12 +141,8 @@ static void _POSIX_Keys_Manager_initialization(void)
     sizeof( POSIX_Keys_Control ),
-#endif
   _POSIX_Keys_Initialize_keypool();
diff --git a/cpukit/posix/src/mqueue.c b/cpukit/posix/src/mqueue.c
index 0f261f6..e5fc3a0 100644
--- a/cpukit/posix/src/mqueue.c
+++ b/cpukit/posix/src/mqueue.c
@@ -58,12 +58,8 @@ static void _POSIX_Message_queue_Manager_initialization(void)
     sizeof( POSIX_Message_queue_Control ),
-#endif
     &_POSIX_Message_queue_Information_fds,
@@ -73,12 +69,8 @@ static void _POSIX_Message_queue_Manager_initialization(void)
     sizeof( POSIX_Message_queue_Control_fd ),
-    NAME_MAX                    /* maximum length of each object's name */
+    NAME_MAX,                   /* maximum length of each object's name */
-#endif
diff --git a/cpukit/posix/src/mutex.c b/cpukit/posix/src/mutex.c
index ef56d0a..22b14c0 100644
--- a/cpukit/posix/src/mutex.c
+++ b/cpukit/posix/src/mutex.c
@@ -74,12 +74,8 @@ static void _POSIX_Mutex_Manager_initialization(void)
     sizeof( POSIX_Mutex_Control ),
-#endif
diff --git a/cpukit/posix/src/pbarrier.c b/cpukit/posix/src/pbarrier.c
index 1ae3115..8216a08 100644
--- a/cpukit/posix/src/pbarrier.c
+++ b/cpukit/posix/src/pbarrier.c
@@ -39,12 +39,8 @@ static void _POSIX_Barrier_Manager_initialization(void)
 				    /* maximum objects of this class */
     sizeof( POSIX_Barrier_Control ),/* size of this object's control block */
     true,                           /* true if the name is a string */
-    NULL                           /* Proxy extraction support callout */
-#endif
+    NULL                            /* Proxy extraction support callout */
diff --git a/cpukit/posix/src/prwlock.c b/cpukit/posix/src/prwlock.c
index 10c88d9..963ad1f 100644
--- a/cpukit/posix/src/prwlock.c
+++ b/cpukit/posix/src/prwlock.c
@@ -36,12 +36,8 @@ static void _POSIX_RWLock_Manager_initialization(void)
     sizeof( POSIX_RWLock_Control ), /* size of this object's control block */
-#endif
diff --git a/cpukit/posix/src/pspin.c b/cpukit/posix/src/pspin.c
index 62e6f3a..6c466bc 100644
--- a/cpukit/posix/src/pspin.c
+++ b/cpukit/posix/src/pspin.c
@@ -39,12 +39,8 @@ static void _POSIX_Spinlock_Manager_initialization(void)
     sizeof( POSIX_Spinlock_Control ),/* size of this object's control block */
-#endif
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index cf4eab4..61e498b 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -352,10 +352,6 @@ static void _POSIX_Threads_Manager_initialization(void)
-    false                        /* true if this is a global object class */
-#endif
diff --git a/cpukit/posix/src/ptimer.c b/cpukit/posix/src/ptimer.c
index 810112a..de3645c 100644
--- a/cpukit/posix/src/ptimer.c
+++ b/cpukit/posix/src/ptimer.c
@@ -67,12 +67,8 @@ static void _POSIX_Timer_Manager_initialization(void)
     sizeof( POSIX_Timer_Control ),
-#endif
diff --git a/cpukit/posix/src/semaphore.c b/cpukit/posix/src/semaphore.c
index db3ae0c..661456c 100644
--- a/cpukit/posix/src/semaphore.c
+++ b/cpukit/posix/src/semaphore.c
@@ -55,12 +55,8 @@ static void _POSIX_Semaphore_Manager_initialization(void)
     sizeof( POSIX_Semaphore_Control ),
-#endif
diff --git a/cpukit/rtems/src/barrier.c b/cpukit/rtems/src/barrier.c
index 6c85f47..a291238 100644
--- a/cpukit/rtems/src/barrier.c
+++ b/cpukit/rtems/src/barrier.c
@@ -40,12 +40,8 @@ static void _Barrier_Manager_initialization(void)
     sizeof( Barrier_Control ),     /* size of this object's control block */
     false,                         /* true if the name is a string */
-    RTEMS_MAXIMUM_NAME_LENGTH      /* maximum length of an object name */
+    RTEMS_MAXIMUM_NAME_LENGTH,     /* maximum length of an object name */
-#endif
diff --git a/cpukit/rtems/src/dpmem.c b/cpukit/rtems/src/dpmem.c
index aca71a3..2522a59 100644
--- a/cpukit/rtems/src/dpmem.c
+++ b/cpukit/rtems/src/dpmem.c
@@ -38,12 +38,8 @@ static void _Dual_ported_memory_Manager_initialization(void)
     sizeof( Dual_ported_memory_Control ),
     false,                        /* true if names of this object are strings */
-    RTEMS_MAXIMUM_NAME_LENGTH     /* maximum length of each object's name */
+    RTEMS_MAXIMUM_NAME_LENGTH,    /* maximum length of each object's name */
-#endif
diff --git a/cpukit/rtems/src/msg.c b/cpukit/rtems/src/msg.c
index acb6c37..44a0727 100644
--- a/cpukit/rtems/src/msg.c
+++ b/cpukit/rtems/src/msg.c
@@ -40,13 +40,9 @@ static void _Message_queue_Manager_initialization(void)
     sizeof( Message_queue_Control ),
-    true,                         /* true if this is a global object class */
     _Message_queue_MP_Send_extract_proxy
-#endif
diff --git a/cpukit/rtems/src/part.c b/cpukit/rtems/src/part.c
index 211c117..4df676e 100644
--- a/cpukit/rtems/src/part.c
+++ b/cpukit/rtems/src/part.c
@@ -37,12 +37,8 @@ static void _Partition_Manager_initialization(void)
     sizeof( Partition_Control ), /* size of this object's control block */
     _Partition_MP_Send_extract_proxy  /* Proxy extraction support callout */
-#endif
diff --git a/cpukit/rtems/src/ratemon.c b/cpukit/rtems/src/ratemon.c
index b0d248f..dd3ca29 100644
--- a/cpukit/rtems/src/ratemon.c
+++ b/cpukit/rtems/src/ratemon.c
@@ -37,12 +37,8 @@ static void _Rate_monotonic_Manager_initialization(void)
     sizeof( Rate_monotonic_Control ),/* size of this object's control block */
-#endif
diff --git a/cpukit/rtems/src/region.c b/cpukit/rtems/src/region.c
index f1c2b23..65933f9 100644
--- a/cpukit/rtems/src/region.c
+++ b/cpukit/rtems/src/region.c
@@ -48,12 +48,8 @@ static void _Region_Manager_initialization(void)
     sizeof( Region_Control ),  /* size of this object's control block */
-#endif
diff --git a/cpukit/rtems/src/rtemstimer.c b/cpukit/rtems/src/rtemstimer.c
index f591c25..d60e4a9 100644
--- a/cpukit/rtems/src/rtemstimer.c
+++ b/cpukit/rtems/src/rtemstimer.c
@@ -39,12 +39,8 @@ static void _Timer_Manager_initialization(void)
     sizeof( Timer_Control ),   /* size of this object's control block */
-#endif
diff --git a/cpukit/rtems/src/sem.c b/cpukit/rtems/src/sem.c
index 13615eb..a221852 100644
--- a/cpukit/rtems/src/sem.c
+++ b/cpukit/rtems/src/sem.c
@@ -39,12 +39,8 @@ static void _Semaphore_Manager_initialization(void)
     sizeof( Semaphore_Control ), /* size of this object's control block */
     _Semaphore_MP_Send_extract_proxy /* Proxy extraction support callout */
-#endif
diff --git a/cpukit/rtems/src/tasks.c b/cpukit/rtems/src/tasks.c
index 832228e..f18e0ab 100644
--- a/cpukit/rtems/src/tasks.c
+++ b/cpukit/rtems/src/tasks.c
@@ -185,10 +185,6 @@ static void _RTEMS_tasks_Manager_initialization(void)
-    true                       /* true if this is a global object class */
-#endif
diff --git a/cpukit/sapi/src/extension.c b/cpukit/sapi/src/extension.c
index 3378850..9c49683 100644
--- a/cpukit/sapi/src/extension.c
+++ b/cpukit/sapi/src/extension.c
@@ -36,12 +36,8 @@ static void _Extension_Manager_initialization(void)
     rtems_configuration_get_maximum_extensions(),
     sizeof( Extension_Control ),
-#endif
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index ee9da93..47d17dd 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -122,6 +122,7 @@ typedef enum {
   OBJECTS_ERROR  = 1          /* id was invalid */
 } Objects_Locations;
+#if defined(RTEMS_MULTIPROCESSING)
  *  The following type defines the callout used when a local task
  *  is extracted from a remote thread queue (i.e. it's proxy must
@@ -131,6 +132,7 @@ typedef void ( *Objects_Thread_queue_Extract_callout )(
   Thread_Control *,
   Objects_Id
+#endif
  *  The following defines the structure for the information used to
@@ -238,6 +240,20 @@ void _Objects_Shrink_information(
   Objects_Information *information
+void _Objects_Do_initialize_information(
+  Objects_Information *information,
+  Objects_APIs         the_api,
+  uint16_t             the_class,
+  uint32_t             maximum,
+  uint16_t             size,
+  bool                 is_string,
+  uint32_t             maximum_name_length
+  Objects_Thread_queue_Extract_callout extract
+#endif
  *  @brief Initialize object Information
@@ -259,20 +275,48 @@ void _Objects_Shrink_information(
  *  @param[in] is_string is true if this object uses string style names.
  *  @param[in] maximum_name_length is the maximum length of object names.
-void _Objects_Initialize_information (
-  Objects_Information *information,
-  Objects_APIs         the_api,
-  uint16_t             the_class,
-  uint32_t             maximum,
-  uint16_t             size,
-  bool                 is_string,
-  uint32_t             maximum_name_length
-  bool                 supports_global,
-  Objects_Thread_queue_Extract_callout extract
+  #define _Objects_Initialize_information( \
+    information, \
+    the_api, \
+    the_class, \
+    maximum, \
+    size, \
+    is_string, \
+    maximum_name_length, \
+    extract \
+    _Objects_Do_initialize_information( \
+      information, \
+      the_api, \
+      the_class, \
+      maximum, \
+      size, \
+      is_string, \
+      extract \
+#else
+    information, \
+    the_api, \
+    the_class, \
+    maximum, \
+    size, \
+    is_string, \
+    extract \
+      information, \
+      the_api, \
+      the_class, \
+      maximum, \
+      size, \
+      is_string, \
+      maximum_name_length \
 #endif
  *  @brief Object API Maximum Class
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 6b65e8e..b19a6dc 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -94,10 +94,6 @@ void _Thread_Initialize_information(
   uint32_t             maximum,
   bool                 is_string,
-#endif
diff --git a/cpukit/score/src/apimutex.c b/cpukit/score/src/apimutex.c
index 1ac5052..a098edb 100644
--- a/cpukit/score/src/apimutex.c
+++ b/cpukit/score/src/apimutex.c
@@ -36,12 +36,8 @@ void _API_Mutex_Initialization(
     maximum_mutexes,             /* maximum objects of this class */
     sizeof( API_Mutex_Control ), /* size of this object's control block */
-    0                            /* maximum length of an object name */
+    0,                           /* maximum length of an object name */
-#endif
diff --git a/cpukit/score/src/objectinitializeinformation.c b/cpukit/score/src/objectinitializeinformation.c
index 3149bb1..dc8a106 100644
--- a/cpukit/score/src/objectinitializeinformation.c
+++ b/cpukit/score/src/objectinitializeinformation.c
@@ -24,7 +24,7 @@
 #include <rtems/score/sysstate.h>
-void _Objects_Initialize_information(
   uint16_t             the_class,
@@ -34,7 +34,6 @@ void _Objects_Initialize_information(
 #endif
diff --git a/cpukit/score/src/thread.c b/cpukit/score/src/thread.c
index 68a728c..83e98cb 100644
--- a/cpukit/score/src/thread.c
+++ b/cpukit/score/src/thread.c
@@ -51,10 +51,6 @@ void _Thread_Initialize_information(
   uint32_t             maximum,
   bool                 is_string,
-#endif
@@ -64,12 +60,8 @@ void _Thread_Initialize_information(
     maximum,
     _Thread_Control_size,
     is_string,
-    maximum_name_length
-    #if defined(RTEMS_MULTIPROCESSING)
-      supports_global,
-      NULL
-    #endif
+    NULL
   _Freechain_Initialize(
@@ -116,10 +108,6 @@ void _Thread_Handler_initialization(void)
     _Thread_Get_maximum_internal_threads(),
     false,                      /* true if names for this object are strings */
     8                           /* maximum length of each object's name */
-    #endif
diff --git a/testsuites/psxtests/psxobj01/init.c b/testsuites/psxtests/psxobj01/init.c
index 5f87308..c3b3f49 100644
--- a/testsuites/psxtests/psxobj01/init.c
+++ b/testsuites/psxtests/psxobj01/init.c
@@ -46,12 +46,8 @@ rtems_task Init(
     0,           /* maximum */
     4,           /* size */
     true,        /* is_string */
-    10           /* maximum_name_length */
-      false,       /* supports_global */
-      NULL         /* Objects_Thread_queue_Extract_callout extract */
-    #endif
+    10,          /* maximum_name_length */
+    NULL         /* Objects_Thread_queue_Extract_callout extract */
1.8.4.5
