[PATCH 19/20] score: Rename _CORE_barrier_Wait()
Tue Apr 19 13:12:47 UTC 2016
Rename _CORE_barrier_Wait() into _CORE_barrier_Seize().  Rename
_CORE_barrier_Release() into _CORE_barrier_Surrender().  This avoids
confusion with the ISR lock acquire and release.
 cpukit/posix/src/pbarrierwait.c                    |  2 +-
 cpukit/rtems/src/barrierrelease.c                  |  2 +-
 cpukit/rtems/src/barrierwait.c                     |  2 +-
 cpukit/score/include/rtems/score/corebarrierimpl.h | 20 ++++++++++----------
 cpukit/score/src/corebarrierrelease.c              |  2 +-
 cpukit/score/src/corebarrierwait.c                 |  4 ++--
 6 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/cpukit/posix/src/pbarrierwait.c b/cpukit/posix/src/pbarrierwait.c
index fd94e45..86bfba7 100644
--- a/cpukit/posix/src/pbarrierwait.c
+++ b/cpukit/posix/src/pbarrierwait.c
@@ -52,7 +52,7 @@ int pthread_barrier_wait(
     case OBJECTS_LOCAL:
       executing = _Thread_Executing;
-      _CORE_barrier_Wait(
+      _CORE_barrier_Seize(
         &the_barrier->Barrier,
         executing,
         true,
diff --git a/cpukit/rtems/src/barrierrelease.c b/cpukit/rtems/src/barrierrelease.c
index 02500e5..77937b3 100644
--- a/cpukit/rtems/src/barrierrelease.c
+++ b/cpukit/rtems/src/barrierrelease.c
@@ -54,7 +54,7 @@ rtems_status_code rtems_barrier_release(
   switch ( location ) {
     case OBJECTS_LOCAL:
-      *released = _CORE_barrier_Release( &the_barrier->Barrier, NULL, 0 );
+      *released = _CORE_barrier_Surrender( &the_barrier->Barrier, NULL, 0 );
       _Objects_Put( &the_barrier->Object );
       return RTEMS_SUCCESSFUL;
diff --git a/cpukit/rtems/src/barrierwait.c b/cpukit/rtems/src/barrierwait.c
index b2999eb..f8f9ac3 100644
--- a/cpukit/rtems/src/barrierwait.c
+++ b/cpukit/rtems/src/barrierwait.c
@@ -40,7 +40,7 @@ rtems_status_code rtems_barrier_wait(
     case OBJECTS_LOCAL:
         executing,
         true,
diff --git a/cpukit/score/include/rtems/score/corebarrierimpl.h b/cpukit/score/include/rtems/score/corebarrierimpl.h
index 8e923df..239bd9d 100644
--- a/cpukit/score/include/rtems/score/corebarrierimpl.h
+++ b/cpukit/score/include/rtems/score/corebarrierimpl.h
@@ -84,7 +84,7 @@ RTEMS_INLINE_ROUTINE void _CORE_barrier_Destroy(
   _Thread_queue_Destroy( &the_barrier->Wait_queue );
-void _CORE_barrier_Do_wait(
+void _CORE_barrier_Do_seize(
   CORE_barrier_Control    *the_barrier,
   Thread_Control          *executing,
   bool                     wait,
@@ -116,7 +116,7 @@ void _CORE_barrier_Do_wait(
  * @note Status is returned via the thread control block.
 #if defined(RTEMS_MULTIPROCESSING)
-  #define _CORE_barrier_Wait( \
+  #define _CORE_barrier_Seize( \
     the_barrier, \
     executing, \
     wait, \
@@ -124,7 +124,7 @@ void _CORE_barrier_Do_wait(
     mp_callout, \
     mp_id \
-    _CORE_barrier_Do_wait( \
+    _CORE_barrier_Do_seize( \
       the_barrier, \
       executing, \
       wait, \
@@ -133,7 +133,7 @@ void _CORE_barrier_Do_wait(
       mp_id \
 #else
     the_barrier, \
     executing, \
     wait, \
@@ -141,7 +141,7 @@ void _CORE_barrier_Do_wait(
     mp_callout, \
     mp_id \
       the_barrier, \
       executing, \
       wait, \
@@ -149,7 +149,7 @@ void _CORE_barrier_Do_wait(
 #endif
-uint32_t _CORE_barrier_Do_release(
+uint32_t _CORE_barrier_Do_surrender(
@@ -172,23 +172,23 @@ uint32_t _CORE_barrier_Do_release(
  *  @retval the number of unblocked threads
-  #define _CORE_barrier_Release( \
+  #define _CORE_barrier_Surrender( \
     the_barrier, \
     mp_callout, \
     mp_id \
-    _CORE_barrier_Do_release( \
+    _CORE_barrier_Do_surrender( \
       the_barrier, \
       mp_callout, \
       mp_id \
 #else
     the_barrier, \
     mp_callout, \
     mp_id \
       the_barrier \
 #endif
diff --git a/cpukit/score/src/corebarrierrelease.c b/cpukit/score/src/corebarrierrelease.c
index 4458064..6d72203 100644
--- a/cpukit/score/src/corebarrierrelease.c
+++ b/cpukit/score/src/corebarrierrelease.c
@@ -23,7 +23,7 @@
diff --git a/cpukit/score/src/corebarrierwait.c b/cpukit/score/src/corebarrierwait.c
index 689ead0..11495e5 100644
--- a/cpukit/score/src/corebarrierwait.c
+++ b/cpukit/score/src/corebarrierwait.c
@@ -23,7 +23,7 @@
   bool                     wait,
@@ -45,7 +45,7 @@ void _CORE_barrier_Do_wait(
 	 the_barrier->Attributes.maximum_count) {
       executing->Wait.return_code = CORE_BARRIER_STATUS_AUTOMATICALLY_RELEASED;
       _Thread_queue_Release( &the_barrier->Wait_queue, &lock_context );
-      _CORE_barrier_Release( the_barrier, mp_callout, mp_id );
+      _CORE_barrier_Surrender( the_barrier, mp_callout, mp_id );
       return;
1.8.4.5
