BSP Console support (was Re: [PATCH] arm: mx6ulevk: Initial BSP support for i.MX 6UltraLite EVK board.)
Wed Apr 20 05:50:15 UTC 2016
Hello Chris,
On 20/04/16 01:24, Chris Johns wrote:
> On 19/04/2016 19:31, Sebastian Huber wrote:
>> Please don't use this console driver framework. Use
>> rtems_termios_device_handler instead.
> I am not on board with saying we do this and I have a few reasons
> which I would like to present and discuss.
> The console support in BSPs is a mess and in general we have no
> standard rules so any debate on this topic is destined to be related
> to style, preference and history. We need to sort through these things
> and get a clear understand of the path we want to take and then
> support it.
> To guide us I would like to propose some simple rules and while they
> specifically address consoles it does relate more broadly to all parts
> of a BSP.
> 1. One method to support consoles in a BSP.
> Currently I think we have 4 or more ways console IO happens. There are
> direct low level writes to devices, simulator type writes, and
> termios, and within termios we have a couple of possible paths we can
> take. Joel, is this correct?
> We should aim at a single termios solution as preferred. I am not sure
> if this is possible on low memory foot print targets and if it is not
> possible we should address that in a supported way.
Termios is nothing for low memory targets. However, my comment refers to
Termios. We have currently two device interfaces to Termios. We have
several console driver frameworks.
> 2. Technical merit.
> We should base the adoption of a solution on technical merit. This
> however needs to be in the context of documentation and migration.
> 3. Documentation.
> For any solution to be accepted there needs to be documentation.
> Existing documentation should be given precedence over any technical
> merit.
The state of the art Termios device interface is documented in the manual:
https://docs.rtems.org/doc-current/share/rtems/html/bsp_howto/Console-Driver-Serial-Driver-Functioning-Overview.html#Console-Driver-Serial-Driver-Functioning-Overview
> 4. Migration of existing BSPs.
> There needs to be a defined and clear migration path. Without such a
> path the RTEMS Project ends up having to support all implementations
> for ever. Without a migration plan precedence has to be given to the
> solution that covers the most number of BSPs.
> It would be nice to know where we stand with numbers?
I spend some days to convert all BSPs to the new Termios device
interface. I stopped to work on this once I hit the PC BSP. So, if
someone has enough time to clean up this BSP, the rest should be very easy.
> 5. Tier Status
>  [ Tier documentation is coming ]
> Any BPS that does not support the preferred console framework cannot
> be tier 1. If an architecture does not have a tier 1 BSP it cannot be
> a tier 1 architecture.
> In relation to 'rtems_termios_device_handler' termios framework:
> a) What is the technical reasons we adopt this framework?
Yes, its much easier to write drivers for it since you don't have to
deal with all the tables. It supports SMP in contrast to the old
interface. This is the primary reason why we have this new interface.
> b) Is the framework documented anywhere?
Yes, in the manual.
>  ruru rtems.git $ grep -r rtems_termios_device_handler doc/
>  ruru rtems.git $
> while:
>  ruru rtems.git $ grep -r rtems_termios_handler doc/
>  doc/bsp_howto/console.t:const rtems_termios_handler
> my_driver_handler_polled = @{
> my_driver_handler_interrupt = @{
>  doc/bsp_howto/console.t:extern const rtems_termios_handler
> my_driver_handler_polled;
> my_driver_handler_interrupt;
>  doc/bsp_howto/console.t:  const rtems_termios_handler *handler =
> &my_driver_handler_interrupt;
> &my_driver_handler_polled;
>  ruru rtems.git $
This is a typo. I will fix this once the new documentation repository is
available.
> c) What is the migration plan?
> The PC BSP uses ns16550.c and not ns16550-context.c. This second file
> is almost a copy of the first. If I find a bug in either file should I
> attempt to fix both or ignore the one I cannot test?
I copied the ns16550 due to the PC BSP.
> If the new 'rtems_termios_device_handler' is adopted the PC BSP may
> loose its tier 1 status. In the future we should avoid doing this and
> a migration plan should address tier 1 BSPs first.
I don't think i386 is tier 1 at the moment.
> The copied driver change is unfortunate and highlights a concern I
> have. A change like this may allow a technically better solution to be
> delivered however it does not account for the time and effort others
> need to spend to migrate other BSPs.
I really tried to migrate all BSPs (I spent sever days of work into this
topic), but I didn''t have infinite time for it. At some point I had to
stop working on this and decided to keep the exiting interface. So,
existing BSPs work as before and there is no immediate need for a migration.
> Once a change like this is accepted into the project the project
> becomes responsible for updating any dependent BSPs. History shows
> this does not happen and that is understandable, the RTEMS Project has
> no direct funding to do this work and expecting this to be done
> unfunded is not reasonable. Asking for a migration plan is a way the
> project can understand what else is required and how what will be done.
Yes, I missed to provide a migration plan. Sorry for that.
> As I stated at the start of this post, I am not yet on board and I
> would like to understand how we address the situation we are now in.
> Without a clear understand of this any new BSP is at risk.
> Chris
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
